Electrical trying to hook up boost gauge need help
Old Aug 8, 2010 | 09:15 AM
MCS09's Avatar
MCS09
i have searched the forums even before i tried to hook it up, now i am no electrician but this isnt rocket science. i purchased a prosport digital boost gauge. the wires consist of
red=12v power
black=ground
green= to sender
yellow=accessory power
i ran the wires, now the sender was not connected to anything but could not get the gauge to even turn on. i attached the red to the cig lighter, red with black stripe yellow dots, and the black also to cig lighter brown. i found the accessorry wire behind the a-pillar grey/red i think it was. i turned the car on got nothing, turned on just to accesory got nothing, can somone help me or have any pictures of how they attached the wireing? i am more of a visual person. anything would help.
thanx
Old Aug 8, 2010 | 09:35 AM
HRM's Avatar
HRM
red should be a constant power source and yellow tells it when to turn on. Make sure you have a yellow that is switched. Also, finding a good ground inside isn't always easy with all the plastic in cars. Make sure the ground is good with a test light.
Without the car running, it should read zero. No boost, no vaccum.
I think the cigarette lighter is switched and should have a good ground too if you don't want to go into the fuse panel.
Old Aug 9, 2010 | 08:55 AM
Bigprfed22's Avatar
Bigprfed22
extremely simple, Green goes to gauge, red and white to power(orange coming form the cig lighter) black to ground(brown from cig lighter) , orange to light switch(gray from dtc-dsc). I might switch the orange light switch wire to go elsewhere because i like my gauges as dim as possible and you need 12v to trigger the red light switch in the gauge
Apr 7, 2020 06:49 PM
dinomaniac
Sep 18, 2018 04:19 AM
Oct 19, 2015 08:07 PM
molala
Oct 2, 2015 01:53 PM
gzaos
Sep 14, 2015 04:21 AM
