Electrical 122 Degrees Farenhiet?
Old Aug 2, 2006 | 12:06 PM
not-so-rednwhitecooper
I think i have a temp sensor problem....
After i had my front bumper off for a bit, I threw it all back on and hopped in the car, and my temp was reading 122 degrees.
I dissconeccted the battery, and hooked it back up, then hopped in the car.
Turned car on and watched the temp sensor climb from 0 degrees all the way to 122 and stop.
Does the sensor unplug somewhere under the bumper? I looked, but I probably missed a connector and thats why its climbing like that...
Old Aug 2, 2006 | 01:12 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
Sounds like an unplugged sensor, or the wiring got pinched or damaged. It will read at max (122 deg) if that's the case.
Old Aug 2, 2006 | 01:19 PM
goldcountrymini's Avatar
goldcountrymini
Good to know... Is that the max the temp gauge will go in general?
Old Aug 2, 2006 | 01:31 PM
Greatbear's Avatar
Greatbear
As far as I know, yes.
Old Aug 2, 2006 | 01:34 PM
chows4us's Avatar
chows4us
The sensor is attached to the front plastic bumper facade. On the right side a bit high up. Easy to miss. You most likely unplugged it.
Old Aug 2, 2006 | 01:37 PM
But does the sender itself unplug from the wiring?
I know where it all runs, and i know i didnt pinch it, so it has to plug in somewhere.
I dont run a lower grille, so mine is in a custom mount on the aluminum bumper suport itself.
Old Aug 2, 2006 | 01:49 PM
chows4us's Avatar
chows4us
Yes, if I remember correctly, the unit was unplugged on mine and they had to replug it in. Maybe you lost the sensor?
Old Aug 2, 2006 | 01:53 PM
UKSUV's Avatar
UKSUV
The sensor has a polug on it. It is mounted on the top middle of the bumper. I had something hit my car once and knocked it off. BTW, my temp gauge read 122 degrees the other day....but it wasn't malfunctioning! Arizona is HOTT!
Old Aug 2, 2006 | 04:21 PM
DragonSlayer's Avatar
DragonSlayer
122 Deg F; Not than unusual in Arizona.
But its a dry heat.
Sensor is only a few inches of the hot asphalt.
Old Aug 2, 2006 | 04:43 PM
Agro's Avatar
Agro
Coordinator :: Sin City MINI Club & AMVIV
Yeah, I've seen 122 on my sensor. In the last couple of weeks even. What makes you think that's a problem?
Old Aug 2, 2006 | 06:40 PM
AntiqueCarNut's Avatar
AntiqueCarNut
But its a dry heat.
I was in Phoenix a couple of weeks ago. Rental car thermometer read → 127 ← !
I hear for '07, MINI will have an option for a fourth digit on the outside air temperature display - only for Nevada, Arizona, Texas and Florida cars .
Old Aug 2, 2006 | 07:08 PM
Motor On's Avatar
Motor On
Maybe your getting the heat index if the Chicago weather expanded in your direction.
Sounds like something didn't get plugged back in.
Old Aug 8, 2006 | 11:20 AM
acitydweller's Avatar
acitydweller
If it were celcius, your car would be molten lava
Old Aug 8, 2006 | 05:44 PM
qwertmonkey's Avatar
qwertmonkey
Wow. Nice observation.
Old Aug 16, 2006 | 03:00 PM
eskay's Avatar
eskay
Is it 122 F when the sensor is unplugged or damaged as default? Or 0? I have it plugged into something but im not if its damaged or just not plugged in correctly..
Old Aug 17, 2006 | 03:38 PM
DarkMiniCooperS's Avatar
DarkMiniCooperS
four digit temp display... Could be useful in Quebec's Winters too
Keet
Suspension
Aug 30, 2016 03:46 PM
conky
Apr 6, 2016 08:03 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
olson187
Sep 18, 2015 10:26 AM
PSU 98
Sep 11, 2015 11:20 AM
