Electrical New battery question.
Old Jan 17, 2013 | 06:46 PM
OreoSAll4's Avatar
OreoSAll4
i just got a call from the dealership and they told me my battery is at the end of its legs, specially with the cold weather. slow to start. is there a more cost efficient way of buying a new battery? sales rep on the phone told me out the door its about $300. something im going to need to plan out and save for.
Old Jan 17, 2013 | 06:50 PM
jkapinos's Avatar
jkapinos
Just sold my 2013 battery for $70 dollars. The one I replaced it with was $150.
Old Jan 17, 2013 | 06:52 PM
Braminator's Avatar
Braminator
Goto advanced auto parts they should have it for under 150 and install it for free
Old Jan 17, 2013 | 07:25 PM
ZippyNH's Avatar
ZippyNH
If you need to "plan for" a $300 mx expense, i would hate to see a true emergency....
but to be honest, no real reason to spend $300 on an oem battery imo.
The height o gen2 batteries can be an issue in getting aftermarket ones fit, but i can say 100% that my local mini guy HAS found some that DO fit fine through trial and error....so it can be done.
Old Jan 17, 2013 | 09:16 PM
OreoSAll4's Avatar
OreoSAll4
no need to worry about me with emergencies. all that is fine. its just another expense put infront of my face. but anyways, the sales guy told me theres programming involved when replacing a mini battery.
Originally Posted by Todd from MINI of Marin
the mechanic has to tell the car that a new battery is being put in because right now the car sees the battery is getting weaker so it makes the alternator compensate. and if a new battery is put in, the car will still act like the battery is dying and actually fry the battery and alternator.
i have no experience with newer cars, specially a mini cooper as this is my first one. so im a bit slow learning how to go about doing things with this car.
Old Jan 17, 2013 | 11:11 PM
Fly'n Brick's Avatar
Fly'n Brick
Repalced the battery a week ago at O'Reiliys for $145. The guy came out in the parking lot and took care of it. The only thing I had to reset was the clock.
Replacing a battery is standard maintenance like tires and oil filters. It ain't rocket surgery.
Old Jan 17, 2013 | 11:41 PM
Porthos's Avatar
Porthos
For $300 you can get a Braille battery for half of that and it will weigh half of what the stock battery does.
This is the one I have.
http://www.braillebattery.com/index....atteries/b2317
Old Jan 18, 2013 | 10:52 AM
alexs3d2's Avatar
alexs3d2
The stock battery is of DIN type (2 lifting handles and breather hole), L=278mm W=175mm H=190mm.
I changed mine two days ago with a Delkor 57539 rated at 75Ah, which is stronger than the factory OEM 70Ah unit. It also is only 175mm tall, so it fits nicely and is easier to place than the original one.
As I am at the other end of the world, pricing wouldn't be relevant to you, but just for the sake of it I was able to get it for 105€.
If you have an OBD tool, then also reset your DME to know the new battery is there.
PS: If your car has START-STOP then you need an expensive AGM battery.
Old Jan 18, 2013 | 05:09 PM
OreoSAll4's Avatar
OreoSAll4
ok so that means the rep was right about resetting something. but i dont see how it would cost 300 out the door. thanks for all the info guys!! will any OBD tool work? even the cheapo HF one?
Old Jan 19, 2013 | 12:59 AM
alexs3d2's Avatar
alexs3d2
That I dont know... But what I use is an INPA cable and BMW factory software (INPA, NCS).
Alternative is a J2534 tool which allows you to connect to the mini tech site, but that could be expensive.
Really, if your car isnt acting strange with the old battery, you dont need to reset anything. Resetting simply removes measures to conserve a weak battery. But even then, the car would know after a couple of starts that the battery is ok and function properly.
Old Jan 21, 2013 | 07:24 PM
OreoSAll4's Avatar
OreoSAll4
the only thing strange is the slow engine turn over in the beginning.
wildwestrider
11
Jan 29, 2016 05:06 PM
SJ-R50
Oct 28, 2015 08:39 AM
schr5530
Oct 5, 2015 08:28 AM
MiniSMan
Sep 29, 2015 06:38 PM
jennster
Sep 28, 2015 06:19 PM
