View Full Version : Electrical
Pages :
8]
- Electrical Moss Running Lights w/Angel Eyes" - has anyone used these?
- Electrical PIAA light kits
- Electrical Amperage Draw when "Asleep" and how long..
- Electrical Installing on/off switch, do I use POSITIVE or NEGATIVE wire?
- Electrical aftermarket fog / driving lights in stock MCS bumper cutouts?
- Electrical Stereo placement question
- Electrical taking apart the license plate light assembly
- Electrical warranty question
- Electrical Anyone have StealthOne installed?
- Electrical XM is Two Letters
- Electrical Best route for wire / rear wheel to fuse box (cross post)
- Electrical 122 Degrees Farenhiet?
- Electrical which small battery?
- Electrical Map/Cabin light access
- Electrical Quick Question on parking lights/turn signals
- Electrical Anyone put aftermarket HID/Xenon on thier 02-04 MCS?
- Electrical Boost Guage Lighting
- Electrical how do you remove the 5w parking light
- Electrical Hella "Angel Eyes" and manual switch question...
- Electrical Mikey's Bluetooth Phone I/F - audio quality?
- Electrical Problem with passenger side Window
- Electrical Brakelight Mod Question ?
- Electrical MCSa horn is Neg or Pos connection?
- Electrical Installing a Remote Starter - 03 MC
- Electrical speedo gauge
- Electrical MCAW problem (big problem)
- Electrical clear side markers with silver bulbs
- Electrical Cigarette lighter plug help...
- Electrical question about brakelight wiring?
- Electrical Interior Light Wiring Diagram
- Electrical I need really bright highbeams...
- Electrical Anyone have Viper installed??
- Electrical Which taillights
- Electrical Headlights
- Electrical Center vent gauge install.
- Electrical Finally had to install a GLI
- Electrical Stewart Warner Boost Gauge for $70 need pix of oem gauge & knowledge of max boost
- Electrical Radar detector false signal
- Electrical Help! OEM iPod Adapter : self install or dealer?
- Electrical Radar Detector Fuse Add-in
- Electrical Need help with a circuit to turn on my carputer
- Electrical OEM alarm questions
- Electrical wierd v1 / throttle interaction in the dark
- Electrical Don't buy Rocky Mountian Radar Detectors! Just my advice.
- Electrical where can i find: 12V unswitched in the boot area? (right trunk area?)
- Electrical Passport SR7
- Electrical Help wiring new Halo Lamps (!)(?)
- Electrical Radio powering off every 20 minutes.
- Electrical Anybody have a Clifford Matrix Alarm with 2-way Responder Tranceiver in their Mini?
- Electrical Retrofit BI-XENONS for a 06 cooper S'
- Electrical Moving the Run Flat Button
- Electrical Mini Madness 2 Lamp Rally Kit?
- Electrical How can I add another Cig Adapter?
- Electrical RetroFit OEM Foglights into '04 MC
- Electrical 05 xenons for an 04?
- Electrical 8 Psi Boost
- Electrical ScanGauge II - Anyone ever tried one of these?
- Electrical Driver's side auto-up stopped working
- Electrical Does a light turn on when the bonnet is open?
- Electrical Factory fog light default on?
- Electrical Help needed on wiring OEM driving lights from Mini Mania
- Electrical How many Pulses per Mile is the speed sending wire?
- Electrical Audible Tone
- Electrical Parking Light Install
- Electrical Help, no air out of vents!
- Electrical Cig Lighter Plug
- Electrical Bluetooth and SIRIUS Radio?
- Electrical Where can I run the electrical from engine to cab?
- Electrical Aux Input
- Electrical Fast blinking with LED turn signal bulb
- Electrical battery rating for MCS
- Electrical Looking for switched power fuse to tap
- Electrical PIAA 19227 Extreme Whites to replace stock reverse light?
- Electrical Palo London Ubermini Light Bar & Harness
- Electrical Parrot Bluetooth Ck 3100 / Any Experience In The Mini?
- Electrical I won a door prize...
