Electrical Always show digital speed modification
Old Nov 18, 2010 | 08:17 AM
strobeyprobey's Avatar
strobeyprobey
I used NCS Expert to always show the speed in the digital cluster. It mostly shows in the top window, but if a message appears (like sport mode or cruise control, the speed will temporarily move down to the lower window). I like this change because it is neat to see the mile to empty and the instant miles per gallon along with the speed.
This setting is found in KOBMI (instrument cluster). And I changed it to aktiv
DIG_SPEED_PERMANENT
nicht_aktiv
Here is the video:
I turned off the dampening of the tach, but I don't really notice a difference, so that setting may not effect the R56.
Also you can remove the snowflake alert at 37°F in the cluster using NCS as well.
If you have a BMW you can enable the digital speed on the dash with the following setting:
BC_DIGITAL_V
aktiv
If you don't like the speed overestimation you can remove the correction with this:
BC_DIGITAL_V_KORREKTUR
aktiv
If anyone is curious here are all of the settings in the KOMBI
Code:
TYP_LENKUNG
	linkslenker
SHOW_CC_MSG_NR
	nicht_aktiv
PREDRIVE_ABB_MOT
	nicht_aktiv
BC_DIGITAL_V
	aktiv
	aktiv
PREDRIVE_START_MIT_OBD
	aktiv
CC_BLINKFREQUENZ_LANGSAM
	wert_01
CC_BLINKFREQUENZ_SCHNELL
	wert_01
CC_15_AUS
	wert_01
CC_R_EIN
	wert_01
CC_R_AUS
	wert_01
CC_ML
	wert_01
PREDRIVE_PERIODENDAUER
	wert_01
K_ZAHL_TACHO
	wert_01
K_ZAHL_TACHO_KOMPL
	wert_01
K_ZAHL_WEG
	wert_01
K_ZAHL_WEG_KOMPL
	wert_01
CAS_ALIVE
	aktiv
ZGM_ALIVE_ZAEHLER
	aktiv
DSC_ALIVE_ZAEHLER
	aktiv
ARS_ALIVE_ZAEHLER
	nicht_aktiv
EHC_ALIVE
	nicht_aktiv
DME_ALIVE_ZAEHLER
	aktiv
LM_ALIVE
	aktiv
RDC_ALIVE
	aktiv
SFY_ALIVE_ZAEHLER
	aktiv
LEHNE_FA_ALIVE_ZAEHLER
	nicht_aktiv
LEHNE_BF_ALIVE_ZAEHLER
	nicht_aktiv
SFY_ID_MONITOR
	aktiv
DME_ID_MONITOR
	aktiv
ZGM_ID_MONITOR
	aktiv
LEHNE_FA_ID_MONITOR
	nicht_aktiv
LEHNE_BF_ID_MONITOR
	nicht_aktiv
ARS_ID_MONITOR
	nicht_aktiv
DSC_ID_MONITOR
	aktiv
EPS_ALIVE_MONITOR
	aktiv
EPS_ID_MONITOR
	aktiv
TANK_SCHWELLE_RESERVE
	wert_01
TANK_SCHWELLE_AUF/AB
	wert_02
TANK_BERUHIGUNGSZEIT
	wert_01
TANK_MITTLUNGSZEIT
	wert_01
TANK_SICHERHEITSFAKTOR
	wert_01
TANK_FILTER_STEIGEND
	wert_01
TANK_FILTER_FALLEND
	wert_01
TANK_VOLL_ERKENNUNG
	wert_01
TNK_LITER_RECHTS
	wert_01
TNK_LITER_LINKS
	wert_01
TANK_OHM_FEHLER_OG
	wert_01
TANK_OHM_FEHLER_UG
	wert_01
TANK_RW_WARNUNG
	wert_01
TANK_RED_REICHWEITE
	wert_01
TNK_OHM_RECHTS
	wert_01
TNK_OHM_LINKS
	wert_01
AUSSENTEMP_DELTA_K1
	wert_01
AUSSENTEMP_DELTA_K2
	wert_01
AUSSENTEMP_ZEITKONST_Z1
	wert_01
AUSSENTEMP_ZEITKONST_Z2
	wert_01
AUSSENTEMP_ZEITKONST_Z3
	wert_01
AUSSENTEMP_ZEITKONST_Z4
	wert_01
AUSSENTEMP_ZEITKONST_Z5
	wert_01
AUSSENTEMP_ZEITKONST_Z6
	wert_01
AUSSENTEMP_SPERR_FAKTOR
	wert_01
AUSSENTEMP_SPERR_OFFSET
	wert_01
MOTORKONSTANTE
	wert_01
AUSSENTEMP_ANZ_FEHLER_1
	wert_01
AUSSENTEMP_ANZ_FEHLER_2
	wert_01
CBS_RES_SPERR
	wert_01
CBS_GELB_KM_MIN
	wert_01
CBS_GELB_HUAU
	wert_01
CBS_GELB
	wert_01
CBS_EINH_10H
	wegbas
CBS_INTW_12H
	wert_01
CBS_EINH_12H
	wegbas
CBS_STAT_12H
	sperre
CBS_SCEN_12H
	nicht_aktiv
