Electrical Installing MFSW and Cruise
Old Jun 2, 2011 | 02:05 PM
jacknk's Avatar
jacknk
I bought an 08 Cooper S without cruise. I couldn't believe that cruise was not standard. The dealer has a retrofit but it is expensive. My solution was that I found an 07 Cooper in a salvage yard with cruise. I bought the steering column along with the steering wheel at a very reasonable price.
I tried to get it to work by just changing the steering wheel but it would not program on the dealers computer. I then changed the switch that the SW plugs into (behind the steering wheel) and it programmed without a problem.
One more thing the car I took the SW from was an automatic, with paddle shifters. The paddle shifters can be removed easily, the only thing you have to do is jumper the two wires on the bottom right of the SW where you have unplugged the right paddle shifter. If you don't the buttons on the wheel do not light.
Hopefully this will help someone without cruise.
Old Jun 8, 2011 | 06:51 AM
TimG517's Avatar
TimG517
That does help. The dealership I was at yesterday said it was not possible. I can get a MFSW for 125. Then I just need a wiring harness, and re-programing?
What dealership did you use? Just curious so I can reference that when I call a different dealership in southern California.
Old Jun 8, 2011 | 06:54 AM
TimG517's Avatar
TimG517
I need the steering column too? Not just the MFSW and a wireharness?
Old Jun 8, 2011 | 08:21 AM
strobeyprobey's Avatar
strobeyprobey
Not the column, but you *may* need a different SZL module if you have an 2007 model car.
Old Jun 8, 2011 | 08:24 AM
TimG517's Avatar
TimG517
I have a 2009 MC.
Where can I get a SZL module for a good price?
Old Jun 8, 2011 | 08:26 AM
strobeyprobey
You could try car-part.com or ebay. But the problem with the SZL module is the part numbers are not readily available. If the dealer can find the part number you would need, I like to get my parts from parts.com.
Old Jun 8, 2011 | 12:01 PM
schatzy62's Avatar
schatzy62
There are a number of different part numbers for the SLZ module and it is dependent on other options in the car as to which one will be needed to make it work. There is a VERY LONG thread on this process here in the electrical section which explains the problems a few people have gone thru to get it to work. Some of the problems were did the car have Auto A/C or not di the car have the Convenience Access etc. It is not jsut a straight forward put this module in and it will work thing you have to have the exact right module.
Old Jun 8, 2011 | 12:52 PM
jacknk's Avatar
jacknk
The way to go is to get the MFSW along with the SZL module with that wheel. That is what I did, that is why I got the whole steering column to get both. The SZL module is the part that has the turn signal and wiper stalks coming out of it. You don't need to change the column, just the SZL and MFSW.
Mine would not work by just changing to the MFSW. I had to put the SZL that came with that wheel to get it to work.
The 07 car that I got the steering column from had the automatic climate control, my car does not. I don't think that would make any difference.
The SZL at a dealer is over $500 but there are some on ebay. If I can find where I wrote the part number of the one I have down I will post it.
Old Jun 8, 2011 | 01:40 PM
jacknk's Avatar
jacknk
The ZDL that came on my O8 Cooper had a part number of 61313451897. This would not work with a MFSW.
The ZDL that was on the 07 Cooper with a MFSW had a part number of 61313451901. This worked on my O8 model. Not sure if it will work on later models or not.
I just looked on ebay and there is one of the 1901 ZDLs for $75 or make offer.
Old Jun 8, 2011 | 05:36 PM
TimG517's Avatar
TimG517
Thanks Guys. Keep me posted. And I will keep looking, if I can ever get out of work today.
Tim
Old Jun 8, 2011 | 05:52 PM
jacknk's Avatar
jacknk
Tim, what year is your Cooper?
Old Jun 8, 2011 | 06:33 PM
TimG517's Avatar
TimG517
Jack, it is a 2009 MC
Old Jun 9, 2011 | 12:30 AM
Hoopty's Avatar
Hoopty
I posted this long ago......
