Electrical ScanGauge II - Anyone ever tried one of these?
Old Jan 28, 2008 | 08:10 AM
  #76
thulchatt's Avatar
thulchatt
I got mine from the Toyota group buy a couple of days ago.
Great tool. I have the OBC but am starting to calibrate the Scan Gauge and expect better information. Then what do I do with the OBC
If you want the discount price you need to order by Thursday on the Toyota group buy.
Old Jan 28, 2008 | 10:15 AM
  #77
locogringo's Avatar
locogringo
I have been looking at this devce for a while. I have seen it mentioned on other threads on this forum. This device can read hp. Scan Gauge says that it reads gross hp and not net hp as they can't calculate loss for a/c, alternator, etc. Pretty cool. I am buying one.
Old Jan 30, 2008 | 08:49 PM
  #78
chpsk8's Avatar
chpsk8
Last call! One day left to get in on the Toyota Group Buy!
Tough to find for this price anywhere right now.
Old Feb 2, 2008 | 10:06 AM
  #79
Mini-RI's Avatar
Mini-RI
Easily the best thing I have done to my MINI so far. And its a tie with my Whalen **** for ease of install! I absolutely love it.
I installed mine under the center tower. Certainly not line of sight, but still very easy to glance at and read the data.
Old Feb 6, 2008 | 09:24 AM
  #80
BlimeyCabrio's Avatar
BlimeyCabrio
So here's a question for the geniuses (DrO and DrPhil - y'all listening? )...
Does the MINI have any "hidden" or "additional" data that could be read using the Xgauge capability of the ScanGauge? This PDF shows HP, Fuel Trim and O2 sensor data being somewhere universal... and shows some additional data available on Ford and GM vehicles... just curious if there might be some other stuff out there we could be reading that we don't know about yet...
Also - the Add-a-Gauge function has a "MTH" element - math? - that provides some method to scale, offset and display the data... I'm wondering if there would be away to use this to create an Xgauge that offsets the MAP reading by the the approximate atmospheric pressure to display an approximate "gauge" boost reading... I know it would be static - that the pressure would have to be embedded in the Xgauge setup data vs. reading live pressure wherever you are...
Thoughts?
Old Feb 6, 2008 | 09:29 AM
  #81
Eric_Rowland's Avatar
Eric_Rowland
Got my gauge, plugged it in, and twenty minutes later it started speaking in tongues. On the drive home that night it was lit, but the screen was blank.
Plugged it in again last night and now it seems to be back to normal. Anyone had infant mortality issues with theirs?
Old Feb 6, 2008 | 02:21 PM
  #82
thulchatt's Avatar
thulchatt
Originally Posted by Eric_Rowland
Got my gauge, plugged it in, and an twenty minutes later it started speaking in tongues. On the drive home that night it was lit, but the screen was blank.
Only been using it two weeks but no problems yet.
I just need to learn how to use all of functionality.
Old Feb 6, 2008 | 02:25 PM
  #83
HighLife4136's Avatar
HighLife4136
Nope, the only oddity was when my 3.5 year old original battery finally gave up the guage was on when I opened my door...nothing like that since...about 3 months since I replaced the battery.
Old Feb 6, 2008 | 03:12 PM
  #84
BlimeyCabrio
Check THIS OUT!!!!
How to program an Xgauge as an approximate boost gauge (instead of MAP)... going to try it now...
Old Feb 6, 2008 | 03:16 PM
  #85
HighLife4136
Originally Posted by BlimeyCabrio
Check THIS OUT!!!!
That's cool and all, but I just subtract 14.1 and continue to be a lazy SOB
Seriously though, nice find
Old Feb 6, 2008 | 03:22 PM
  #86
BlimeyCabrio
Just tried it - IT WORKS!
Took 2 minutes to program it and called it BST... If I really wanted I could setup multiple XGauges for different elevations (one for home, one for the track, one for the Dragon, one for my high elevation runs, etc.)...
Old Feb 6, 2008 | 06:26 PM
  #87
Dr Obnxs's Avatar
Dr Obnxs
Sorry, haven't posted here in a while...
But all I can add (since I don't own one and never will) is that to do a nice permanant mount you can take the OBD-II connector center part out of the frame so that the connector doesn't stick down. If you take out the knee bolster or euro parcel shelf, you'll see a blue frame at the back of the OBD-II connector. Push the back of this towards the firewall, it will move but won't come off the connector housing, then you can press the connector center up from below and out of the housing. Then it will go into the cable connector and you can wire-tie it up and out of the way. If you take your time, you can put it where you can still disconnect it from the cable connector if you want to use other tools with the diagnostic port.