CBS_INTD_03H
	wert_01
CBS_EINH_03H
	zeitbas
CBS_STAT_03H
	anzeige
CBS_SCEN_03H
	nicht_aktiv
CBS_INTD_14H
	wert_01
CBS_EINH_14H
	zeitbas
CBS_STAT_14H
	sperre
CBS_SCEN_14H
	nicht_aktiv
CBS_INTD_11H
	wert_01
CBS_EINH_11H
	wegzeit
CBS_STAT_11H
	anzeige
CBS_SCEN_11H
	nicht_aktiv
CBS_EINH_20H
	zeitbas
CBS_STAT_20H
	anzeige
CBS_SCEN_20H
	nicht_aktiv
CBS_EINH_21H
	zeitbas
CBS_STAT_21H
	sperre
CBS_SCEN_21H
	nicht_aktiv
CBS_EINH_02H
	wegbas
CBS_STAT_02H
	anzeige
CBS_SCEN_02H
	nicht_aktiv
CBS_EINH_06H
	wegbas
CBS_STAT_06H
	anzeige
CBS_SCEN_06H
	nicht_aktiv
CBS_EINH_07H
	wegbas
CBS_EINH_01H
	wegzeit
CBS_STAT_01H
	anzeige
CBS_SCEN_01H
	nicht_aktiv
CBS_EINH_04H
	wegzeit
CBS_STAT_04H
	sperre
CBS_SCEN_04H
	nicht_aktiv
CBS_AVKM_START
	wert_01
CBS_TZ_SCHALTER
	borddatum
CODING_VALID_BMW
	wert_01
DATEN_INDEX
	grundcode_var
HU_VERBAUT
	radiostufe_3_4
KL_PREDRIVE_AUSWAHL
	wert_01
ACC_AUSSTATTUNG
	wert_01
ACC_ALIVE_ZAEHLER
	nicht_aktiv
ACC_CSUM_MONITOR
	nicht_aktiv
FDC_VERBAUT
	aktiv
GPS_UHR
	nicht_aktiv
BC_2_ENABLE
	nicht_aktiv
CC_15_EIN
	wert_01
EKP_ALIVE_ZAEHLER
	nicht_aktiv
EKP_ID_MONITOR
	nicht_aktiv
CBS_STAT_10H
	sperre
CBS_SCEN_10H
	nicht_aktiv
CBS_STAT_07H
	sperre
CBS_SCEN_07H
	nicht_aktiv
CBS_INTW_10H
	wert_02
CBS_INTW_11H
	wert_04
RDC_VERBAUT
	aktiv
ACC_ID_MONITOR
	nicht_aktiv
AFS_ALIVE_ZAEHLER
	nicht_aktiv
AFS_ID_MONITOR
	nicht_aktiv
AHM_ALIVE
	nicht_aktiv
TEMPOMAT_SETZ_ANZ_DAUER
	wert_02
EGS_ALIVE_ZAEHLER
	aktiv
EGS_ID_MONITOR
	aktiv
EGS_CSUM_MONITOR
	aktiv
TCM_ALIVE_MONITOR
	nicht_aktiv
TCM_ID_MONITOR
	nicht_aktiv
K4310_C_SPRACHE_1
	wert_03
K4310_C_SPRACHE_2
	wert_03
K4310_C_SPRACHE_3
	wert_03
K4310_C_SPRACHE_4
	wert_03
K4310_D_SPRACHE
	wert_03
K430C_C_DATUM_1
	wert_02
K430C_C_DATUM_2
	wert_02
K430C_C_DATUM_3
	wert_02
K430C_C_DATUM_4
	wert_02
K430C_D_DATUM
	wert_02
K4113_C_ZEIT_1
	wert_02
K4113_C_ZEIT_2
	wert_02
K4113_C_ZEIT_3
	wert_02
K4113_C_ZEIT_4
	wert_01
K4113_D_ZEIT
	wert_02
WARNUNG_GESCHW_LIMIT
	nicht_aktiv
CC_TEMPERATURWARNUNG
	aktiv
K4116_C_TEMPERATUR_1
	wert_02
K4116_C_TEMPERATUR_2
	wert_02
K4116_C_TEMPERATUR_3
	wert_02
K4116_C_TEMPERATUR_4
	wert_02
K4116_D_TEMPERATUR
	wert_02
BC_V_KORREKTUR
	aktiv
CC_ZUENDSCHLUESSEL
	aktiv
K4110_C_VERBRAUCH_1
	wert_02
K4110_C_VERBRAUCH_2
	wert_02
K4110_C_VERBRAUCH_3
	wert_02
K4110_C_VERBRAUCH_4
	wert_02
K4110_D_VERBRAUCH
	wert_02
K4119_C_DRUCK_1
	wert_03
K4119_C_DRUCK_2
	wert_03
K4119_C_DRUCK_3
	wert_03
K4119_C_DRUCK_4
	wert_03
K4119_D_DRUCK
	wert_03
K410D_C_WEG_1
	wert_02
K410D_C_WEG_2
	wert_02
K410D_C_WEG_3
	wert_02
K410D_C_WEG_4
	wert_02
K410D_D_WEG
	wert_02
MMI_ENA_RPA_RDC
	aktiv
MMI_ENA_PIA
	aktiv
MMI_ENA_UHR_DATUM
	aktiv
SHOW_OEL_STAND
	aktiv
CC_NR_ROLLE
	aktiv
HDC_ID_MONITOR
	nicht_aktiv
DWA_VERBAUT
	nicht_aktiv
TANK
	wert_01
TIMEOUT_1
	wert_01
TIMEOUT_2
	wert_01
CRASH_TH_DIMMUNG
	wert_01
CBS_EINH_15H
	zeitbas
CBS_INTD_15H
	wert_01
CBS_SCEN_15H
	nicht_aktiv
CBS_STAT_15H
	sperre
DSC_MIT_RPA_CC
	aktiv
TNK_RW_VERBRAUCH
	wert_02
BC_1_ENABLE
	aktiv
CBS_EINH_16H
	wegbas
CBS_SCEN_16H
	nicht_aktiv
CBS_STAT_16H
	sperre
CC_EHH_ANZ_MIN_TIME
	wert_01
