PDA
View Full Version : Drivetrain (Cooper S)
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16
  1. Drivetrain New guy with old problem..... boost loss
  2. Drivetrain hot side baffle delete.... on the cheap!!!!
  3. Drivetrain New guy with old problem..... boost loss
  4. Drivetrain Riss Racing + Invidia Q300 Exhaust!
  5. Drivetrain New clutch options DMF delete - Replace Flywheel + Clutch
  6. Drivetrain Help needed! Cant find replacement stud
  7. Drivetrain Alta Diverter Valve Install and Test Opinion (With Pics)
  8. Drivetrain I'm looking for or starting a group buy of aquamist
  9. Drivetrain Custom CAI Idle issue...
  10. Drivetrain FMIC - Did I miss all of the good deals???
  11. Drivetrain How much PSI is your r56 holding?
  12. Drivetrain LSD on an automatic?
  13. Drivetrain newbie: first mods on a 2010 MCS
  14. Drivetrain newbie: first mods on a 2010 MCS
  15. Drivetrain Short term gas smell
  16. Drivetrain Possibly upgrading to a R56, just some advice please
  17. Drivetrain K&N Typhoon with BSH OCC
  18. Drivetrain Im poor...
  19. Drivetrain catless dp without tune!!
  20. Drivetrain JCW Intake on stock 09 Cooper S
  21. Drivetrain NM Engineering downpipe back exhaust review, high pitch resonance problem??
  22. Drivetrain NM Boost tubes installed
  23. Drivetrain Waterless Engine Coolant
  24. Drivetrain Experience with Samco intake hoses?
  25. Drivetrain Catted DP
  26. Drivetrain Confused by fluid in OCC
  27. Drivetrain replacing stock air filter, advice on which to get
  28. Drivetrain Dynomat info
  29. Drivetrain Big brakes or not
  30. Drivetrain ignition coils and spark plugs help
  31. Drivetrain Catback owners, which downpipe?
  32. Drivetrain Foam filter on K&N intake ??
  33. Drivetrain Turbo options? (Rebuild/new)
  34. Drivetrain Why would typhoon sri intake fit a 08 mini "S" and not a "clubman S"
  35. Drivetrain mini tires and alignment
  36. Drivetrain Timing chain
  37. Drivetrain Twin loop muffler exhausts
  38. Drivetrain Catless Downpipe with Resonator Delete!!!
  39. Drivetrain Cobb SoCal Grand Opening Party
  40. Drivetrain Diverter Issue - Ideas Pls
  41. Drivetrain Alta Billet Turbo
  42. Drivetrain CAE Shifter .....I want one
  43. Drivetrain Help Getting my Exhaust to last threw winter
  44. Drivetrain looking for a dyno
  45. Drivetrain DoS intake
  46. Drivetrain Regarding the Fuelpump.
  47. Drivetrain Should i be concerned??
  48. Drivetrain Opinions on resonator delete '11 MCS
  49. Drivetrain Evolve Tuning - now sponsors NAM!
  50. Drivetrain Akrapovic exhaust system question
  51. Drivetrain Opinions
  52. Drivetrain CEL code p0456
  53. Drivetrain Hopeful Harmonic Tunes
  54. Drivetrain Boost Gauge install question
  55. Drivetrain Those with aftermarket downpipes...
  56. Drivetrain How affective are the various upgraded intake pipes and tubes?
  57. Drivetrain Torque Mount Insert Install
  58. Drivetrain Valve Cover Breather Assy sliding out of NM CAI
  59. Drivetrain Catless Downpipe and AP
  60. Drivetrain Intake pipe keeps coming off...
  61. Drivetrain m7 tuning
  62. Drivetrain Engine bay question for OCC
  63. Drivetrain Where to grab boost reading on 2011+ N18?
  64. Drivetrain Bov
  65. Drivetrain Can I still drive if one of the turbo pipes slip off?
  66. Drivetrain Driving Impressions: JCW Stage 1 Intake
  67. Drivetrain 11 JCW mod?
  68. Drivetrain Aggressive exhaust
  69. Drivetrain Forge BOV/RCV Installed / No Vacuum - Odd Blow Off Sounds
  70. Drivetrain Norcal Mechanic
  71. Drivetrain PCV Delete Modification -vs- OCC
  72. Drivetrain Ddm cai
  73. Drivetrain Hot Glue Engine Mount
  74. Drivetrain Aftermarket Air intake - Suggestions?
  75. Drivetrain I was wondering....
  76. Drivetrain Which spark plugs after tune?
  77. Drivetrain Spark plug socket?
  78. Drivetrain How to Remove PCV Hose for OCC Install?
  79. Drivetrain When does an new "tune" become necessary
  80. Drivetrain DIY "ram air" scoop attachment
  81. Drivetrain Anyone tried thermal coating on face of intake valves?
  82. Drivetrain accessport maps
  83. Drivetrain OBX turbo back sound clips
