Electrical Cruise Control Speed Display???
Old May 16, 2013 | 11:06 AM
alexs3d2's Avatar
alexs3d2
Anyone know the setting which enables the cruise control speed to display in the tacho? I have seen in the 2009 MINI manual that such a function is available, but my 2007 doesn't have it.
Since I already have v46 data flashed on the unit, I would presume this to be a possible setting in the NCS. Anyone spotted such a setting? On a side note, my car has the CCC Nav and I don't know if that changes the functionality.
Old May 16, 2013 | 09:38 PM
Chernobyl's Avatar
Chernobyl
Can you provide a TRC file from your KOMBI for comparison? I seem to recall a setting for this somewhere in there.
Incidentally I updated my KOMBI firmware to V46.3 using WINKFP recently and the cruise control symbol changed a bit. No big deal, but curious nonetheless.
Old May 17, 2013 | 08:46 AM
alexs3d2's Avatar
alexs3d2
OK... This is the TRC from the KOMBI. I have updated the KOMBI to v46 status, so it should be in the software.
I believe the setting should be "TEMPOMAT_SETZ_ANZ_DAUER" which can either be "WERT_01" or "WERT_02" (thanks ncsdumy) but will test and see. If you have ideas please post!
CC_ID_AKTIV_01
wert_01
CC_ID_AKTIV_05
wert_02
CC_ID_AKTIV_07
wert_01
CC_ID_AKTIV_14
wert_01
SOUND_SWITCH
aktiv
CSUM_KODIERUNG_VALID
grundcode_var
FDC_VERBAUT
nicht_aktiv
SHOW_CC_MSG_NR
nicht_aktiv
CODING_VALID_BMW
wert_01
DATEN_INDEX
grundcode_var
TCM_ID_MONITOR
nicht_aktiv
CC_NR_ROLLE
aktiv
TCM_ALIVE_MONITOR
nicht_aktiv
DSC_ID_MONITOR
aktiv
AUSSENTEMP_SPERR_OFFSET
wert_01
MOTORKONSTANTE
wert_01
ARS_ID_MONITOR
nicht_aktiv
DISP_ENGDAT_ID_MONITOR
nicht_aktiv
AUSSENTEMP_ANZ_FEHLER_1
wert_01
AUSSENTEMP_ANZ_FEHLER_2
wert_01
AUSSENTEMP_DELTA_K1
wert_01
TANK_RED_REICHWEITE
wert_01
AUSSENTEMP_DELTA_K2
wert_01
AUSSENTEMP_ZEITKONST_Z1
wert_01
AUSSENTEMP_ZEITKONST_Z2
wert_01
DME_ID_MONITOR
aktiv
AUSSENTEMP_ZEITKONST_Z3
wert_01
AUSSENTEMP_ZEITKONST_Z4
wert_01
AUSSENTEMP_ZEITKONST_Z5
wert_01
TANK_OHM_FEHLER_UG
wert_01
AUSSENTEMP_ZEITKONST_Z6
wert_01
AUSSENTEMP_SPERR_FAKTOR
wert_01
TANK_OHM_FEHLER_OG
wert_01
DISP_TEMP_LEVEL
wert_01
TANK_MITTLUNGSZEIT
wert_01
TANK_SICHERHEITSFAKTOR
wert_01
TANK_BERUHIGUNGSZEIT
wert_01
ZGM_ID_MONITOR
aktiv
LEHNE_FA_ID_MONITOR
nicht_aktiv
LEHNE_BF_ID_MONITOR
nicht_aktiv
ACC_CSUM_MONITOR
nicht_aktiv
AFS_ALIVE_ZAEHLER
nicht_aktiv
SFY_ALIVE_ZAEHLER
aktiv
LEHNE_FA_ALIVE_ZAEHLER
nicht_aktiv
LEHNE_BF_ALIVE_ZAEHLER
nicht_aktiv
DME_ALIVE_ZAEHLER
aktiv
SFY_ID_MONITOR
aktiv
AFS_ID_MONITOR
nicht_aktiv
ACC_ID_MONITOR
nicht_aktiv
EHC_ALIVE
nicht_aktiv
