Electrical Light Above Fog Light
Old Apr 19, 2013 | 05:44 PM
JoAhJoAh's Avatar
JoAhJoAh
hi guys
my light above the fog went out...
i have leds in them but i thought they just went bad so i bought another bulb
but still the same thing...
so i got a volt meter and checked if there was power but i get .003V...
the other side has 12.37V... i checked the socket and the connector same result
is there a fuse for just that light or do i have a bad connector since there is no power coming out of it????
any help would be great.
thanks
Old Apr 19, 2013 | 10:04 PM
Chernobyl's Avatar
Chernobyl
This is not good. The lights are not individually fused. There are only two large fuses (F47 and F48, both 40 amp) that take care of most lights. If only one socket is getting power then there is a problem with either the: wiring, socket, or (gulp) the FRM module that controls the lights. Do you get a bulb-out notification when there is nothing in the socket? You should.
Here is a snippet of the wiring diagram that shows how each light is supplied separately:
Old May 18, 2013 | 08:41 AM
JoAhJoAh's Avatar
JoAhJoAh
ok finally went to dealer so they can look at it
they said that after putting the leds, the leds put a fault in the frm
the parking light works now but they say it may go out again
my reverse and turn signals flicker at start up but the parking dont
anything i can do to prevent this from happening???
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