DIG_TACHO_SWITCH_TIME
	wert_01
FB_ALLE_TUEREN
	aktiv
FB_FA_TUER
	aktiv
HEIMLEUCHTEN_10S
	aktiv
HEIMLEUCHTEN_150S
	aktiv
HEIMLEUCHTEN_240S
	aktiv
HEIMLEUCHTEN_40S
	aktiv
HEIMLEUCHTEN_90S
	aktiv
HEIMLEUCHTEN_AUS
	aktiv
OHNE_QUITT_ENT
	aktiv
OHNE_QUITT_VER
	aktiv
QUITT_AKUST_ENT
	nicht_aktiv
QUITT_AKUST_VER
	nicht_aktiv
QUITT_OPT_AKUST_ENT
	nicht_aktiv
QUITT_OPT_AKUST_VER
	nicht_aktiv
QUITT_OPT_ENT
	aktiv
QUITT_OPT_VER
	aktiv
TAG_LICHT_AN
	aktiv
TAG_LICHT_AUS
	aktiv
TIPP_BLINKEN_1X
	aktiv
TIPP_BLINKEN_3X
	aktiv
ZV_VER_AUS
	aktiv
ZV_VER_FAHRT
	aktiv
ZV_VER_FAHRT_ZEIT
	aktiv
ZV_VER_ZEIT
	aktiv
CC_ID_AKTIV_01
	wert_01
CC_ID_AKTIV_11
	wert_02
GEAR_SHIFT_ALIVE
	nicht_aktiv
GURT_ID_MONITOR
	nicht_aktiv
SCHALT_PKT_BC
	nicht_aktiv
SCHALT_PKT_DAUERHAFT
	nicht_aktiv
CC_ID_AKTIV_14
	wert_01
DISP_TEMP_LEVEL
	wert_01
DSC_ASC_CC
	aktiv
GEAR_SHIFT_CSUM
	nicht_aktiv
GEAR_SHIFT_ID_MONITOR
	nicht_aktiv
MSA_ALIVE_MONITOR
	nicht_aktiv
MSA_CSUM_MONITOR
	nicht_aktiv
MSA_ENABLE
	wert_02
MSA_ID_MONITOR
	nicht_aktiv
MSA_SWITCH_ON_OFF_ENABLE
	nicht_aktiv
SOUND_SWITCH
	aktiv
MONITOR_NAV_SPEED_CALIBR
	aktiv
MONITOR_SPEED_SENSOR
	aktiv
DIG_SPEED_PERMANENT
	nicht_aktiv
RDC_DISP_SWITCH
	aktiv
CC_ID_AKTIV_07
	wert_02
DISP_ENGDAT_ALIVE_ZAEHLER
	nicht_aktiv
DISP_ENGDAT_ID_MONITOR
	nicht_aktiv
DZM_DAEMPFUNG
	aktiv
DZM_DISP_RPM
	wert_01
RAIN_SENSOR_ID_MONITOR
	nicht_aktiv
RAIN_SENSOR_MENU_ENA
	nicht_aktiv
SPORT_ANZEIGEDAUER
	wert_02
VEH_MOD_ALIVE_MONITOR
	aktiv
VEH_MOD_CSUM_MONITOR
	aktiv
VEH_MOD_ID_MONITOR
	aktiv
GETRIEBE_TYP_KOMBI
	automatik
CVM_ALIVE_ZAEHLER
	nicht_aktiv
CVM_ID_MONITOR
	nicht_aktiv
SP_ANZEIGE
	wert_02
SP_ANZEIGE_1
	wert_02
SP_ANZEIGE_2
	wert_02
SP_ANZEIGE_3
	wert_02
SP_ANZEIGE_4
	wert_02
AO_CLOSED_ENABLE
	aktiv
AO_DISP_TIME
	wert_01
AO_ENABLE
	nicht_aktiv
AO_OPENANI_ENABLE
	nicht_aktiv
AO_OVERF_FREQU
	wert_01
AO_OVERFANI_ENABLE
	nicht_aktiv
AO_POINTER_SPEED
	wert_01
AO_STARTANI_ENABLE
	nicht_aktiv
DSC_VARIANT
	wert_01
Old Nov 18, 2010 | 09:05 AM
MINIdave's Avatar
MINIdave
Wish you were closer to me, I'd love to have you do a couple of things to my R55 - like turn off that damn seatbelt gong!
If you ever find yourself in KC, let me know - I'll make it worth your while. I know a great BBQ place, for example!
Old Nov 18, 2010 | 09:07 AM
rkw's Avatar
rkw
Very nice. What do you mean by turning off "dampening of the tach"?
Old Nov 18, 2010 | 09:14 AM
strobeyprobey
YUM! I love BBQ! Sorry, I don't see any visits to KC anytime soon.
And dampening of the tach I assumed was slowing of the needle movement, it seems way too slow to me. But I didn't really notice any difference this morning driving in.
Old Feb 4, 2011 | 07:51 PM
smoke05S's Avatar
smoke05S
So that speed overestimation is on purpose? Is it on the display only? In other words, does the Korrection error carry over to the odometer? Sure would like to know if we are really getting 33MPG and not 10% less (since the error is about 10%)?
Old Feb 5, 2011 | 12:43 PM
hsautocrosser's Avatar
hsautocrosser
My speedo is 6.8% overstated and odo is 1.1% compared to Garmin Nuvi GPS.