CAS_ALIVE
aktiv
ZGM_ALIVE_ZAEHLER
aktiv
HDC_ID_MONITOR
nicht_aktiv
DSC_ALIVE_ZAEHLER
aktiv
ARS_ALIVE_ZAEHLER
nicht_aktiv
ACC_ALIVE_ZAEHLER
nicht_aktiv
LM_ALIVE
aktiv
CC_15_AUS
wert_01
CC_R_EIN
wert_01
TIMEOUT_1
wert_01
TIMEOUT_2
wert_01
CC_R_AUS
wert_01
CC_ML
wert_01
PREDRIVE_PERIODENDAUER
wert_01
MONITOR_SPEED_SENSOR
aktiv
BC_DIGITAL_V
aktiv
BC_V_KORREKTUR
aktiv
PREDRIVE_ABB_MOT
nicht_aktiv
CC_BLINKFREQUENZ_SCHNELL
wert_01
BC_DIGITAL_V_KORREKTUR
aktiv
PREDRIVE_START_MIT_OBD
aktiv
CC_BLINKFREQUENZ_LANGSAM
wert_01
DISP_ENGDAT_ALIVE_ZAEHLER
nicht_aktiv
CRASH_TH_DIMMUNG
wert_01
CC_EHH_ANZ_MIN_TIME
wert_01
DIG_TACHO_SWITCH_TIME
wert_01
ZV_VER_FAHRT_ZEIT
aktiv
HEIMLEUCHTEN_AUS
aktiv
HEIMLEUCHTEN_10S
aktiv
HEIMLEUCHTEN_40S
aktiv
FB_FA_TUER
aktiv
HEIMLEUCHTEN_90S
aktiv
HEIMLEUCHTEN_150S
aktiv
HEIMLEUCHTEN_240S
aktiv
FB_ALLE_TUEREN
aktiv
QUITT_OPT_ENT
aktiv
OHNE_QUITT_ENT
aktiv
QUITT_OPT_VER
aktiv
ZV_VER_AUS
aktiv
OHNE_QUITT_VER
aktiv
TIPP_BLINKEN_3X
aktiv
TIPP_BLINKEN_1X
aktiv
TANK_SCHWELLE_RESERVE
wert_01
TANK_RW_WARNUNG
wert_01
CBS_STAT_01H
anzeige
MMI_ENA_UHR_DATUM
aktiv
DIG_SPEED_PERMANENT
nicht_aktiv
CBS_INTD_11H
wert_01
AHM_ALIVE
nicht_aktiv
K_ZAHL_TACHO
wert_01
K_ZAHL_TACHO_KOMPL
wert_01
K_ZAHL_WEG
wert_01
K_ZAHL_WEG_KOMPL
wert_01
CBS_RES_SPERR
wert_01
CBS_GELB_KM_MIN
wert_01
CBS_GELB_HUAU
wert_01
ZV_VER_FAHRT
aktiv
CBS_GELB
wert_01
CBS_EINH_10H
wegbas
CBS_INTW_12H
wert_01
ZV_VER_ZEIT
aktiv
CBS_EINH_12H
wegbas
CBS_STAT_12H
sperre
CBS_SCEN_12H
nicht_aktiv
CBS_EINH_04H
wegzeit
CBS_INTD_03H
wert_01
CBS_EINH_03H
zeitbas
CBS_STAT_03H
anzeige
DZM_DISP_RPM
wert_01
CBS_SCEN_03H
nicht_aktiv
CBS_SCEN_04H
nicht_aktiv
CBS_INTD_14H
wert_01
CBS_SCEN_01H
nicht_aktiv
CBS_EINH_14H
zeitbas
CBS_STAT_14H
sperre
CBS_SCEN_14H
nicht_aktiv
CBS_EINH_11H
wegzeit
CBS_STAT_11H
anzeige
CBS_EINH_01H
wegzeit
EPS_ALIVE_MONITOR
aktiv
EPS_ID_MONITOR
aktiv
CBS_SCEN_11H
nicht_aktiv
CBS_EINH_20H
zeitbas
CBS_STAT_20H
anzeige
CBS_SCEN_07H
nicht_aktiv
CBS_SCEN_20H
nicht_aktiv
CBS_EINH_21H
zeitbas
CBS_EINH_07H
wegbas
CBS_SCEN_10H
nicht_aktiv
CBS_SCEN_21H
nicht_aktiv
CBS_EINH_02H
wegbas
CBS_STAT_02H
anzeige
CBS_SCEN_06H
nicht_aktiv
CBS_SCEN_02H
nicht_aktiv
CBS_EINH_06H
wegbas
CBS_STAT_06H
anzeige
SCHALT_PKT_DAUERHAFT
nicht_aktiv
CBS_SCEN_16H
nicht_aktiv
CBS_INTD_15H
wert_01
CBS_EINH_15H
zeitbas
MONITOR_NAV_SPEED_CALIBR
aktiv
CBS_AVKM_START
wert_01
CBS_TZ_SCHALTER
borddatum
CBS_STAT_15H
sperre
CBS_SCEN_15H
nicht_aktiv
RDC_DISP_SWITCH
aktiv
DZM_DAEMPFUNG
aktiv
CBS_STAT_10H
sperre
CBS_STAT_07H
sperre
CBS_EINH_16H
wegbas
CBS_STAT_04H
sperre
TYP_LENKUNG
rechtslenker