It took many months of trying to get a dealer to help me with my MFSW (cruise control) install….it has now been working perfectly for 30 months. I heard everything from ‘It can’t be done’ to ‘You need the convenience package first’ to ‘It’s never been done’ ect. The dealer where I purchased my car (Irvine) was worthless and never any help. They quoted over $1000.00 in parts and service. Well….while I was in for my first service at another local dealer (Crevier) they programmed my car for the MFSW I had installed months prior. For anyone considering this mod, my car is a 2008 MCSa and was built in Dec of 2007. The only part/labor it needed was the MFSW (easily installed myself) and programming. I had picked up a used steering wheel several months before for $100.00, but you could purchase just the buttons and achieve the same result.
Good Luck
Hoopty
Old Jun 9, 2011 | 04:31 AM
jacknk's Avatar
jacknk
Hoopty, you were lucky.
They tried to program mine with me just changing the wheel. The mechanic doing it said that some of the SZL did not have the internals needed for the MFSW even though it has the receptacle for the MFSW plug. When it would not program, I changed the SZL, took about 30 minutes. With the 61313451901 SZL installed it programmed with no problems.
Old Jun 9, 2011 | 05:28 AM
ke3ee's Avatar
ke3ee
where can you buy the MFSW for $125?
Best price I found was $185
Old Nov 7, 2011 | 02:56 PM
ke3ee's Avatar
ke3ee
I picked up a SZL that is for a car with DSC and No rain sensor. Mine does not have DSC or rain sensor. Can I install the unit and just have the MFSW portioned programmed on , or will the entire unit error out due to it looking for DSC ?
Old Nov 8, 2011 | 04:57 AM
schatzy62's Avatar
schatzy62
well a little more information about your car would be greatly helpful.
What year, model, and options does your car have? I ask because there is more to it than just the DSC and Rain Sensor.
Old Nov 8, 2011 | 05:03 AM
jacknk's Avatar
jacknk
I would install it and see if the cruise would program. I bet if the SZL has cruise that it will.
Old Nov 8, 2011 | 05:51 AM
ke3ee's Avatar
ke3ee
I have a 2008 base cooper. 6 spd, no DSC, No Rain sensor. HID's. NO MFSW. I bought the MFSW and installed. now I need to change the SZL. after installing tyhe MFSW I did go to the local dealer and when they tried to program the MFSW the software said I had the wrong SZL. So I bought the unit part # above from Ebay.If it helps, I also have the Cold Wx package.
Old Nov 8, 2011 | 06:11 AM
jacknk's Avatar
jacknk
I doubt if anyone knows if it will work till they try it. They were not sure that mine would work. I don't know what options the car had that the SZL was from. I would think as long as the SZL had the electronics for the MFSW that it would work.
Old Nov 8, 2011 | 11:27 AM
schatzy62's Avatar
schatzy62
It has been proven a number of times that even if it has the MFSW electronics that there are a number of different modules with the electronics and only certain ones will work with certain options.
Here are the part numbers and how they are to be used ( note 3992 is to be used on cars without MFSW as well and in incorporates all the components so it should work - but it is not a guarantee)
61313453992 -
DSC = Yes
Rain = Yes
61313453999
DCS = No
Rain = No
61313453991
DCS = Yes
Rain = No
61313454001
DSC = No
Rain = Yes
61319253770
DSC = Yes
Rain = Yes
61319253769
DSC = Yes
Rain = No
Old Jan 26, 2013 | 09:22 AM
SnowdogMini's Avatar
SnowdogMini
Revival of an ancient thread, but my '08 Clubman S has SZL# 61313451888. DSC/Xenon/ no Rain Sensing. Anyone know if it will work? Can't find any references to this part number. I'm guessing no. If not, what would the correct SZL be?
Thanks!
Old Jan 26, 2013 | 10:07 AM
SnowdogMini
Update: with the MFSW installed, not even the audio switches on the MFSW function. I'm guessing I need SZL 61319253769 to make everything work?
Old Feb 8, 2013 | 04:40 PM
OreoSAll4's Avatar
OreoSAll4
im in the same journey Snowdog, im about to take my wheel apart and check the part number for my szl. where exactly is it located?
2009 Clubman S, 6MT, yes DSC, no Rain, Coldweather Package.
Old Feb 9, 2013 | 07:50 AM
SnowdogMini
OreoSAll4,
The part number on the SZL is located right around 12 o'clock on the module itself, easily visible after the wheel is off. Now if I could find a used one, and a dealer to re-flash the car, I'd be all set.
