Electrical Hardwire GPS with auto on Sport button mod using fuse 32
I did the auto on sport button mod. Its connected to fuse 32. Now I want to hardwire my GPS using a female lighter plug adapter:
http://www.partsexpress.com/pe/showd...number=265-570.
Like what lacning74 did.
What fuse can I connect the cigarette lighter plug adapter to so that I get power when the car is started and turns off when the car is turned off? Can I also connect it to fuse 32? Will that cause any problems?
For your first question, you can get something "splice free" that Mike from newministuff.com has to offer: http://www.newministuff.com/new/shop...uctshow&id=472
For your second question, I've done the sport button mod and my V1 detector both tapped into #32 via a Bussman add a circuit fuse tap. Works great since #32 is set so that when the ignition cuts off so does the power. Good luck and enjoy your new MINI
-Oly
-Oly
siriuszero
Sep 17, 2015 04:41 AM