For those looking on the R56, I'd check around the underside of the dash on the driver side. It has to be within about three feet of there by law, so it's pretty much always in that area. Open the door real wide, slide the seat back, and get your head in there to look around. Shouldn't be too hard.
Matt
Old Feb 6, 2008 | 06:43 PM
  #88
MINIGURU@WAY MOTOR WORKS's Avatar
Vendor
I'm glad you guys are liking them. If there is more people wanting them I could put together a MINI group buy. Let me know.
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
Alta,M7,Helix,Wilwood,H-sport,Milltek,CROSS,Craven,DDM,H&R,Megan,Carbotech,EBC,Forge,TSW,Powerflex
Old Feb 6, 2008 | 08:49 PM
  #89
chpsk8's Avatar
chpsk8
Very cool Blimey! I must admit that I still have mine in the box sitting on my bar. My Mini is stashed away until the snow melts. I can't wait to get this installed though. I want to see boost and volts for sure. I'm hoping there will be other hacks that come up as this gauge continues to get smarter.
Old Feb 7, 2008 | 06:59 AM
  #90
thulchatt's Avatar
thulchatt
This would be a great idea.
For those of you who don't have one yet it is a very small investment for the info you get.
I got one mostly to watch the temp but I am enjoying the ton of information I can see while I drive, sensors, trip, MPG, costs, etc...
Also, one of the simplest installs you could ever ask for.
Old Feb 8, 2008 | 09:38 AM
  #91
whiteyanderson's Avatar
whiteyanderson
i'd be down for this group buy i think. been eyeing it for awhile, not sure if it would permanantly mount it but, i do think i would like it as a nice code reader and reset tool with a nice set of extra features.
question- i would really like it if i could use it on the wifes pt cruiser in addition to my MINI. researching the website awhile back- i think it states it will work on just about every car (maybe not a jeep). does anyone know if it WOULD work on her car? my MINI is a 2003 R50, her pt is a 2003 as well. so am i right in assuming i should be able to use it on both with the stock obd connector? or would i need another adaptor?
Old Feb 8, 2008 | 09:45 AM
  #92
Vendor
Well the buy is on then. They will be $150.
As for your wifes PT Cruiser it should work no problem. My dad swaps his from his Geo to Honda weekly.
Old Feb 8, 2008 | 09:48 AM
  #93
whiteyanderson
put me on the list then, and keep me posted when you get enough of us to to make this worthwhile for you to do. i assume $150 is the shipped price? i'm in socal so i should avoid taxes? thanks.
Old Feb 8, 2008 | 04:30 PM
  #94
HighLife4136
I tried the horsepower XGuage today and the silly thing was reading north of 390 horsepower
We may need to wait for ScanGuage to come out with programming specific to the MINI for this to work.
Old Feb 9, 2008 | 05:23 AM
  #95
HighLife4136
Originally Posted by HighLife4136
I tried the horsepower XGauge today and the silly thing was reading north of 390 horsepower
We may need to wait for ScanGauge to come out with programming specific to the MINI for this to work.
Apparently this has something to do with me not ever setting up my fuel parameters on the scangauge....what's MPG anyway? I'll get to it today and chime back in with comparisons from my last couple dynos.
Old Feb 9, 2008 | 07:52 AM
  #96
Vendor
Also set up your correction factor for MPH. The HP guage wasn't too bad when I had all the parameters set. Occasionally it would spike and say something crazy, but most of the time it seemed pretty close.
Old Feb 9, 2008 | 09:32 AM
  #97
brownflyer's Avatar
brownflyer
Add me to the list.
I've beem eyeing this thing for many months now and you guys have finally convinced me.
Old Feb 9, 2008 | 04:50 PM
  #98
HighLife4136
Yep, that helped a bit! The freeway where I'm at was closed today so I only had real opportunity to hit redline in 2nd gear, giving a reading of 206 hp. The hp at idle reads between 4 and 5 hp, and usually at 4.9...the hp while coasting in gear reads 0 for all you MPG nitpickers
Old Feb 10, 2008 | 09:21 AM
  #99
bad venge's Avatar
bad venge
Glad I pulled mine out of the Rover when I went to trade it in .... Getting it set up correctly is the most challanging part ,Took me months to get it right ... So I'm guessing it'll be the same in the mini
Old Feb 12, 2008 | 05:03 AM
  #100
BlimeyCabrio
My HP gauge seems *relatively* reasonable most of the time - and yesterday I hit 504HP, so it looks like my mod plan has worked out OK.