Old Feb 5, 2011 | 12:47 PM
hsautocrosser
Sorry, the 6.8% error is in the CONSUMPTION number. The speedo is off 2-4 mph between 25 and 70.
Old Feb 7, 2011 | 07:58 AM
strobeyprobey
Yep, the odometer is close to the real number as hsautocrosser stated, obviously the size of your tires will make that number change slightly. The speed display is artificially inflated.
Old Feb 10, 2011 | 04:18 AM
meckonica's Avatar
meckonica
I solved my Speedo error with a tire change. I went to 225-40-18. the error is about 1/2mph faster indication vs GPS actual at any speed.
Now I need to lower the car, too much air going under the car.
Also if anyone has performance mod ideas for the factory R55 JCW, let me know.
I had an 09 R56 JCW that would run circles around my 09 R55 JCW. I love everything about the JCW Clubman except that it is a pig compared to my JCW coupe. On the Dyno it showed 178hp to the front (factory) wheels.
Any ideas?
Old Feb 12, 2011 | 09:48 AM
smoke05S's Avatar
smoke05S
Unfortunately, you should start by reducing rotating mass so while those 18's are great for reducing speedo error, they are not helping with acceleration.
Old Feb 17, 2011 | 08:37 PM
mellocooper's Avatar
mellocooper
Cool - that always bugs me in my 2008 but my new 2011 Clubman the speed always stays on just like in your video. Also they added a little icon that comes on between the odos when intermittent wipers are on.
I just wish there was a way to get the clock to show when the radio is on "comp" showing the consumption, range temp etc. There's a huge amount of unused space on that display.
So you must have to know some German to do that programming lol.
Old Feb 18, 2011 | 07:26 AM
strobeyprobey
The only workaround to show the clock in the "computer" is to select one of values, like the temperature. Even more wasted space! But the clock shows.
Old Feb 20, 2011 | 07:25 PM
BBoshart's Avatar
BBoshart
First off, thanks to this thread and the 'Close Windows & Sunroof' thread (and strobeyprobey in particular) for providing all the info.
Using BC_DIGITAL_V_KORREKTUR, I've corrected my digital (tach) speedo, but the big center speedo is unaffected. I found BC_V_KORREKTUR which I figured was the big speedo correction but making that inactive did not change anything.
So right now, my digital speedo is about 2 mph slower than my big speedo. Also, when setting cruise control it reads 2 mph faster than my digital. For now, I put the correction back on so everything matches.
Does anyone know how to correct the big speedo as well? I'd like to have both matching (and the cruise control). Thanks.
Old Feb 21, 2011 | 08:21 AM
strobeyprobey
I left my digital speed to the default just to avoid the inconsistency you describe between the different gauges. I haven't found the setting to fix the analog gauge. Doesn't seem like the BMW forum really found the answer yet either.
Old Sep 30, 2011 | 07:56 PM
TheCheatOSX's Avatar
TheCheatOSX
I don't think I've ever seen this one listed on any of the spreadsheets. What's the code for it?
Old Oct 3, 2011 | 05:34 PM
strobeyprobey
AUSSENTEMP_WARNUNG_GONG
