Electrical Driving lights fuse blowing?
Old Feb 7, 2006 | 03:52 PM
SonicVI's Avatar
SonicVI
I turned my driving lights on last night and they didn't come on. I checked the fuse and it was blown. I replaced it today and it immediately blew. I installed them myself about 3-4 weeks ago and haven't had any trouble until now. What are some things I should look for to fix the problem? The only thing I can think of and will check first is maybe a hot lead inside one of the lights is making contact with ground through the light housing. I didn't cover the connectors with tape or shrink tubing so one might have come disconnected and is touching the housing. Any other ideas? They're the OEM Mini lights btw.
thanks,
Daniel
Old Feb 7, 2006 | 04:40 PM
seeya's Avatar
seeya
Short
That's a good place to start, aslo check the wires coming out from the light through the threaded post, when you are taking the light a part.
Crashton's Avatar
Crashton
That's a good place to start looking. Also check the wiring back to the switch. It may have chaffed causing it to go to ground. Did you use a grommet were you pulled the wire through the firewall?
Chuck
Old Feb 7, 2006 | 10:13 PM
SonicVI's Avatar
SonicVI
I was correct. I taped up the connectors in both lights and they're working again.
Old Feb 8, 2006 | 03:10 PM
Crashton's Avatar
Crashton
I'm glad it was an easy fix for you. Those are the best kind.
Chuck
Old Feb 20, 2006 | 05:56 PM
m_goose66's Avatar
m_goose66
I was reading your post and I have the same problem with my lights not working. Which fuse is it?
Old Feb 20, 2006 | 06:37 PM
Rawhyde's Avatar
Rawhyde
Probably the one in the little fuseholder added to the area in front of the driver's side cowl vent. This fuse holder is typically loose and flops around everywhere in this little compartment.
Rawhyde
Old Feb 20, 2006 | 06:39 PM
SonicVI's Avatar
SonicVI
Yes, that's the one.
m_goose66's Avatar
m_goose66
Thank you for the info I will locate that and check it out! hope it works
Old Feb 20, 2006 | 06:47 PM
SonicVI's Avatar
SonicVI
It's connected directly to the main fuse box by a thick red wire, btw.
Old Feb 20, 2006 | 06:49 PM
m_goose66's Avatar
m_goose66
All right, just checked it out. And darn, it was good, and I checked all the wiring out with my multi-tester, all ok. I winder if it could be the switch?
Old Feb 20, 2006 | 08:24 PM
SonicVI's Avatar
SonicVI
Does the switch light up? Do the lights even flicker when you hit the switch? Sometimes I have to press mine a few times before the lights will come on. It's a pretty cheap switch. I'd check the switch with your meter.
Old Feb 21, 2006 | 11:29 AM
Agro's Avatar
Agro
Coordinator :: Sin City MINI Club & AMVIV
Depends on your definition of cheap. I think MINI wanted something like $70 for a new switch.
Old Feb 21, 2006 | 11:36 AM
SonicVI's Avatar
SonicVI
Cheap as in not high quality
Wohnson89
Jun 10, 2020 04:53 AM
ryGuyMCS
Oct 20, 2015 02:24 PM
JHolland
Aug 13, 2015 10:47 PM
Red Raven
Aug 11, 2015 04:48 AM
nismo4life
Aug 5, 2015 08:31 AM
