PDA
View Full Version : Electrical
Pages : 1 2 [3] 4 5 6
  1. Electrical anyone has full bluetooth Champ coding files?
  2. Electrical Aftermarket Coolant Temp Sensor
  3. Electrical Can use NCS to add MINI connected(S6NMA)?
  4. Electrical What is this?!?!
  5. Electrical A/C Climate button not working
  6. Electrical Enable BFD1 and BFD2
  7. Electrical Ultragauge & oil temp/pressure
  8. Electrical NCS Expert to control rad fan...
  9. Electrical Can anyone confirm they can use INPA for diagnosis?
  10. Electrical R60 (2011) Start/Stop automatic memory function
  11. Electrical Thermostat switch
  12. Electrical HomeLink would not able to bind to garage door
  13. Electrical ncs expert for 2013?
  14. Electrical swap to a used tachometer
  15. Electrical "List" of songs from USB input?
  16. Electrical R56 Spot Light bulb change ?
  17. Electrical Front Brake Service reset not resetting
  18. Electrical Cruise Control Speed Display???
  19. Electrical Navigation Language
  20. Electrical Trip Odometer Display
  21. Electrical Yep.. ANOTHER Hella 500 install
  22. Electrical ncs expert and r56 2008
  23. Electrical knock sensor
  24. Electrical Enable Welcome Lights with light switch off
  25. Electrical Installing Pulsing 3rd Brake Light
  26. Electrical Help! Get problems after coding KOBMI module
  27. Electrical Dension Gateway 500 with BTA1500 Bluetooth
  28. Electrical Wiring in non-dimming rearview mirror
  29. Electrical Comfort Bluetooth/USB $6NE music via Bluetooth?
  30. Electrical City Lights Bulb check??
  31. Electrical Wanted: Conversion to Rear Amber Turn Light for '13 JWS
  32. Electrical Anyone with Mini Connected able to help?
  33. Electrical Cigarette Lighter Continuous Power
  34. Electrical Electrical Power for Radar Detector
  35. Electrical Switched 12V wire
  36. Electrical mObridge coding
  37. Electrical Increased Battery Discharge
  38. Electrical Auto lights sensitivity options
  39. Electrical Remote Controller Problem...
  40. Electrical New Mini Halo LED foglight
  41. Electrical Light Above Fog Light
  42. Electrical Fog & reverselight wiring
  43. Electrical Add options before Modules, Problem?
  44. Electrical CD changer preparation
  45. Electrical Weather band radio
  46. Electrical Using center armrest for iPod/iPhone
  47. Electrical BMW/MINI coding in So Cal
  48. Electrical Justa Cooper heartbeat
  49. Electrical Relocate Battery
  50. Electrical DME high RPM / over-rev snitch?
  51. Electrical Multifunction Steering Wheel Coding
  52. Electrical NCS Error message, help needed
  53. Electrical Need car re-coded due to aftermarket amp installation
  54. Electrical looking for a wrecked R56 with OEM driving lights,I need the wiring
  55. Electrical Data logger for knocks, afr, timing, boost & more ?
  56. Electrical Pulsar Install r56
  57. Electrical Reset Module to Default with NCS Expert?
  58. Electrical Radio Issues?
  59. Electrical LCI Taillight Schematic ????
  60. Electrical Android 4.0 and above USB music?
  61. Electrical No response to inserting the key in the dash => start button does not work
  62. Electrical Coding for new 12v battery
  63. Electrical .. WHICH Cable??
  64. Electrical Older I-levels (Accessport won't work after programing)
  65. Electrical One touch for windows
  66. Electrical MOST ring ?
  67. Electrical Can 2011 R56 tail lights work with 2010 R56?
  68. Electrical Adding a Second Back Up Light
  69. Electrical UK 2012 Mini one D - Enable OBC
  70. Electrical Map Light and Low Tire Pressure Warning
  71. Electrical FA: $2PX NCS Expert Error
  72. Electrical Random radio problems
  73. Electrical NCSExpert - Pass Air Bag Still Deploy?
  74. Electrical Dealer won't re-flash for Cruise
  75. Electrical Water temperature - codeable?
  76. Electrical LED Turn Indicators (with or without resistors?)
  77. Electrical Bulb Error Light Indication ?
  78. Electrical Anyone tried the Torque Steering Compensation?
  79. Electrical HID Mistake
  80. Electrical New battery question.
  81. Electrical i want cruise control.
  82. Electrical Convert R55 "S" Rear Fog Lights to Brake Lights
  83. Electrical AUX and Bluetooth Problems
  84. Electrical Install or not install?
  85. Electrical New Driving Lights!
  86. Electrical Change non automatic to automatic heating dashboard
  87. Electrical License Plate LED Bulb ?