- Electrical Making a fog lamp bracket
- Electrical Problem after wiring red rear fog light
- Electrical reverse light bulb replacement with PIAA on a '04 MCS
- Electrical help needed with tach and speedo problem
- Electrical Buying an '05 Mini: windows won't roll down? help?!
- Electrical Has anyone installed an aftermarket Tach?
- Electrical Is the MINI Electrical system touchy like BMW?
- Electrical Which sunroof wire has switched power?
- Electrical Brake light question
- Electrical Rear 3rd brake light mod
- Electrical Moss Mini riding light "angel eyes"
- Electrical Where to tap Power?
- Electrical MFSW Button swap
- Electrical Can you replace an '04 steering wheel (premium) with an '05+?
- Electrical Using stealth bulbs in clear tail lights?
- Electrical Two Questions about my Xenon's.
- Electrical Melted Wiring beneath Right Front Headlight?
- Electrical Flash2Pass
- Electrical Hacking steering wheel connections
- Electrical Boost Gauge Wiring
- Electrical Security
- Electrical retrofitting 05+ tailights? and additional mods
- Electrical Parking distance control switch
- Electrical Wiring lights question.
- Electrical Close windows & sunroof from key remote
- Electrical Whats better, Screamin demon or MSD coil pack????
- Electrical Antenna ripped out...
- Electrical A/C compressor no go
- Electrical turn signal prob
- Electrical OEM Driving Light Retrofit?
- Electrical Is there a kit to replace the front fog lights with driving lights?
- Electrical Replacing the horn
- Electrical Xenons not leveling
- Electrical Xenon headlights?
- Electrical xenon headlights?
- Electrical Relacing stock rally lights
- Electrical Ian's Window up mod
- Electrical MFSW, possible use
- Electrical Need bluetooth help
- Electrical Double-checking of the bulb size
- Electrical Rain Sensor retrofit
- Electrical Ignition switch hacking for remote close windows/sunroof
- Electrical Installing Aux Input by just splicing?
- Electrical I need DIY instructions for fitting HID/Xenon
- Electrical All electrical dead - need some help
- Electrical On/off switch
- Electrical Help on Side Fender reflector
- Electrical The yellow light at the end of my windsheild wipers flash when i start the car!
- Electrical Interior tube lighting
- Electrical Where to buyfind replacement sidemarker?
- Electrical Anyone use this gps?
- Electrical Aftermarket Security System
- Electrical Electrical shutdown...rant
- Electrical Defi HUD System?! anyone using it?
- Electrical Do I need to remove auto-up?
- Electrical Low Cost OBD II Reader and Resetter
- Electrical Bulb sizes for everything?
- Electrical iPod delay
- Electrical OEM Bluetooth Install
- Electrical radar detector recomendation
- Electrical Anybody using a battery cut-off switch?
- Electrical BC1 Module, driving lamps, rewiring, and old Porches...
- Electrical Questions about Ian's Auto up/DSC
- Electrical Lightweight Battery Box Fabricator???
- Electrical Using the boot power outlet for power tools
- Electrical will the oem xenon lights bolt up?
- Electrical Coolant temp warning light wiring
- Electrical Will these tail lights work on an '05?
- Electrical Retrofit pre '05 clock
- Electrical Install side-reflectors
- Electrical Question about a project I'm working on
- Electrical My rediculously complicated lighting project is almost done!!!!
- Electrical FYI adding a circuit - alternative to add a fuse ...
- Electrical Help - LED bulbs glowing faintly when car is off ??
- Electrical add a circuit
- Electrical Wireless internet in Mini S 24/7
- Electrical Wiring Question
- Electrical Bluetooth AND iPod
- Electrical Horn wiring - connector question
- Electrical Broke an oem driving light need advice.
- Electrical Blitz Power Meter
- Electrical Parrot install using newministuff harness
- Electrical i just install oem alram for 05 cooper s,
- Electrical Harman Kardon: could I fit one in my MCS
- Electrical Fabric over battery terminals ok?
