Electrical HOW TO:Change H11 bulbs Fog light bulbs??
Old Oct 30, 2005 | 06:08 PM
ilovepanerai's Avatar
ilovepanerai
Hi all,
Like to get any advise as to how to change my H11 fog lights bulbs?
Thinking of upgrading to whiter bulbs but no clue how to get the stock ones out.
I have the front aero front bumper, does one have to take out the front bumper to take out the fog light bulbs?
Thanks in advance for any inputs.
Cheers
Old Oct 30, 2005 | 06:11 PM
Battle Cattle's Avatar
Battle Cattle
remove the front bumper... 4 bolts if memory serves correctly and you will see all the connectors to the fogs, turnsignals and the sidemarkers... should be self explanitory from there...
-Josh
Old Oct 30, 2005 | 07:11 PM
ScuderiaMini's Avatar
ScuderiaMini
To reach the front fog lights, you will have to remove the front bumper, I could not figure another way.
Old Oct 30, 2005 | 07:54 PM
ilovepanerai
Hi Guys,
Thanks for the inputs, was really hoping do not need to take the front bumper out for taking out the fog lights bulbs...
Really no way around it? .....does anyone that have the bently manuels shed some light on this?
thanks..
cheers
Old Oct 30, 2005 | 07:59 PM
Battle Cattle
the lights are BEHIND the bumper... sooo no... unless you remove your wheel well and squeeze you hand in there and do it blind... but 4 bolts COMMON! its like a 3 min removal process. mine is longer since i have ALTA rally lights which only take me 10 mins to remove my front bumper...
-Josh
Old Oct 30, 2005 | 08:07 PM
ScuderiaMini
you can litterally remove the front bumper in less than 10 min. it is very easy. BTW, I am thinking of yellow fog lights, they work better than anything else in fog, but I do not know the cool factor.
Old Oct 31, 2005 | 01:31 PM
chows4us's Avatar
chows4us
Yes, there is. The manual says to take off the tire and the front fender lining, then just do what you want. It has pics and everything. I dont know about the clips for the fender lining if you can reuse them or not. Now which method is simpler, dont know but there is another way.
Old Nov 6, 2005 | 12:40 PM
shooler's Avatar
shooler
No need to remove the front bumper. Turn the wheels so you gain access to the fender liner and remove the clips (if your careful you can reuse them). Pull the liner out a bit and remove the bulbs from the fog housing. It's much easier than removing the bumper. I changed both bulbs in under 10 minutes.
Old Nov 6, 2005 | 01:18 PM
kapps's Avatar
kapps
I tried turning the wheel but couldn't get to a couple of the plastic "screw clips" holding the fender lining on. I ended up taking the wheel off and it made it a lot easier. You don't need to remove all the clips to get to the bulb, just enough to pull the lining out. FYI, the screw in part of the clip is VERY easy to strip. Also, hold the outer portion of the clip so it doesn't move while your unscrewing the inner part. Take your time with it, it's pretty easy.
Old Nov 8, 2005 | 07:31 AM
Snappychip's Avatar
Snappychip
Ok so what kind of bulbs are there in H11? Is there such thing as a H11 Silverstar? Or is Piaa or Hella make a bulb that fits? I want to put new bulbs in the fogs, I know Silverstars are great but is there an H11?
Old Nov 8, 2005 | 07:54 AM
kapps's Avatar
kapps
I don't think there are any Silverstars in H11. It's a fairly new bulb type (along with H7) and not many manufacturers are using it yet. If you're looking for a yellow light for bad weather, check Google. Nokya makes one that's regularly on Ebay for ~$20. PIAA also make a yellow bulb but it's JDM. A couple sites import them to the US and sell them for a very steep price (but PIAA's are brighter). If you just want a bright white light and don't really care about fog performance, then PIAA and Hella both make some very good bulbs in H11.
Old Nov 8, 2005 | 11:28 AM
chows4us's Avatar
chows4us
http://www.piaa.com/Bulbs/Bulbs-H11.html but PIAA are crap. See danielsternlighting.com
Go with Hellas http://www.rallylights.com/hella/H11.asp
Old Nov 8, 2005 | 11:32 AM
Rally@StanceDesign's Avatar
Rally@StanceDesign
my whiter fog light bulbs
Old Nov 8, 2005 | 01:28 PM
cooper99's Avatar
cooper99
RallyMINI, I really like your whiter fog lights. I cannot find any decent fog light bulb replacements for under 60 dollars plus shipping ; at that price its not worth it yet for me to change them out. If you don't mind me asking, what is the brand and make of the bulbs you have in, how much did they cost, and where did you buy them? I am tired of searching various online dealers and pictures and I want the clean look of your setup.
Old Nov 8, 2005 | 01:54 PM
Rally@StanceDesign
www.supremepower.com
under "super white bulbs" which is under lighting
30 dollars and they have either yellow OR white.....im debating yellow soon.
Old Nov 9, 2005 | 09:56 AM
fishbulb's Avatar
fishbulb
very nice...details?
Old Nov 9, 2005 | 10:12 AM
Vinyl Styles's Avatar
Vinyl Styles
For a variety of colors for the H11's check out autolumination.com - find the headlight/foglight page.
Neon Blue Krypton
Old Nov 9, 2005 | 10:19 AM
eVal's Avatar
eVal
I have bought bulbs from Eric at Supreme Power Parts in the past and been very happy with them. I finally have some yellow fogs and superwhite high beams on the way and will post pics as soon as I can
Old Nov 9, 2005 | 12:46 PM
Rally@StanceDesign
details about my bulbs can be found right above your post.
I installed them by removing wheel wells and going in from behind the foglights. Really not that hard, and i was changing from my snow wheel combo already....so the wheels had to come off anyways.
Old Nov 9, 2005 | 03:40 PM
OldRick's Avatar
OldRick
Blue fog lights are exactly the wrong thing - they cause additional glare on fog. Use yellow or white.
Hint: you can use H-9 bulbs, which produce 2100 lumens instead of the stock 1400. If you also use the yellow stone-guard plastic protectors, you get a really bright yellow fog light, which is excellent.
Old Nov 9, 2005 | 03:50 PM
chows4us's Avatar
chows4us
Dude. its bling. Everything doesnt have to be functional
Old Nov 9, 2005 | 04:28 PM
Rally@StanceDesign
Very true....but i dont think anyone is attempting to use blue ones.
Mine are very white...but even then still have some yellow in them. My eyes can't percieve any difference whatsoever between these and the OEM ones besides color. Effectiveness is obviously not hampered a noticable amount.
Old Nov 11, 2005 | 08:07 AM
hahnsie's Avatar
hahnsie
you know im sexy
ok i see oldrick is under the idea that most mini owners want funtionability or even legality. truth is we dont care about either (usually) its all about looking a little different from your buddy
Old Nov 11, 2005 | 10:36 AM
OldRick's Avatar
OldRick
Well, I get a lot of fog where I live, so I want good fog lights.
Perhaps we should agree to refer to other options as bling-lights?
Old Nov 2, 2006 | 07:45 PM
Snappychip's Avatar
Snappychip
Thanks Chows I will go with the Hella's I have had success with Hella in the past. I want the fogs more white.
AZN Optics
Accessory Products
Aug 21, 2015 02:03 PM
AZN Optics
Aug 21, 2015 02:02 PM
AZN Optics
Aug 16, 2015 11:52 PM
