Electrical Removing snap splice wire connectors...
Old Feb 9, 2006 | 11:08 AM
TonyB's Avatar
TonyB
When there's a need to remove one of these (blue, far left),
what's the best method for covering the exosed bare wire caused by the connector? I'm thinking that there might be some kind of liquid that solidifies as an insulator... I'm using electrical tape for now, but with a thin wire, in a tight location, I know that I'm not doing a very good job...
Thanks much for your input!
Old Feb 9, 2006 | 11:28 AM
Partsman's Avatar
Partsman
Legion_of_Doom
Can't see the pic Tony.
Are you referring to a "scotch lock"?
There is liquid electrical tape, and of course heat shrink tube.
Old Feb 9, 2006 | 11:32 AM
Kentiki's Avatar
Kentiki
Liquid electrical tape. Any hardware store should have it. It's great for difficult to reach spots or delicate wires.
Ken
Old Feb 9, 2006 | 12:02 PM
TonyB's Avatar
TonyB
sorry about the pic... here's another one, not the best shot though:
Usually get a small box of these for a couple of bucks...
PARTSMAN109 & Ken, thanks! Something Home Depot should have? I have shrink tubes, but that requires at least one end of the wire to be free... One of the wires in on the coil (removed & sold a shift light)...
Old Feb 9, 2006 | 12:12 PM
francisk's Avatar
francisk
How about Glue gun?
Old Feb 9, 2006 | 12:19 PM
Partsman's Avatar
Partsman
Legion_of_Doom
Home Depot should have it. Your local hardware store too.
Old Feb 9, 2006 | 01:02 PM
TonyB's Avatar
TonyB
I'll stop by on the way home... Thanks again!
Old Feb 9, 2006 | 01:12 PM
Kentiki's Avatar
Kentiki
Home Depot for sure does, and in a few colors. Plus, it smells great!!!
Old Feb 9, 2006 | 03:35 PM
petecrosby's Avatar
petecrosby
I don't use them because the connections often go flakey. I trim the
insulation, solder the new wire, and then either heatshrink or tape it.
Old Feb 9, 2006 | 03:49 PM
TonyB's Avatar
TonyB
I agree with that! I use tha Add-a-Circuit/fuse's when I can now...
Old Feb 9, 2006 | 05:47 PM
petecrosby's Avatar
petecrosby
To answer the original question, using a piece of electrical tape is good.
You could also use some RTV, which should insulate well and hold up
fine. Just clean the wire with some brake cleaner or alcohol first so that
the RTV adheres well. You could apply it with a small stick or a Q-tip.
Old Feb 9, 2006 | 07:39 PM
TonyB's Avatar
TonyB
Pete, thank you. I picked-up some of that liquid tape tonight (about 6 bucks), and I can see where this will come in handy on a few projects, and not just the MINI. I like the Q-tip idea as the included applicator is a bit on the large side... Thanks again everyone!
minimofo
Nov 5, 2015 08:40 AM
siriuszero
Sep 17, 2015 04:41 AM
greekzilla
Aug 23, 2015 03:44 PM
Getrieben
Aug 15, 2015 09:09 PM
minipopkart
Aug 13, 2015 05:22 AM