And I think that is in the cluster. KOMBI module
Old May 4, 2013 | 08:53 AM
troylees's Avatar
troylees
Hi all, I got problems after coding KOBMI module on r56, now the gas light is off, always have tail box open alarm, etc... Even I coding to original codes, not work.
my change:
DIG_SPEED_PERMANENT
nicht_aktiv to aktiv
CC_ZUENDSCHLUESSEL
original code:
TYP_LENKUNG
linkslenker
SHOW_CC_MSG_NR
nicht_aktiv
PREDRIVE_ABB_MOT
nicht_aktiv
BC_DIGITAL_V
aktiv
aktiv
aktiv
wert_01
wert_01
CC_15_AUS
wert_01
CC_R_EIN
wert_01
CC_R_AUS
wert_01
CC_ML
wert_01
wert_01
K_ZAHL_TACHO
wert_01
K_ZAHL_TACHO_KOMPL
wert_01
K_ZAHL_WEG
wert_01
K_ZAHL_WEG_KOMPL
wert_01
CAS_ALIVE
aktiv
ZGM_ALIVE_ZAEHLER
aktiv
DSC_ALIVE_ZAEHLER
aktiv
ARS_ALIVE_ZAEHLER
nicht_aktiv
EHC_ALIVE
nicht_aktiv
DME_ALIVE_ZAEHLER
aktiv
LM_ALIVE
aktiv
RDC_ALIVE
nicht_aktiv
SFY_ALIVE_ZAEHLER
aktiv
nicht_aktiv
nicht_aktiv
SFY_ID_MONITOR
aktiv
DME_ID_MONITOR
aktiv
ZGM_ID_MONITOR
aktiv
LEHNE_FA_ID_MONITOR
nicht_aktiv
LEHNE_BF_ID_MONITOR
nicht_aktiv
ARS_ID_MONITOR
nicht_aktiv
DSC_ID_MONITOR
aktiv
EPS_ALIVE_MONITOR
aktiv
EPS_ID_MONITOR
aktiv
wert_01
wert_02
wert_01
TANK_MITTLUNGSZEIT
wert_01
wert_01
wert_01
TANK_FILTER_FALLEND
wert_01
TANK_VOLL_ERKENNUNG
wert_02
TNK_LITER_RECHTS
wert_02
TNK_LITER_LINKS
wert_02
TANK_OHM_FEHLER_OG
wert_01
TANK_OHM_FEHLER_UG
wert_01
TANK_RW_WARNUNG
wert_01
TANK_RED_REICHWEITE
wert_01
TNK_OHM_RECHTS
wert_02
TNK_OHM_LINKS
wert_02
AUSSENTEMP_DELTA_K1
wert_01
AUSSENTEMP_DELTA_K2
wert_01
wert_01
wert_01
wert_01
wert_01
wert_01
wert_01
wert_01
wert_01
MOTORKONSTANTE
wert_01
wert_01
wert_01
CBS_RES_SPERR
wert_01
CBS_GELB_KM_MIN
wert_01
CBS_GELB_HUAU
wert_01
CBS_GELB
wert_01
CBS_EINH_10H
wegbas
CBS_INTW_12H
wert_01
CBS_EINH_12H
wegbas
CBS_STAT_12H
sperre
CBS_SCEN_12H
nicht_aktiv
CBS_INTD_03H
wert_01
CBS_EINH_03H
zeitbas
CBS_STAT_03H
anzeige
CBS_SCEN_03H
nicht_aktiv
CBS_INTD_14H
wert_01
CBS_EINH_14H
zeitbas
CBS_STAT_14H
sperre
CBS_SCEN_14H
nicht_aktiv
CBS_INTD_11H
wert_01
CBS_EINH_11H
wegzeit
CBS_STAT_11H
anzeige
CBS_SCEN_11H
nicht_aktiv
CBS_EINH_20H
zeitbas
CBS_STAT_20H
anzeige
CBS_SCEN_20H
nicht_aktiv
CBS_EINH_21H
zeitbas
CBS_STAT_21H
anzeige
CBS_SCEN_21H
nicht_aktiv
CBS_EINH_02H
wegbas
CBS_STAT_02H
anzeige
CBS_SCEN_02H
nicht_aktiv
CBS_EINH_06H
wegbas
CBS_STAT_06H
anzeige
CBS_SCEN_06H
nicht_aktiv
CBS_EINH_07H
wegbas
CBS_EINH_01H
wegzeit
CBS_STAT_01H
anzeige
CBS_SCEN_01H
nicht_aktiv
CBS_EINH_04H
wegzeit
CBS_STAT_04H
sperre
CBS_SCEN_04H
nicht_aktiv
CBS_AVKM_START
wert_01
CBS_TZ_SCHALTER
borddatum
CSUM_KODIERUNG_VALID
grundcode_var
CODING_VALID_BMW
wert_01
HU_VERBAUT
radiostufe_3_4
KL_PREDRIVE_AUSWAHL
wert_02
ACC_AUSSTATTUNG
wert_01
ACC_ALIVE_ZAEHLER
nicht_aktiv
ACC_CSUM_MONITOR
nicht_aktiv
FDC_VERBAUT
aktiv
GPS_UHR
nicht_aktiv
BC_2_ENABLE
nicht_aktiv
CC_15_EIN
wert_01
EKP_ALIVE_ZAEHLER
nicht_aktiv
EKP_ID_MONITOR
nicht_aktiv
CBS_STAT_10H
sperre
CBS_SCEN_10H
nicht_aktiv
CBS_STAT_07H
sperre
CBS_SCEN_07H
nicht_aktiv
CBS_INTW_10H
wert_01
CBS_INTW_11H
wert_01
wert_03
RDC_VERBAUT
nicht_aktiv
ACC_ID_MONITOR
nicht_aktiv
AFS_ALIVE_ZAEHLER
nicht_aktiv
AFS_ID_MONITOR
nicht_aktiv