CC_15_EIN
wert_01
EKP_ALIVE_ZAEHLER
nicht_aktiv
EKP_ID_MONITOR
nicht_aktiv
TNK_RW_VERBRAUCH
wert_02
TANK_SCHWELLE_AUF/AB
wert_02
CBS_STAT_16H
sperre
CBS_INTW_11H
wert_01
wert_03
TANK
wert_01
TANK_VOLL_ERKENNUNG
wert_01
TNK_LITER_LINKS
wert_01
TNK_OHM_LINKS
wert_01
TNK_LITER_RECHTS
wert_01
TNK_OHM_RECHTS
wert_01
CC_ID_AKTIV_11
wert_01
K4116_C_TEMPERATUR_1
wert_01
K4116_C_TEMPERATUR_2
wert_01
K4116_C_TEMPERATUR_3
wert_01
K4116_C_TEMPERATUR_4
wert_01
K4116_D_TEMPERATUR
wert_01
CC_ZUENDSCHLUESSEL
nicht_aktiv
CBS_INTW_10H
wert_01
GURT_ID_MONITOR
aktiv
CBS_STAT_21H
sperre
WARNUNG_GESCHW_LIMIT
nicht_aktiv
K430C_C_DATUM_1
wert_02
K4113_C_ZEIT_1
wert_02
K430C_C_DATUM_2
wert_02
K4113_D_ZEIT
wert_02
K4113_C_ZEIT_2
wert_02
K430C_C_DATUM_3
wert_02
K4113_C_ZEIT_3
wert_02
K430C_C_DATUM_4
wert_02
K4113_C_ZEIT_4
wert_02
K430C_D_DATUM
wert_02
K4110_C_VERBRAUCH_1
wert_01
K4110_C_VERBRAUCH_2
wert_01
K4110_C_VERBRAUCH_3
wert_01
K4110_C_VERBRAUCH_4
wert_01
K4110_D_VERBRAUCH
wert_01
K4119_C_DRUCK_1
wert_01
K4119_C_DRUCK_2
wert_01
K4119_C_DRUCK_3
wert_01
K4119_C_DRUCK_4
wert_01
K4119_D_DRUCK
wert_01
QUITT_AKUST_ENT
nicht_aktiv
QUITT_OPT_AKUST_ENT
nicht_aktiv
QUITT_AKUST_VER
nicht_aktiv
QUITT_OPT_AKUST_VER
nicht_aktiv
GETRIEBE_TYP_KOMBI
automatik
EGS_ALIVE_ZAEHLER
aktiv
EGS_ID_MONITOR
aktiv
EGS_CSUM_MONITOR
aktiv
GEAR_SHIFT_ALIVE
nicht_aktiv
GEAR_SHIFT_ID_MONITOR
nicht_aktiv
GEAR_SHIFT_CSUM
nicht_aktiv
DWA_VERBAUT
aktiv
WIPER_STAT_DISP
wert_01
MMI_ENA_RPA_RDC
nicht_aktiv
MMI_ENA_PIA
nicht_aktiv
SHOW_OEL_STAND
nicht_aktiv
CC_TEMPERATURWARNUNG
nicht_aktiv
BC_2_ENABLE
aktiv
GPS_UHR
aktiv
TANK_FILTER_STEIGEND
wert_01
TANK_FILTER_FALLEND
wert_01
DSC_VARIANT
wert_01
SP_ANZEIGE_1
wert_02
SP_ANZEIGE_2
wert_02
SP_ANZEIGE_3
wert_02
SP_ANZEIGE_4
wert_02
SP_ANZEIGE
wert_02
RDC_VERBAUT
nicht_aktiv
RDC_ALIVE
nicht_aktiv
DSC_MIT_RPA_CC
nicht_aktiv
HU_VERBAUT
radiostufe_3_4
K4310_C_SPRACHE_1
wert_02
K4310_C_SPRACHE_2
wert_02
K4310_C_SPRACHE_3
wert_02
K4310_C_SPRACHE_4
wert_02
K4310_D_SPRACHE
wert_02
K410D_C_WEG_1
wert_01
K410D_C_WEG_2
wert_01
K410D_C_WEG_3
wert_01
K410D_C_WEG_4
wert_01
K410D_D_WEG
wert_01
BC_1_ENABLE
aktiv
SCHALT_PKT_BC
nicht_aktiv
AO_ENABLE
nicht_aktiv
AO_OVERFANI_ENABLE
nicht_aktiv
AO_OPENANI_ENABLE
nicht_aktiv
AO_STARTANI_ENABLE
nicht_aktiv
AO_CLOSED_ENABLE
aktiv
AO_DISP_TIME
wert_01
AO_OVERF_FREQU
wert_01
AO_POINTER_SPEED
wert_01
DSC_ASC_CC
aktiv
TAG_LICHT_AN
nicht_aktiv
TAG_LICHT_AUS
nicht_aktiv
KL_PREDRIVE_AUSWAHL
wert_02
wert_01
ACC_AUSSTATTUNG
wert_01
MSA_SWITCH_ON_OFF_ENABLE
nicht_aktiv
MSA_ID_MONITOR
nicht_aktiv
MSA_CSUM_MONITOR