  84. Drivetrain size resonator
  85. Drivetrain m7 catch can install with stock intake
  86. Drivetrain jcw strut sway bar/k&n typhon intake kit
  87. Drivetrain nm hi flow air intake
  88. Drivetrain hi flow cold air intake
  89. Drivetrain CEL with K&N CAI
  90. Drivetrain EXHAUSTS and newb help. !!!!!
  91. Drivetrain Turbo back OBX exhaust =]
  92. Drivetrain Shifter Counterweight for Short Shift Effect
  93. Drivetrain Flat Metal Strip Oil Dipstick vs. Cable
  94. Drivetrain 2012 R60 Countryman S Turbo N18B16 dyno & tune
  95. Drivetrain Downpipe install problem- please help!
  96. Drivetrain Respectable Horsepower Numbers
  97. Drivetrain Mini cooper exhaust question
  98. Drivetrain DDMWorks R56 Race Intake System (RIS)
  99. Drivetrain Alta Stg 1 Recorded Gains
  100. Drivetrain Header on a R56
  101. Drivetrain Alta unichip diy
  102. Drivetrain Is my car special or did my gauge just go crazy?
  103. Drivetrain Catless DP mod to make 02 sensors believe to have Catalytic Converter
  104. Drivetrain Boost drop off
  105. Drivetrain ALTA BPV spring replacement on '11 MCS
  106. Drivetrain Any point in upgrading to a JCW downpipe?
  107. Drivetrain SPEC Clutch Stg 1,2,2+
  108. Drivetrain I just purchase a CNT Racing R56 catback ehaust
  109. Drivetrain So any pop and burble yet?
  110. Drivetrain Brake light not turning off?
  111. Drivetrain MINI modification install
  112. Drivetrain Oil catch can for 2010 MCS?
  113. Drivetrain when should i think about engine tuning?
  114. Drivetrain Leaking Drain Plug?
  115. Drivetrain Torque specs
  116. Drivetrain Some info for those that live in california with car problems!
  117. Drivetrain Downpipe for 2011 mcs
  118. Drivetrain MAF values - getting useful data
  119. Drivetrain Heat Shield MOD
  120. Drivetrain R56 cai
  121. Drivetrain K&N Typhoon CAI
  122. Drivetrain Replacement Air filter for M7 AGS-R
  123. Drivetrain What kind of aftermarket bov do you have?
  124. Drivetrain Any successful E85 conversions in here?
  125. Drivetrain clutch fail...
  126. Drivetrain DoS & WMW Mods @ MITM
  127. Drivetrain Alta Exhaust Suggestion
  128. Drivetrain jcw tuning package
  129. Drivetrain The Last Oil Catch Can Question?
  130. Drivetrain best $150 or less engine mod?
  131. Drivetrain Intakes for 2011+ models?
  132. Drivetrain My solution to the PVC system dilemma.
  133. Drivetrain Another Aquamist HFS-3
  134. Drivetrain rev limiter style
  135. Drivetrain Seafoam effects.
  136. Drivetrain Quafie LSD questions..
  137. Drivetrain Check this out exhaust manifold.
  138. Drivetrain Diagnose boost....
  139. Drivetrain Code P1447
  140. Drivetrain R56 Upper radiator Hose Inner diameter size?
  141. Drivetrain Mobil 1 0W-40 - Reduced oil loss
  142. Drivetrain G-Force Chip
  143. Drivetrain $550 to upgrade your K03 to K04 hybrid turbo...
  144. Drivetrain 2011 MCS, still waiting on my HP upgrades to come out (*TUNE!)
  145. Drivetrain Observation & Quick Question...
  146. Drivetrain CP Pistons/Scat Rods for the R56 - Sorta
  147. Drivetrain Turbo Solenoid Bypass Adapter?
  148. Drivetrain Quality wise: What is the Best DP for the R56?
  149. Drivetrain Increased turbo lag
  150. Drivetrain mini cooper R56 turbo
  151. Drivetrain Myne TUNE
  152. Drivetrain CAI or just a free flow filter in OEM CAI?
  153. Drivetrain throwing CEL's
  154. Drivetrain Samco Hoses
  155. Drivetrain NM Engineering's DP back exhaust....
  156. Drivetrain Resonator delete vids?
  157. Drivetrain AccessPort MCS auto stage 3 or 2?
  158. Drivetrain What is this new sensor in my 2011 MCS that broke off?
  159. Drivetrain DoS CAI Installed. Truly Impressed!
  160. Drivetrain Bad turbo today
  161. Drivetrain Got a problem with your BOV, ALTA wants to know about it!
  162. Drivetrain Boost after modding
  163. Drivetrain ALTA Quality...What's going on?
  164. Drivetrain Bov... Cai??
  165. Drivetrain NM Eng vs RISS Racing turbo back exhaust
  166. Drivetrain anyone NOT using the downpipe heat shields?
  167. Drivetrain So I blew a piston on my JCW and the fun begins