  88. Electrical Can a Pre-Owned Key Fob be Re-Programmed?
  89. Electrical Retrofitting Connected and Convenience Start/Open
  90. Electrical Best or Greatest working Speed and Radar Detector
  91. Electrical Where to tap power source inside cockpit?
  92. Electrical LED License Plate Frame Back Up Lights
  93. Electrical power tender plus installation
  94. Electrical R56 Rear fog light does not work completley
  95. Electrical HID Hella Black Magics
  96. Electrical ACC connection?
  97. Electrical replaced taillight bulbs with led's
  98. Electrical V1 Threat Picture
  99. Electrical INPA Diagnostics for late model R56/R60s?
  100. Electrical NCS help!!
  101. Electrical Cruise contro default to ON using FES Auto Sport?
  102. Electrical Better sound from the HiFi stereos
  103. Electrical no power to amp
  104. Electrical Battery Maintainer
  105. Electrical High Beams and fog lights at same time
  106. Electrical Kenwood DNX9990HD Double-Din installation
  107. Electrical Programming Rear Fog Lights
  108. Electrical 05 MCS Headlight adjustment
  109. Electrical Boost Tap Install?
  110. Electrical Ultra-Gauge install in place of Openometer
  111. Electrical Trunk Interior Light?
  112. Electrical Ultragauge Coolant Temp ?
  113. Electrical Vin is Faulty Message in NCS Expert
  114. Electrical Custom ScanGauge II Mount
  115. Electrical Instructions for OEM Alarm install
  116. Electrical PDC (Backup sensor) Retrofit installation
  117. Electrical 07 R56 Battery sugestion
  118. Electrical Halogen replacement bulbs?
  119. Electrical Part numbers for OEM Alarm system?
  120. Electrical Led bulb fitment
  121. Electrical H13 HID for 2012 Mini Classic
  122. Electrical dynotuning in hawaii
  123. Electrical HIDS FOR NEWB..Qs..
  124. Electrical Electronic Oil Pressure and Boost Gauge Install
  125. Electrical Circuits on with "door open" command....
  126. Electrical Adding MFSW questions
  127. Electrical Justa with basic radio... I want bluetooth and XMsirius.. how?
  128. Electrical BlackFlame customs Retro fit
  129. Electrical RGB Ambient Mood Lighting Additions Mod
  130. Electrical Any coders near Cleveland?
  131. Electrical Coding FRM2 and Bulb Checks
  132. Electrical 2012 MCS halogen light retrofit question
  133. Electrical Interior led setup
  134. Electrical Alternator to battery power wire.
  135. Electrical Problems with INPA interface Help..
  136. Electrical CM Parking Light Issues
  137. Electrical Software to pull the DTC's
  138. Electrical HELP!! Bulbs for Mini R56?
  139. Electrical Sport Mode retrofit ? Huh? (CDN CAR)
  140. Electrical Howto: Vehicle Software Updated with minitechinfo & J2534
  141. Electrical Dash menu 14.0 engine error code A3ACh?
  142. Electrical needs help front foglight installation ASAP
  143. Electrical OBD 2 Bluetooth Error Code Scanner Tool + "Torque"
  144. Electrical How to Reset Roadworthiness Test?
  145. Electrical Enable Auto Start / Stop on US Mini HT 2011
  146. Electrical Easy auto dim mirror replacement
  147. Electrical Ham Radio Installation
  148. Electrical Unlocking Onboard Computer
  149. Electrical Need help with xenon retrofit
  150. Electrical How do you tap into the passenger fuse box
  151. Electrical Found a great NCSexpert coder in NJ/NY/CT
  152. Electrical BMW Coding Tool (Complementary to NCSExpert/WinKFP)
  153. Electrical Replacing Nav Speedo MPH to KMH and KOMBI ECU
  154. Electrical 2008 mini cooper S r56 license plates LED question
  155. Electrical Spec-D Headlights with Projectors & Halos... some pics and info
  156. Electrical Borked my KOMBI module -- Can I reload software fresh? How?
  157. Electrical gauge air fuel ratio alta performance instructions
  158. Electrical R60 coding in general
  159. Electrical Ground in interior fuse box?
  160. Electrical Coding success n an R56 and some questions
  161. Electrical Jcw shift light
  162. Electrical NCS Expert cable. Diff cable for diff yrs?
  163. Electrical Help!! turning off CDN DRL
  164. Electrical '05 Xenon swap
  165. Electrical Who made those really bright LED bulbs?
  166. Electrical NCSExpert Help in Columbus?
  167. Electrical What options for Rear Fogs? Let's make a list
  168. Electrical Overhead console wiring schematic?
  169. Electrical Anyone run NCS Expert on 64-bit Win7?
  170. Electrical Radar Detector Mount and Hardwire
  171. Electrical NCSExpert - Little help please! 2011 R56 S