nicht_aktiv
MSA_ALIVE_MONITOR
nicht_aktiv
MSA_ENABLE
wert_02
VEH_MOD_ID_MONITOR
nicht_aktiv
VEH_MOD_CSUM_MONITOR
nicht_aktiv
VEH_MOD_ALIVE_MONITOR
nicht_aktiv
SPORT_ANZEIGEDAUER
wert_01
RAIN_SENSOR_ID_MONITOR
nicht_aktiv
RAIN_SENSOR_MENU_ENA
nicht_aktiv
CVM_ALIVE_ZAEHLER
nicht_aktiv
CVM_ID_MONITOR
nicht_aktiv
DIMMUNG_ADJ
wert_01
HKFM_ALIVE_ZAEHLER
nicht_aktiv
HKFM_ID_MONITOR
nicht_aktiv
ATEMP_WAKEUP
wert_02
BC_1_TIME
wert_01
Old May 17, 2013 | 08:10 PM
Chernobyl's Avatar
Chernobyl
Yup, it is almost certainly the TEMPOMAT_SETZ_ANZ_DAUER ("Cruise Set Time Display") setting. In your car it is wert_01 which is 0 seconds and in my car it is wert_02 which is 8 seconds.
There are many, many other differences between our KOMBI codings. Among other things you're right-hand drive, automatic, with NAV, no rain-light sensor and no Sport button and I'm left-hand drive, manual, no NAV, have rain-light sensor and have the Sport button.
Old May 17, 2013 | 11:35 PM
alexs3d2's Avatar
alexs3d2
Actually I do have the sport button. What is different, is that by default it didn't show up in the tacho when pressed. Both settings have production week criteria PU07 in both cases. My car was built in 0307 so MAERZ07 which does not satisfy the time criteria for those two values. I will change the build order to reflect 0907 so PU07 as time criteria which would code both values by default to show up (WERT_02).
Old May 18, 2013 | 02:58 AM
alexs3d2's Avatar
alexs3d2
UPDATE: I did as said, changed the manufacturing date to a later one to make it default to Wert_02. While it does now default to Wert_02 when coding, it doesn't show me the pre-set speed or anything on the display:( The sport button does show up now when pressed.
Any other ideas? Could other modules be involved?
Old May 26, 2013 | 02:36 AM
alexs3d2's Avatar
alexs3d2
OK... Perhaps someone can shed some more light on this:
After quite some time reading the coding files in NCSDummy, I realized that the Cruise Control display setting shares its memory address with the Gearbox Type option.
I was wondering whether that could be the culprit, so would be good to know if somebody out there has the AUTOMATIC gearbox AND the cruise control speed shows on the tacho. If so please post so that I know. Thanks!!
Old Jun 21, 2015 | 05:36 PM
justawatcher's Avatar
justawatcher
I do and it does.. now.. ('08 and '09 justas w/automatics)
KOMBI module..
wert_02
ACC_AUSSTATTUNG
wert_01
theblackfalcon
Oct 11, 2015 09:49 AM
Tweedbean
Sep 4, 2015 05:37 PM
caiken
Aug 27, 2015 06:55 AM
PatrikKN
Aug 5, 2015 09:10 PM
