Electrical ScanGauge II - Anyone ever tried one of these?
Old Jun 7, 2006 | 06:36 AM
theroyalwe's Avatar
theroyalwe
I got an email today and this product caught my eye... Scangauge II
Has anyone ever seen this before? looks pretty interesting... theoretically it could be used in place of the OBC and also to read any trouble codes that come up.
anyone?
Old Jun 7, 2006 | 07:59 AM
curv872's Avatar
curv872
The MINI isn't listed on the compatibility list :-(
Old Jun 7, 2006 | 08:02 AM
Dr Obnxs's Avatar
Dr Obnxs
One guy I know of is using it...
It's a lot like the CarChip E/X unit, but a bit less. Doesn't need Mini compatibility, as it uses standard OBD-II commands....
I didn't use this one specifically, but two things to look for:
1) How many different OBD-II sensors does it support and
2) How many can it process at one time.
The CarChip had about 20+ variables that it could read, but only 4-6 at a time, at a rate of one reading every 5 seconds, so it was slow.....
Matt
Old Jun 7, 2006 | 12:39 PM
dmh's Avatar
dmh
I have one
Matt
I originally bought it to read trouble codes on a Volvo. I never knew it capabilities. I have it setup on my Mini dash to read boost, water temp (the gauge sucks), intake temp, and timing (though I am still trying to figure this one out). It reads fast and can display 4 readings at a time. I don’t have the manual in front of me but you can go to their web site and there you can find all that it can read. Data logging will be available in August.
Old Jun 7, 2006 | 03:23 PM
jchanger's Avatar
jchanger
I'm gonna go out on a limb here and say Minis are included in "ALL EXCEPT MERCEDES"
Old Jun 7, 2006 | 07:28 PM
theroyalwe's Avatar
theroyalwe
ohhh... that's pretty cool! I may have to check it out.
Old Jun 8, 2006 | 09:09 AM
speednut's Avatar
speednut
Hmmm, I've been trying to figure out a nice way to determine the engine temp; Nav screen means you only get an idiot light for over temperature. It's impossible to really know when your car has warmed up to normal operating temp so you can start driving it more enthusastically. Looks like this might fit the bill.
Thanks for the goto theroyalwe!
Old Aug 15, 2006 | 01:22 PM
BBCooper's Avatar
BBCooper
I just got one of these... I really like it.. I use it to display the same readings that dmh referenced above.. I have also been using it to help others debug SES lights.
As a plus it can change the backlighting to match (pretty close) the orange illumination of the MINI dash..
One "gauge" that does not work with the MINI is the FPR - fuel pressure regulator. But the web site states this feature does not work on most cars..
So far... I like it alot..
Old Aug 15, 2006 | 01:25 PM
Dr Obnxs's Avatar
Dr Obnxs
There is a reason for this...
I don't think we have one! There's a regulator, but it's passive (ie, no electronics) and I don't know of any fuel pressure reading that you can get via diagnostics without using an external guage.... But I've been wrong before.
Matt
Matt
Old Aug 16, 2006 | 07:57 AM
Z-Mini's Avatar
Z-Mini
Would this unit fit just below the MINI Switch panel? Got any pics of your installation?
Thanks-
Randy
Old Aug 16, 2006 | 10:13 AM
BBCooper's Avatar
BBCooper
Yup it fits nicely below the toggle switches with about 1" on either side.
I might be able to get pictures later today...
Old Aug 16, 2006 | 10:56 AM
Z-Mini's Avatar
Z-Mini
Thanks for the information. Pictures would be great if you could take the time.
Thank you-
Randy
Old Aug 16, 2006 | 12:32 PM
BBCooper's Avatar
BBCooper
Here is a pic..
Sorry for the shakey image... It from my camera phone. Just ran out quickly at lunch.
Enjoy
Attached Thumbnails ScanGauge II - Anyone ever tried one of these?-scanguageii_b.jpg
Old Aug 16, 2006 | 12:35 PM
Z-Mini's Avatar
Z-Mini
Enjoy
Thanks for the photo. I like the look!