  168. Drivetrain Aquamist HFS-3
  169. Drivetrain air to fuel ratio
  170. Drivetrain 2007 mini cooper s K&N Typhoon Intake System
  171. Drivetrain help me decide!
  172. Drivetrain Calling those with DDM RIS
  173. Drivetrain If AP not an option, what do you mod?
  174. Drivetrain .
  175. Drivetrain Changing Brakes
  176. Drivetrain Water-Meth injection as second mod?
  177. Drivetrain turbo failure!
  178. Drivetrain Introducing From ALTA - R56 Turbo Inlet Pipe
  179. Drivetrain Uninstalled the BSH R56 Direct Dual Boost Tap
  180. Drivetrain Perte de pression
  181. Drivetrain My RMW experiences...
  182. Drivetrain It's all fun till someone loses a piston
  183. Drivetrain Full Custom Magnaflow With a Touch of OBX
  184. Drivetrain Turbo Identification
  185. Drivetrain Exhaust Help
  186. Drivetrain K & N Filter??
  187. Drivetrain Getting Serious: Need some advise and thoughts
  188. Drivetrain R56S Hard Air Intake Pipe?
  189. Drivetrain Best Cat-back exhaust?
  190. Drivetrain Cravenspeed Boost Tap Adapter Not Working on '11 MCS
  191. Drivetrain Exhaust Depot Intercooler Boost Tubes - Beware!!
  192. Drivetrain Riss Racing Catback Exhaust W/ Downpipe
  193. Drivetrain CAI DIY??? Help...
  194. Drivetrain Not getting an ALTA Accessport...yet.
  195. Drivetrain New Clutch
  196. Drivetrain Summer Heat and Turbos - Should I Mod?
  197. Drivetrain Master Engine Gasket Kit?!?
  198. Drivetrain What are the chances of throwing a code?
  199. Drivetrain Tubing under the BSH dual boost tap
  200. Drivetrain Billet Tech DUAL OCC PROTOTYPE IS IN!!!!!!
  201. Drivetrain rear sway bar
  202. Drivetrain Got my access port today!
  203. Drivetrain Mods for N00b
  204. Drivetrain Invidia Q300 Exhaust System Emission Issues/Failure
  205. Drivetrain Intake with no risk of sucking water
  206. Drivetrain Am I Done ?
  207. Drivetrain Question, turbo heat shield
  208. Drivetrain Data logging info
  209. Drivetrain Alta Accessport: Worth It?
  210. Drivetrain Latest news on CAI's and panel filters for 2011+ S?
  211. Drivetrain Track car list of mods
  212. Drivetrain Will the Cooper S do 160?
  213. Drivetrain Exhaust or FMIC. What should I do
  214. Drivetrain Brisk racing plugs in stock '10 turbo
  215. Drivetrain mini tuning program
  216. Drivetrain Mods without Turbo-back exhaust
  217. Drivetrain Alta Boost Tube review
  218. Drivetrain Getting Start/Stop added in the US?
  219. Drivetrain Discharge and Air Charge Pipes
  220. Drivetrain After market exhaust
  221. Drivetrain boost loss symptoms? help!
  222. Drivetrain Forge BOV
  223. Drivetrain Exhaust with Catalysts - Help!
  224. Drivetrain WHO makes Aftermarket Pistons and Rods????????
  225. Drivetrain boost gauge install - tap path??
  226. Drivetrain drone-cancelling exhaust?
  227. Drivetrain How can I modify my MINI to get an exhaust burp, burble, rumble, pop with downshift?
  228. Drivetrain exhaust depot hard pipes
  229. Drivetrain Intercooler ???
  230. Drivetrain After DOS noise maker delete, car wont build boost?
  231. Drivetrain Oil Catch Cans let me know what you think?
  232. Drivetrain help me find the how to's for DOS noismaker delete and CAI
  233. Drivetrain Help me troubleshoot this boost problem
  234. Drivetrain strut reinforcement (anti-mushroom) plates
  235. Drivetrain 2011 JCW Tune Kit?
  236. Drivetrain Craven Speed short shifter and NM shift box
  237. Drivetrain FMIC or AP
  238. Drivetrain Mini JCW K04 project
  239. Drivetrain Running OPEN stage 1 JCW Intake
  240. Drivetrain 2011: J-brace won't fit!
  241. Drivetrain Low oil pressure under hard cornering.
  242. Drivetrain RMW dyno tuning DC area May 13-14
  243. Drivetrain Helix Shift Adapter Installation Writeup
  244. Drivetrain Alta Turbo Back Exhaust
  245. Drivetrain Tune Questions
  246. Drivetrain If you have a stage 3 alta tune I'd like your opinion..
  247. Drivetrain Turbo Leak?
  248. Drivetrain Torque Steer Fix Crosspost from JCW forum--applied to an "S"
  249. Drivetrain Problem with Alta Intake
  250. Drivetrain When is this 22psi map limit/cut going to be solved??
