Electrical add a circuit
Old Feb 19, 2006 | 10:48 PM
shack01's Avatar
shack01
add a circuit
Checked this thread for ideas on getting power to some aux lighting that I plan to add which will need power even when the ignition is off. Saw several mentions of "add a circuit" with the implication that it is a hardware mod. Sounds like just the ticket. If that is indeed what it is, where do I obtain one and where should I go for the power I need? Thanks in advance.
Old Feb 20, 2006 | 12:10 AM
rkw's Avatar
rkw
It adds a power tap to a fuse slot. Here is where I purchased mine: http://www.partsexpress.com/pe/showd...number=071-580. You'll need to find a fuse slot that has always-on power. I'd imagine that would be true for the alarm system (F24), but perhaps someone else could make a recommendation.
Old Feb 20, 2006 | 07:19 AM
shack01's Avatar
shack01
Thanks, rkw, its in the mail. Another project for next wekend!
Old Feb 20, 2006 | 08:06 AM
petecrosby's Avatar
petecrosby
I found them at Pep Boys. Other stores might have them as well.
Old Feb 20, 2006 | 06:49 PM
garretwp's Avatar
garretwp
You can also get them at autozone as well.
Garrett
Old Feb 20, 2006 | 06:52 PM
Motor On's Avatar
Motor On
Check out the Classic MINI post, said there was an OEM int. lighting kit coming out, the install instructions should have points to tap into w/ enough power
Old Feb 20, 2006 | 07:29 PM
rclements's Avatar
rclements
See my separate post about the Ground tap kit... I put one in the battery jumper box under the hood, works well. -rc
Old Feb 22, 2006 | 06:18 AM
jwardell's Avatar
jwardell
I have details and instructions on how to tap your fuse with the add-a-circuit on my site:
http://www.jwardell.com/mini/fusetap.html
Old Feb 22, 2006 | 07:36 AM
CARdiac's Avatar
CARdiac
the add-a-circuit has a limit of 10, I am not sure what the power requirements are for your lights but be aware of the limitations
schr5530
Oct 5, 2015 08:28 AM
Oct 1, 2015 12:34 PM
Oct 1, 2015 12:28 PM
Oct 1, 2015 12:13 PM