AHM_ALIVE
nicht_aktiv
wert_02
EGS_ALIVE_ZAEHLER
aktiv
EGS_ID_MONITOR
aktiv
EGS_CSUM_MONITOR
aktiv
TCM_ALIVE_MONITOR
nicht_aktiv
TCM_ID_MONITOR
nicht_aktiv
K4310_C_SPRACHE_1
wert_10
K4310_C_SPRACHE_2
wert_10
K4310_C_SPRACHE_3
wert_10
K4310_C_SPRACHE_4
wert_10
K4310_D_SPRACHE
wert_10
K430C_C_DATUM_1
wert_01
K430C_C_DATUM_2
wert_01
K430C_C_DATUM_3
wert_01
K430C_C_DATUM_4
wert_01
K430C_D_DATUM
wert_01
K4113_C_ZEIT_1
wert_01
K4113_C_ZEIT_2
wert_01
K4113_C_ZEIT_3
wert_01
K4113_C_ZEIT_4
wert_01
K4113_D_ZEIT
wert_01
nicht_aktiv
aktiv
wert_01
wert_01
wert_01
wert_01
K4116_D_TEMPERATUR
wert_01
BC_V_KORREKTUR
aktiv
CC_ZUENDSCHLUESSEL
nicht_aktiv
K4110_C_VERBRAUCH_1
wert_01
K4110_C_VERBRAUCH_2
wert_01
K4110_C_VERBRAUCH_3
wert_01
K4110_C_VERBRAUCH_4
wert_01
K4110_D_VERBRAUCH
wert_01
K4119_C_DRUCK_1
wert_01
K4119_C_DRUCK_2
wert_01
K4119_C_DRUCK_3
wert_01
K4119_C_DRUCK_4
wert_01
K4119_D_DRUCK
wert_01
K410D_C_WEG_1
wert_01
K410D_C_WEG_2
wert_01
K410D_C_WEG_3
wert_01
K410D_C_WEG_4
wert_01
K410D_D_WEG
wert_01
MMI_ENA_RPA_RDC
aktiv
MMI_ENA_PIA
aktiv
MMI_ENA_UHR_DATUM
aktiv
SHOW_OEL_STAND
aktiv
CC_NR_ROLLE
aktiv
HDC_ID_MONITOR
nicht_aktiv
DWA_VERBAUT
aktiv
TANK
wert_02
TIMEOUT_1
wert_01
TIMEOUT_2
wert_01
CRASH_TH_DIMMUNG
wert_01
CBS_EINH_15H
zeitbas
CBS_INTD_15H
wert_01
CBS_SCEN_15H
nicht_aktiv
CBS_STAT_15H
sperre
DSC_MIT_RPA_CC
nicht_aktiv
TNK_RW_VERBRAUCH
wert_02
BC_1_ENABLE
aktiv
CBS_EINH_16H
wegbas
CBS_SCEN_16H
nicht_aktiv
CBS_STAT_16H
sperre
CC_EHH_ANZ_MIN_TIME
wert_01
wert_01
FB_ALLE_TUEREN
aktiv
FB_FA_TUER
aktiv
HEIMLEUCHTEN_10S
aktiv
HEIMLEUCHTEN_150S
aktiv
HEIMLEUCHTEN_240S
aktiv
HEIMLEUCHTEN_40S
aktiv
HEIMLEUCHTEN_90S
aktiv
HEIMLEUCHTEN_AUS
aktiv
OHNE_QUITT_ENT
aktiv
OHNE_QUITT_VER
aktiv
QUITT_AKUST_ENT
nicht_aktiv
QUITT_AKUST_VER
nicht_aktiv
QUITT_OPT_AKUST_ENT
nicht_aktiv
QUITT_OPT_AKUST_VER
nicht_aktiv
QUITT_OPT_ENT
aktiv
QUITT_OPT_VER
aktiv
TAG_LICHT_AN
aktiv
TAG_LICHT_AUS
aktiv
TIPP_BLINKEN_1X
aktiv
TIPP_BLINKEN_3X
aktiv
ZV_VER_AUS
aktiv
ZV_VER_FAHRT
aktiv
ZV_VER_FAHRT_ZEIT
aktiv
ZV_VER_ZEIT
aktiv
CC_ID_AKTIV_01
wert_01
CC_ID_AKTIV_11
wert_01
GEAR_SHIFT_ALIVE
nicht_aktiv
GURT_ID_MONITOR
nicht_aktiv
SCHALT_PKT_BC
nicht_aktiv
nicht_aktiv
CC_ID_AKTIV_14
wert_01
DISP_TEMP_LEVEL
wert_01
DSC_ASC_CC
aktiv
GEAR_SHIFT_CSUM
nicht_aktiv
nicht_aktiv
MSA_ALIVE_MONITOR
nicht_aktiv
MSA_CSUM_MONITOR
nicht_aktiv
MSA_ENABLE
wert_02
MSA_ID_MONITOR
nicht_aktiv
nicht_aktiv
SOUND_SWITCH
aktiv
aktiv
aktiv
DIG_SPEED_PERMANENT
nicht_aktiv
RDC_DISP_SWITCH
aktiv
CC_ID_AKTIV_07
wert_02
nicht_aktiv
nicht_aktiv
DZM_DAEMPFUNG
aktiv
DZM_DISP_RPM
wert_01
aktiv
aktiv
SPORT_ANZEIGEDAUER
wert_01
nicht_aktiv
nicht_aktiv
VEH_MOD_ID_MONITOR
nicht_aktiv
GETRIEBE_TYP_KOMBI
automatik
CVM_ALIVE_ZAEHLER
nicht_aktiv
CVM_ID_MONITOR
nicht_aktiv
SP_ANZEIGE
wert_02
SP_ANZEIGE_1
wert_02
SP_ANZEIGE_2
wert_02
SP_ANZEIGE_3
wert_02
SP_ANZEIGE_4
wert_02
AO_CLOSED_ENABLE
aktiv
AO_DISP_TIME
wert_01
AO_ENABLE
nicht_aktiv
AO_OPENANI_ENABLE
nicht_aktiv
AO_OVERF_FREQU
wert_01
AO_OVERFANI_ENABLE
nicht_aktiv
AO_POINTER_SPEED
wert_01
AO_STARTANI_ENABLE
nicht_aktiv
DSC_VARIANT
wert_01
CC_ID_AKTIV_05
wert_02