-Randy
Old Aug 16, 2006 | 01:02 PM
JoeCool's Avatar
JoeCool
Can you see the display down there?
I was thinking of placing a scangauge there as well, but I didn't know if the display would be visible at that angle. How's the visibility?
Old Aug 16, 2006 | 01:18 PM
BBCooper's Avatar
BBCooper
Visibility
I like it..
As a side note I was debated on putting the gauge under the toggles or on the dash to the left of the steering wheel.. But the "stealthy" look under the toggles keeps winning me over... Plus if I remove it for any reason the velcro is not visible..
Back to the visibility... At night it is very easy to see becasue of the backlight.. During the day it is fine too - the backlighting does not show up that well.. The characters are very tall and wide enough for good contrast. There are times I get a little concerned looking down that low in the cabin while driving.. But I don't want it in my line of sight either... After the first day and the "new" factor wears off.. I find the numbers (except MAP) don't change that much to warrant having it in my line of sight while driving..
The other thing that is nice - it is very easy to reach the buttons from the grearshift (Alta SSK) to change selections..
Enjoy
Old Aug 16, 2006 | 02:03 PM
JoeCool's Avatar
JoeCool
Thanks, that answers a lot! Looks like it's time to pull the trigger on another toy...
Old Aug 17, 2006 | 05:41 AM
jwardell's Avatar
jwardell
Does this have the ability to reset a CEL?
Old Aug 17, 2006 | 10:38 AM
BBCooper's Avatar
BBCooper
I have not had an DTC on a MINI near me to test the ScanGaugeII... But the documentation says it does...
Any ideas on how to create a "safe" DTC error to try it out?
Old Aug 21, 2006 | 12:42 PM
Dr Obnxs's Avatar
Dr Obnxs
Up plug you tb...
and try to start you car. You'll get tons of lights!s
Matt
Old Aug 21, 2006 | 12:50 PM
BBCooper's Avatar
BBCooper
That would work ;-)
ah .. Well that would create many lights & codes.... I was looking for some "safe" ways to throw a code.
On a side note I was able to clear a MINI P0335 code... See this thread for more details on that "fun"...
So far I have plugged this reader into several MINIs, a 2000 Ranger, 04 Saturn, and 04 Honda CRV... Every time the unit works great and was able to use the gauge side easily.. Even pulled & cleared codes on the Saturn..
Thanks..
Blair
Old Aug 21, 2006 | 12:57 PM
Dr Obnxs's Avatar
Dr Obnxs
Than the EPA for all that!
OBD-II standard is a STANDARD! That's why a scanner will work on all cars... And it was mandated by your friendly government. Without the mandate, you wouldn't have OBD-II or ECU reflashes (the ability to upload new operational maps to the car is part of the mandate!) So for all you "gov is nothing but wasting money and overregulation" think again. Without it, we'd still be tuning carborators!
Matt
Old Aug 21, 2006 | 01:13 PM
blue agave's Avatar
blue agave
Those were the good ole days Still have my draft gauges for Stromberg sidedrafts
Old Sep 19, 2006 | 09:15 PM
OzMini's Avatar
OzMini
Hi everyone,
I also just bought the Scangauge based on this thread but I just can't get it to synch - it just shows "connecting..." I have tried to manually force it to the ISO setting but still no luck. I suspect my car's OBD II connector may be faulty or the fuse to it is out - does anyone know which fuse it is hooked up to? Or which pin carries power?
Any other troubleshooting ideas welcome. I did by the way check to see that the connector is well seated.
Cheers
Old Sep 20, 2006 | 07:49 AM
BBCooper's Avatar
BBCooper
Not to ask the simple things..
Sounds like you have it plugged in correctly..
But for me to get past the "Connecting" message I have to turn the key to the "ON" (not starting) position. Then in a few seconds the ScanGauge should connect up and display the main window..
Other question what year is your MINI.. I have used this easily on '04 & earlier MINI's but I don't think I have tried it on the '05 or higher models.. I think MINI changed the ECU (type, speed??) for the current models..
Hope that helps, if not post back .. I have an '06 MINI close by I could test my ScanGaugeII with...
