Electrical Issues with higher wattage halogens???
Old Jan 20, 2012 | 08:42 AM
PhilV89's Avatar
PhilV89
I was thinking of putting in higher wattage halogen bulbs in my mini, and was wondering if I would encounter any issues by doing so. Does anyone have any experience with this? As much as I would like Xenons, it's not in my budget, so some new bulbs might be what I am after. Thanks in advance for any suggestions.
Old Jan 20, 2012 | 09:56 AM
yetti96's Avatar
yetti96
I would look into better, whiter bulbs and not ones that are of a higher wattage...thus pulling more amps, adding more load than originally intended to the electrical system.
Old Jan 23, 2012 | 05:18 AM
schatzy62's Avatar
schatzy62
Yes the MINI lighting system is rather fragile when it comes to putting in higher wattage bulbs. It is based on what the OEM spec is and if more current is drawn can do some crazy things. And the wiring can burn or melt with higher wattage bulbs.
Old Feb 17, 2012 | 10:17 AM
ishlara's Avatar
ishlara
Melted both my headlights with higher watt bulbs, lucky they replaced them with a warning not to try doing it again! Car was only a month old!
Old Feb 17, 2012 | 10:31 AM
PhilV89's Avatar
PhilV89
Good to know. I was still contemplating the higher wattage bulbs, but with one of those heavy duty plug adaptors that are guaranteed not to melt the plug. But that doesn't help if the housing is melting. Hiw are those Sylvanias working for you? Better light output than the stock halogens? Any pictures?
Old Feb 19, 2012 | 02:06 PM
Darryl_J's Avatar
Darryl_J
I was really unhappy with my low-beam lighting, and was considering something like the PIAA or Sylvania bulbs.
But then I did a simple check on the way the lights were aimed and discovered that both lights were more than 2" too low from where they should be. Once I corrected that, I'm a lot happier about night driving.
I may still try out alternate bulbs, but I have to say that I was warned by two different dealers that the aftermarket bulbs have very short lifespans. I was told, for example, that I should expect the have to replace the PIAA bulbs at least once a year!
I sold my last car at just over 10 1/2 years of age -- with the original bulbs. It wasn't a MINI, so I can't say how long the stock MINI bulbs can be expect to last; but I would certainly expect more than a few years out of them.
Given the cost of the aftermarket bulbs, it's something to think about...
Darryl
Old Apr 30, 2012 | 09:08 AM
Dozuki01's Avatar
Dozuki01
Darryl
I used to have to replace the PIAA GTX bulb on my BMW once a year. I installed the HID conversion and has been very happy with it since.
Old Apr 30, 2012 | 10:28 AM
quikmni's Avatar
quikmni
What wattage are you thinking of?
I little higher wattage will not be a problem, but much higher wattage (such as 100W) can be a problem due to heat melting plastic parts and higher current melting the wire.
Alkaidovich
Jan 30, 2021 01:35 AM
woodstudio
Mar 15, 2020 08:28 AM
maestro39
Oct 27, 2015 02:38 PM
Inziladun
Sep 3, 2015 10:35 AM
ASRman
Aug 13, 2015 09:33 AM