  172. Electrical Want Sequential Blinking LED Repeaters
  173. Electrical Where is the RDC(TPMS) module?
  174. Electrical Want Goodwood black switches
  175. Electrical r56 halogen halogen swap for xenon
  176. Electrical Coded w NCSExpert a 2009+ MINI? Tell me cable source!
  177. Electrical BC Board Computer Retrofit on R60, Help!
  178. Electrical Download ECU File with OBD II
  179. Electrical looking for two pair of Amp connectors 2-968407-2
  180. Electrical Any downside to adding driving lights with no switch?
  181. Electrical Shift light kit
  182. Electrical Connecting a sub to factory Nav unit?
  183. Electrical 2012 Turn signal bulbs / two different bulbs!
  184. Electrical pulsar doesn't pulse...
  185. Electrical LED Daytime Running Lights mod
  186. Electrical Stereo, 2009 MCS. Need some help.
  187. Electrical Has anyone upgraded from OEM HID to 55w HID?
  188. Electrical HELP with auto up passenger window and NCSExpert!!
  189. Electrical HID Retrofit SUCCESS -- 2012 Cooper S
  190. Electrical Is it possible to swap??
  191. Electrical Oracle HOD Bulbs
  192. Electrical Rear pdc retrofit with visual boost?
  193. Electrical Pic of back of headlights???
  194. Electrical NCS Experts in the Tri State?
  195. Electrical Panic Mode activation help!!
  196. Electrical The rear fog lights as brake lights
  197. Electrical T10 LED bulb recommendation
  198. Electrical Driving Light Bulb Replacement
  199. Electrical Resetting a module to factory default using NCSexpert
  200. Electrical OEM Style Driving Lights for Less Installed (Wipac)
  201. Electrical Installing a boost gauge, opinions???
  202. Electrical Who has tried the Xenon Retrofit and failed??
  203. Electrical Wiring Driving Lights with Xenons
  204. Electrical Troubleshooting NCSExpert getting no response from ECU
  205. Electrical Blackout Retrofit Parts Starting to Be Listed by Sewell
  206. Electrical DSC inactive- why?
  207. Electrical How do you like your $259 LED DEPO tails?
  208. Electrical If I installed a 55w resistor in a circuit, will it half the output of a 55w bulb?
  209. Electrical R56 MOST Diagnostic Port
  210. Electrical Angel Eyes- Fog light hook up question
  211. Electrical Rear Fog Light Switch Plate and Toggle Switch Install
  212. Electrical Headlamps module
  213. Electrical Conveneince package not so convenient
  214. Electrical OBDII to Bluetooth
  215. Electrical Driver Window Malfunction
  216. Electrical 2012 mc hardtop hardwire garmin gps
  217. Electrical Head light bulb change? Good choice or bad?
  218. Electrical Outlaw pushbutton-start?
  219. Electrical LEDs (tail, turn) without coding (brief report)
  220. Electrical Independent Control of Rally Lights.
  221. Electrical Getting temp from OBD II and programming ECU
  222. Electrical I am looking to install Bluetooth
  223. Electrical Odd question....
  224. Electrical 2012 R56 Cooper S Lights
  225. Electrical OEM Driving light wiring kit
  226. Electrical Reverse lights always on - 2007 Mini Cooper (base)
  227. Electrical Empty Fuse - ie Seat Heater Fuse
  228. Electrical Running electrical wire from engine to dash
  229. Electrical Best Driving Light after market????
  230. Electrical Any concerns about unplugging Footwell module?
  231. Electrical troubleshooting power lock system
  232. Electrical How to turn off tire pressure light NCS Expert
  233. Electrical Headlight bulbs
  234. Electrical clubman reverse light not working...what to look for?
  235. Electrical Another HELLA 500 Install Q....
  236. Electrical HID Recommendation? Need new bulbs
  237. Electrical Headlight compatibility and retrofit for 2011 MCS
  238. Electrical How to feed USB cable to dash
  239. Electrical iPhone + Cravenspeed Mount + Rev App + PLX KiWi OBDII WiFi adaptor = Slick
  240. Electrical Issues with higher wattage halogens???
  241. Electrical Headlights issue...one randomly won't come on then...
  242. Electrical Mod mood lighting
  243. Electrical Built into the grill driving lights; Mustang style?
  244. Electrical Prosport Gauge Help Needed...
  245. Electrical Blue tooth CK3000 EVO with CTPPAR008
  246. Electrical hella 500 install/ wiring...
  247. Electrical Wiper Covers Flush?,
  248. Electrical Wiper Covers Flush?,
  249. Electrical 1,2 & 4 Misfire at the same time?
  250. Electrical Spiderlite LED bulbs