WIPER_STAT_DISP
wert_01
after re-code to original, read again
TYP_LENKUNG
linkslenker
SHOW_CC_MSG_NR
nicht_aktiv
PREDRIVE_ABB_MOT
nicht_aktiv
BC_DIGITAL_V
aktiv
aktiv
aktiv
wert_01
wert_01
CC_15_AUS
wert_01
CC_R_EIN
wert_01
CC_R_AUS
wert_01
CC_ML
wert_01
wert_01
K_ZAHL_TACHO
wert_01
K_ZAHL_TACHO_KOMPL
wert_01
K_ZAHL_WEG
wert_01
K_ZAHL_WEG_KOMPL
wert_01
CAS_ALIVE
aktiv
ZGM_ALIVE_ZAEHLER
aktiv
DSC_ALIVE_ZAEHLER
aktiv
ARS_ALIVE_ZAEHLER
nicht_aktiv
EHC_ALIVE
nicht_aktiv
DME_ALIVE_ZAEHLER
aktiv
LM_ALIVE
aktiv
RDC_ALIVE
nicht_aktiv
SFY_ALIVE_ZAEHLER
aktiv
nicht_aktiv
nicht_aktiv
SFY_ID_MONITOR
aktiv
DME_ID_MONITOR
aktiv
ZGM_ID_MONITOR
aktiv
LEHNE_FA_ID_MONITOR
nicht_aktiv
LEHNE_BF_ID_MONITOR
nicht_aktiv
ARS_ID_MONITOR
nicht_aktiv
DSC_ID_MONITOR
aktiv
EPS_ALIVE_MONITOR
aktiv
EPS_ID_MONITOR
aktiv
wert_01
wert_02
wert_01
TANK_MITTLUNGSZEIT
wert_01
wert_01
wert_01
TANK_FILTER_FALLEND
wert_01
TANK_VOLL_ERKENNUNG
wert_02
TNK_LITER_RECHTS
wert_02
TNK_LITER_LINKS
wert_02
TANK_OHM_FEHLER_OG
wert_01
TANK_OHM_FEHLER_UG
wert_01
TANK_RW_WARNUNG
wert_01
TANK_RED_REICHWEITE
wert_01
TNK_OHM_RECHTS
wert_02
TNK_OHM_LINKS
wert_02
AUSSENTEMP_DELTA_K1
wert_01
AUSSENTEMP_DELTA_K2
wert_01
wert_01
wert_01
wert_01
wert_01
wert_01
wert_01
wert_01
wert_01
MOTORKONSTANTE
wert_01
wert_01
wert_01
CBS_RES_SPERR
wert_01
CBS_GELB_KM_MIN
wert_01
CBS_GELB_HUAU
wert_01
CBS_GELB
wert_01
CBS_EINH_10H
wegbas
CBS_INTW_12H
wert_01
CBS_EINH_12H
wegbas
CBS_STAT_12H
sperre
CBS_SCEN_12H
nicht_aktiv
CBS_INTD_03H
wert_01
CBS_EINH_03H
zeitbas
CBS_STAT_03H
anzeige
CBS_SCEN_03H
nicht_aktiv
CBS_INTD_14H
wert_01
CBS_EINH_14H
zeitbas
CBS_STAT_14H
sperre
CBS_SCEN_14H
nicht_aktiv
CBS_INTD_11H
wert_01
CBS_EINH_11H
wegzeit
CBS_STAT_11H
anzeige
CBS_SCEN_11H
nicht_aktiv
CBS_EINH_20H
zeitbas
CBS_STAT_20H
anzeige
CBS_SCEN_20H
nicht_aktiv
CBS_EINH_21H
zeitbas
CBS_STAT_21H
anzeige
CBS_SCEN_21H
nicht_aktiv
CBS_EINH_02H
wegbas
CBS_STAT_02H
anzeige
CBS_SCEN_02H
nicht_aktiv
CBS_EINH_06H
wegbas
CBS_STAT_06H
anzeige
CBS_SCEN_06H
nicht_aktiv
CBS_EINH_07H
wegbas
CBS_EINH_01H
wegzeit
CBS_STAT_01H
anzeige
CBS_SCEN_01H
nicht_aktiv
CBS_EINH_04H
wegzeit
CBS_STAT_04H
sperre
CBS_SCEN_04H
nicht_aktiv
CBS_AVKM_START
wert_01
CBS_TZ_SCHALTER
borddatum
CODING_VALID_BMW
wert_01
DATEN_INDEX
grundcode_var
HU_VERBAUT
radiostufe_3_4
KL_PREDRIVE_AUSWAHL
wert_02
ACC_AUSSTATTUNG
wert_01
ACC_ALIVE_ZAEHLER
nicht_aktiv
ACC_CSUM_MONITOR
nicht_aktiv
FDC_VERBAUT
aktiv
GPS_UHR
nicht_aktiv
BC_2_ENABLE
nicht_aktiv
CC_15_EIN
wert_01
EKP_ALIVE_ZAEHLER
nicht_aktiv
EKP_ID_MONITOR
nicht_aktiv
CBS_STAT_10H
sperre
CBS_SCEN_10H
nicht_aktiv
CBS_STAT_07H
sperre
CBS_SCEN_07H
nicht_aktiv
CBS_INTW_10H
wert_01
CBS_INTW_11H
wert_01
wert_03
RDC_VERBAUT
nicht_aktiv
ACC_ID_MONITOR
nicht_aktiv
AFS_ALIVE_ZAEHLER
nicht_aktiv
AFS_ID_MONITOR
nicht_aktiv
AHM_ALIVE
nicht_aktiv
wert_02
EGS_ALIVE_ZAEHLER
aktiv
EGS_ID_MONITOR
aktiv
EGS_CSUM_MONITOR
aktiv
TCM_ALIVE_MONITOR
nicht_aktiv
TCM_ID_MONITOR
nicht_aktiv
K4310_C_SPRACHE_1
wert_10
K4310_C_SPRACHE_2
wert_10
K4310_C_SPRACHE_3
wert_10
K4310_C_SPRACHE_4
wert_10
K4310_D_SPRACHE
wert_10
K430C_C_DATUM_1
wert_01