- Electrical Fogs + Highbeams Possible?
- Electrical Removing snap splice wire connectors...
- Electrical Automatic Headlights- How do they work?
- Electrical Driving lights fuse blowing?
- Electrical Moisture invading my side lights!
- Electrical pass. side brake light not working.
- Electrical MCAW basic install
- Electrical Can anyone layout and fab a PCB?
- Electrical Replacing driving light bulbs
- Electrical Which fuse is for cig lighter???
- Electrical Dash harness ?
- Electrical Can both inside & outside auto-up modules be used together?
- Electrical Added some driving lights
- Electrical Battery harness Q, MCS->MC
- Electrical Another Bulb Question
- Electrical tb question
- Electrical help on routing a wire
- Electrical HELP! My stereo no longer recognizes my Aux Input.
- Electrical Extra 12Volt Plug
- Electrical Can someone help me with 2005 fuse layout?
- Electrical Thought of a use for dead button on two spoke mfsw
- Electrical WTK: H3 Driving Lamps
- Electrical Rear Seat Power Outlet Location
- Electrical 06 DIY Alarm System
- Electrical Not the usual BRAKE light mod
- Electrical Computer concerns
- Electrical Headlight Lamp Replacement
- Electrical code reset?
- Electrical iPod hookup in a 2002
- Electrical My first mod. Ever.
- Electrical Radar reads Ka band 100% of the time
- Electrical throttle body
- Electrical Another driving light install question.
- Electrical 8000k!!!
- Electrical Weird Speedo Thing
- Electrical Another rear fog light Q (and possible solution)
- Electrical Which yellow bulbs?
- Electrical 05/06 Rear fog mega mod EXTREME
- Electrical Engine Start button from Moss in a 2005 Cooper?
- Electrical Questions about iPod in a Mini!
- Electrical Chirp without alarm system?
- Electrical gauge led bulbs
- Electrical What fuse to tap for Cig/Power
- Electrical Driving Light Brackets
- Electrical Santa brought me OEM driving lights...
- Electrical Sunroof question
- Electrical Cigarette lighter doesnt work with compressor?
- Electrical Defi-Link meter help
- Electrical Schumacher 6000a battery charger, do you own one?
- Electrical BiM-COM
- Electrical What Are Those Bulbs!????
- Electrical Need pictures of PIAA fog light installs!
- Electrical Disable your Seat Belt warning chime!!!
- Electrical Bluetooth Basics?
- Electrical Harmon Kardon iPod Controller
- Electrical Nav System Question
- Electrical How do I replace side turn indicators?
- Electrical Lidatek LE-30...
- Electrical CK3100 or 3000EVO
- Electrical Factory Alarm Install...
- Electrical Fuse F-37?
- Electrical Black or smoked tail lights - pics pls?
- Electrical Convert from blinkies to strobe flashers
- Electrical Windows Up module
- Electrical Those two useless buttons
- Electrical Cigar Lighter / Power Outlet
- Electrical Interior Digital Camera Recommendations
- Electrical Factory iPod adapter- does it charge when the car is off???
- Electrical "New Autoup module"???
- Electrical Remote Control Auto Window Up Module
- Electrical LED Taillights
- Electrical Wiring a boost gauge
- Electrical Rear Brake light modification
- Electrical Terk XMDirect Smart Digital Adapter - Anyone Install Yet?
- Electrical Rear Fog Question
- Electrical help with fog lights ?
- Electrical Yellow fogs or super whites?
- Electrical Driving lights??
- Electrical Mirror Lights mod—JAPAN
- Electrical Xenon Fog lights?
- Electrical Digital Readout
- Electrical Satelite Radio/Car Alarm/Auto Starter
- Electrical Auto dimming mirror with Home Link retrofit?
- Electrical Retrofit Starter Button
- Electrical Just finshed installing my PIAA Driveinglamps
- Electrical HOW TO:Change H11 bulbs Fog light bulbs??
- Electrical Radar Detector Interference?
- Electrical Anyone upgrade their H/K speakers?
