Electrical If I installed a 55w resistor in a circuit, will it half the output of a 55w bulb?
Old Mar 31, 2012 | 04:24 PM
JPMM's Avatar
JPMM
Hi,If I installed a 55w resistor in a circuit, will it half the light output of a 55w bulb?
Old Mar 31, 2012 | 05:51 PM
cristo's Avatar
cristo
Alliance Member
How many ohms is the 55w resistor, what kind of circuit, and do you mean a 12V 55w bulb
like a headlight bulb?
Anyway, the short answer is no.
Old Mar 31, 2012 | 06:04 PM
daflake's Avatar
daflake
As Cristo stated it will not do that.
http://en.wikipedia.org/wiki/Resisto...llel_resistors
Here is a good read...
Old Mar 31, 2012 | 06:19 PM
cristo's Avatar
cristo
Alliance Member
Longer answer, ... if you used a resistor with the same resistance that a 55W bulb has at 13.6 Volts (about 3.4 ohms)
and put in in series with the bulb, the voltage drop across the bulb would be 6.8 V, the current would be 1/2 what
you had before, and the power (voltage x current) would be about 1/4 of 55W or 13.75W.
But, ... the bulb will have a lower resistance when running at that lower voltage (cooler filament), so you'd have
a lower voltage drop across the bulb than the resistor, and you'd get even less output, and the light output per
watt (efficiency) of the bulb would drop quite a bit, so even less light output, and the color temperature would
drop as well, so you'd get a dim, orangy light from the bulb.
You'd get something closer to 1/2 the light output from the bulb in series with a resistor about 0.8 to 0.9 ohm.
Old Mar 31, 2012 | 06:29 PM
rkw's Avatar
rkw
What is your goal? If you install a resistor to halve the output, be careful where you mount it, because the resistor will get very hot (as hot as a light bulb).
If you want lower output, install a lower wattage and/or different type of bulb. Wattage is not linearly proportional to light output (lumens) and will depend on the type of bulb, so there isn't a simple formula to follow.
Old Mar 31, 2012 | 07:18 PM
JPMM's Avatar
JPMM
Maybe I could use a resistor from a daytime running light circuit. They have cages around them . I would like a set of 55w lights to run at half brightness, sometimes. How bright would 55w bulbs be run in series?
Old Mar 31, 2012 | 10:27 PM
rkw's Avatar
rkw
That would be a good start. If it's a pair of lights, connect them together in series on the same circuit. It's hard to say how bright it would be. Each bulb will receive half the power but that doesn't necessarily translate into half brightness. Different bulbs will respond differently to varying amounts of power.
Old Mar 31, 2012 | 11:08 PM
JPMM's Avatar
JPMM
looks like some bench testing is in order
Old Apr 1, 2012 | 04:57 AM
cristo's Avatar
cristo
Alliance Member
In this case you'd have 1/4 the power (1/2 the voltage and 1/2 the current)
and considerably less than 1/4 the brightness since you'd be running
the bulbs at about 6.5-7 volts each depending on your alternator output.
Old Apr 1, 2012 | 05:40 AM
JPMM's Avatar
JPMM
so there is no good way of dimming the bulbs?
Old Apr 1, 2012 | 07:47 AM
cristo's Avatar
cristo
Alliance Member
Well, as stated earlier, a 25 or 50 watt 0.85-ish ohm resistor in series with the bulb,
mounted in a way to dissapate heat, would probably work.
I also wonder, can the dealer activate DRL on your car?
Some cars have DRL capability, which can be turned on or off by the factory or dealer
depending on the target market or preference. Daylight Running Lights usually run at
slightly lower voltage and brightness than regular headlight mode.
Is the MINI one of these cars?
Here's a starting point: https://www.northamericanmotoring.co...on-a-mini.html
Old Apr 1, 2012 | 04:41 PM
JPMM's Avatar
JPMM
I tried a bench test,I found running the bulbs in series works well,the dimming is just about right, now I need to get creative with some relays and diodes.
(I'm not trying to run the headlights dimmer)
Old Apr 1, 2012 | 08:54 PM
ammodave's Avatar
ammodave
Have you considered lightly over spraying the bulbs with silver paint to reduce the light output? Alternatively you might be able to find a lower wattage bulb with the same base online.
Old Apr 1, 2012 | 11:15 PM
JPMM's Avatar
JPMM
Hi, I'm being kind of cagey , sorry about that. But I want to run a set of single filament 55watt bulbs at full power and at half power at will.
Old Apr 2, 2012 | 07:44 AM
ammodave's Avatar
ammodave
Sounds like an interesting project; if you figure this out please post the solution for those of us who are electron challenged.
Old Apr 2, 2012 | 12:49 PM
JPMM's Avatar
JPMM
got it figured out, now I need to buy some relays and such then do some bench testing
Old Apr 16, 2012 | 03:01 AM
JPMM's Avatar
JPMM
had a successful proof of concept today
now I need to find male and female OEM Mini wiring connectors to make non intrusive T splices. I need connectors to splice into the driving light's harness and the fog lights.
adrchn
Aug 13, 2019 02:11 AM
FLYM1N1
Mar 7, 2016 05:41 PM
squawSkiBum
Oct 2, 2015 09:21 AM
AZN Optics
Accessory Products
Aug 21, 2015 02:03 PM