K430C_C_DATUM_2
wert_01
K430C_C_DATUM_3
wert_01
K430C_C_DATUM_4
wert_01
K430C_D_DATUM
wert_01
K4113_C_ZEIT_1
wert_01
K4113_C_ZEIT_2
wert_01
K4113_C_ZEIT_3
wert_01
K4113_C_ZEIT_4
wert_01
K4113_D_ZEIT
wert_01
nicht_aktiv
aktiv
wert_01
wert_01
wert_01
wert_01
K4116_D_TEMPERATUR
wert_01
BC_V_KORREKTUR
aktiv
CC_ZUENDSCHLUESSEL
nicht_aktiv
K4110_C_VERBRAUCH_1
wert_01
K4110_C_VERBRAUCH_2
wert_01
K4110_C_VERBRAUCH_3
wert_01
K4110_C_VERBRAUCH_4
wert_01
K4110_D_VERBRAUCH
wert_01
K4119_C_DRUCK_1
wert_01
K4119_C_DRUCK_2
wert_01
K4119_C_DRUCK_3
wert_01
K4119_C_DRUCK_4
wert_01
K4119_D_DRUCK
wert_01
K410D_C_WEG_1
wert_01
K410D_C_WEG_2
wert_01
K410D_C_WEG_3
wert_01
K410D_C_WEG_4
wert_01
K410D_D_WEG
wert_01
MMI_ENA_RPA_RDC
aktiv
MMI_ENA_PIA
aktiv
MMI_ENA_UHR_DATUM
aktiv
SHOW_OEL_STAND
aktiv
CC_NR_ROLLE
aktiv
HDC_ID_MONITOR
nicht_aktiv
DWA_VERBAUT
aktiv
TANK
wert_02
TIMEOUT_1
wert_01
TIMEOUT_2
wert_01
CRASH_TH_DIMMUNG
wert_01
CBS_EINH_15H
zeitbas
CBS_INTD_15H
wert_01
CBS_SCEN_15H
nicht_aktiv
CBS_STAT_15H
sperre
DSC_MIT_RPA_CC
nicht_aktiv
TNK_RW_VERBRAUCH
wert_02
BC_1_ENABLE
aktiv
CBS_EINH_16H
wegbas
CBS_SCEN_16H
nicht_aktiv
CBS_STAT_16H
sperre
CC_EHH_ANZ_MIN_TIME
wert_01
wert_01
FB_ALLE_TUEREN
aktiv
FB_FA_TUER
aktiv
HEIMLEUCHTEN_10S
aktiv
HEIMLEUCHTEN_150S
aktiv
HEIMLEUCHTEN_240S
aktiv
HEIMLEUCHTEN_40S
aktiv
HEIMLEUCHTEN_90S
aktiv
HEIMLEUCHTEN_AUS
aktiv
OHNE_QUITT_ENT
aktiv
OHNE_QUITT_VER
aktiv
QUITT_AKUST_ENT
nicht_aktiv
QUITT_AKUST_VER
nicht_aktiv
QUITT_OPT_AKUST_ENT
nicht_aktiv
QUITT_OPT_AKUST_VER
nicht_aktiv
QUITT_OPT_ENT
aktiv
QUITT_OPT_VER
aktiv
TAG_LICHT_AN
aktiv
TAG_LICHT_AUS
aktiv
TIPP_BLINKEN_1X
aktiv
TIPP_BLINKEN_3X
aktiv
ZV_VER_AUS
aktiv
ZV_VER_FAHRT
aktiv
ZV_VER_FAHRT_ZEIT
aktiv
ZV_VER_ZEIT
aktiv
CC_ID_AKTIV_01
wert_01
CC_ID_AKTIV_11
wert_01
GEAR_SHIFT_ALIVE
nicht_aktiv
GURT_ID_MONITOR
nicht_aktiv
SCHALT_PKT_BC
nicht_aktiv
nicht_aktiv
CC_ID_AKTIV_14
wert_01
DISP_TEMP_LEVEL
wert_01
DSC_ASC_CC
aktiv
GEAR_SHIFT_CSUM
nicht_aktiv
nicht_aktiv
MSA_ALIVE_MONITOR
nicht_aktiv
MSA_CSUM_MONITOR
nicht_aktiv
MSA_ENABLE
wert_02
MSA_ID_MONITOR
nicht_aktiv
nicht_aktiv
SOUND_SWITCH
aktiv
aktiv
aktiv
DIG_SPEED_PERMANENT
nicht_aktiv
RDC_DISP_SWITCH
aktiv
CC_ID_AKTIV_07
wert_02
nicht_aktiv
nicht_aktiv
DZM_DAEMPFUNG
aktiv
DZM_DISP_RPM
wert_01
aktiv
aktiv
SPORT_ANZEIGEDAUER
wert_01
nicht_aktiv
nicht_aktiv
VEH_MOD_ID_MONITOR
nicht_aktiv
GETRIEBE_TYP_KOMBI
automatik
CVM_ALIVE_ZAEHLER
nicht_aktiv
CVM_ID_MONITOR
nicht_aktiv
SP_ANZEIGE
wert_02
SP_ANZEIGE_1
wert_02
SP_ANZEIGE_2
wert_02
SP_ANZEIGE_3
wert_02
SP_ANZEIGE_4
wert_02
AO_CLOSED_ENABLE
aktiv
AO_DISP_TIME
wert_01
AO_ENABLE
nicht_aktiv
AO_OPENANI_ENABLE
nicht_aktiv
AO_OVERF_FREQU
wert_01
AO_OVERFANI_ENABLE
nicht_aktiv
AO_POINTER_SPEED
wert_01
AO_STARTANI_ENABLE
nicht_aktiv
DSC_VARIANT
wert_01
CC_ID_AKTIV_05
wert_02
WIPER_STAT_DISP
wert_01
compare the 2 codes file, find the following difference
original:
grundcode_var
now:
DATEN_INDEX
grundcode_var
Anyone could tell me the cause? and how to solve.
Thanks in advance!
theblackfalcon
Oct 11, 2015 09:49 AM
tag1260
Aug 24, 2015 05:52 PM
Dashdog
Aug 10, 2015 06:17 AM
