Electrical pass. side brake light not working.
Old Feb 4, 2006 | 12:46 PM
chiquivw's Avatar
chiquivw
ok guys i ready to commit a random act of violence on my car
passenger side brake light is not working . i have checked all fuses,engine bay and on driver side kick panel, checked the lights by putting theme on driver side and they worked just great ,what next? please do not ask me to take it to the dealer ,i would like repair this my self and not have drive for an hour to my dealer. this is a 2004 S. are there any individual ground wires for each side ? please flood me with info. i would like to fix this my self and "more importantly" learn something from this ..
Old Feb 4, 2006 | 06:58 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
There could be a problem with the wiring. Try swapping the entire bulb holder from one side to the other. If that does not fix it, trace the wiring back to the BC module. Each side'e brake light has a separate controller output at the BCM. If there is no output from that pin on the BCM, then the driver IC inside the module has gone bad. It is possible to replace these, but it's a job for those who are familiar with surface-mount microelectronics repair.
Did you have a 'brake light mod' on this car?
Old Feb 5, 2006 | 10:36 AM
chiquivw's Avatar
chiquivw
yes i swapped the entire bulb holder and it did worked . what is the BC module and where is it ? and where is BCM ? and what does bmc stand for? yes i do have the clear tail light assembly and i did the fog light mod by using the the jumbo paper clip method . i have removed them thinking that might have screwed things up . however the other side fog light was still working ok .????? what now???? hey thanks for your input .
Old Feb 5, 2006 | 12:37 PM
Greatbear's Avatar
Greatbear
The BCM is the "Body Control Module", the computer responsible for coordinating the functioning of all the body-related electrical items (as opposed to the engine's ECU). This module is responsible for almost all exterior and interior lighting, the windows, locks, alarm system, etc. This module is located under the right side kick panel under the dash.
Old Feb 5, 2006 | 12:59 PM
J0kER's Avatar
J0kER
is it the "brake light mod" causin' this ????????
crap!!
it happened to me aswell, my drivers side 'brake light is not werkin' but the runnin' lights and flashers werk fine???? i dont have the paper clip mod but the in line resistor mod jump wire, same thing jus a different way of doin' it!!
cm.d
Aug 19, 2015 08:51 AM
Terry Gallentine
Aug 11, 2015 03:31 PM
OutMotoring
Aug 6, 2015 09:32 AM
