Electrical will the oem xenon lights bolt up?
Old Mar 1, 2006 | 07:17 PM
ruggedbert's Avatar
ruggedbert
I have a 2006 MCS without the xenon headlights. I was wondering if i could simply buy the OEM xenon units and blot them up? Is it plug and play? Or do i have to mess with a lot of wiring? THanks
RYan
Old Mar 1, 2006 | 10:12 PM
002's Avatar
002
Look into the cost of parts first. The bulbs alone may change your mind. If you do assemble all the parts, you may need to have the control modules programmed.
Old Mar 1, 2006 | 11:14 PM
1nf3rn0's Avatar
1nf3rn0
Like 002 said, the cost may be very high... Other than that, I do not see why the xenons wouldnt work.
Old Mar 1, 2006 | 11:22 PM
Electron_Mike's Avatar
Electron_Mike
Seems like I recall there being a retrofit kit for it, but I'm not sure. Like the others have said, they're very, very expensive.
Old Mar 1, 2006 | 11:23 PM
Motor On's Avatar
Motor On
To do it legally, you can retrofit them, but you also will be install new wiring for them and need to connect washers and autoleveling devices and you end up removing everything within that chrome surround. Or you could do what I did swap in some silverstars and get just as much light at a slightly whiter less blue color for $80 (4 H7 bulbs (2high 2low)carried by autozone and walmart) total and 15-30 min of self install vs ~400 per headlamp minus labor after the car leaves the factory. I'll post a link to my how to if you'd like.
Old Mar 1, 2006 | 11:24 PM
not-so-rednwhitecooper
You CANNOT DO IT without a major wiring change.
I looked into it on my old 05. A large part of the wiring harness had to be changed out.
Old Mar 2, 2006 | 09:51 AM
ruggedbert's Avatar
ruggedbert
THanks a lot guys. I believe you have saved me from a lot of headache and $$$!
Old Mar 3, 2006 | 02:51 AM
Motor On's Avatar
Motor On
This might give you and idea of one of your otpions
https://www.northamericanmotoring.co...ad.php?t=59011
Old Mar 3, 2006 | 03:49 AM
mdsbrain's Avatar
mdsbrain
If you still want the Xenon look with a bit more light then the halogens you could go HID. Using an HID retrofit kit. Its not 100% legal and the light isn't as good as true Xenons but it can be had for about $300 and is a easy DIY.
I did this on my Cooper when I wanted the xenon look without the xenon price. They are now my high beams on my new 05
Rai1gun
R60/R61 Stock Problems/Issues
Jan 11, 2016 05:52 AM
blackie
Oct 2, 2015 07:41 PM
FLYM1N1
Aug 16, 2015 01:15 PM
PatrikKN
Aug 5, 2015 09:10 PM
