View Full Version : Drivetrain (Cooper S)
Pages :
11]
12
15
16
- Drivetrain R56 chiptuning
- Drivetrain JCW R56 goes 2.05.701 @ Buttonwillow Time Attack 1st round
- Drivetrain Anyone have experience with this intake?
- Drivetrain Muffler delete ?
- Drivetrain Twin Turbo MINI
- Drivetrain Alta oval tip cat back for mcs 07
- Drivetrain RMW-ROCHESTER TUNING_APRIL 16-17
- Drivetrain JCW baseline dyno + NSW/XXX/hardcore under bonnet porn!
- Drivetrain CAI Question
- Drivetrain VIBRANT VS FLOWMASTER VS BORLA
- Drivetrain GT28RS Project
- Drivetrain Alta Exhaust and Factory Warranty
- Drivetrain CATTED DP's and CEL
- Drivetrain oil cooler, anyone installed on R56, thoughts..
- Drivetrain Seattle RMW Tune
- Drivetrain DoS vs. factory JCW intake (K&N)
- Drivetrain Retrofit ALTA CAI foam filter with paper filter?
- Drivetrain noisemaker delete question
- Drivetrain Water/Meth Injection For The Track
- Drivetrain I borrowed a DP lost the return address...
- Drivetrain BMC CDA on R56 Mini Cooper S
- Drivetrain R56 Alta Lightened Crank Anyone Have?
- Drivetrain I abso-FREAKN'-lutely love my new DoS intake!!!
- Drivetrain '10 mcS to JCW power with Flash?
- Drivetrain Some sound clips...
- Drivetrain Cold air intake vs hot Air intake on FI cars
- Drivetrain OBX Exhaust Header
- Drivetrain "My" Cold Air Intake
- Drivetrain Loss of power between 5-6k rpm
- Drivetrain For those that can't wait for RMW's remote tuning... alternative!
- Drivetrain Mitsubishi TD05-big16G - 271 Hp
- Drivetrain Vac only and Boost only...
- Drivetrain Easy fix for rubbing boost tubes.
- Drivetrain does your inner cooler cause a lot of vibration?
- Drivetrain goPoint Technology
- Drivetrain supersprint exhaust
- Drivetrain Looking for....
- Drivetrain Found A New CAI
- Drivetrain boost tubes
- Drivetrain Drill Air Box
- Drivetrain Blow off Valve Question ANY REVIEWS?/ HELP
- Drivetrain as much as I would love for this to be true..
- Drivetrain Exhaust Depot - Out of Business??
- Drivetrain Cravenspeed SSK and NMEng Torque Are Insert are in:
- Drivetrain NEW hard turbo inlet from ALTA
- Drivetrain List your MOD with performance gain and MPG lost/gain
- Drivetrain Do You Know?
- Drivetrain Well, was it worth it?
- Drivetrain JCW R56 goes 1.24.103 at Street of Willow
- Drivetrain Want to improve performance what to get?
- Drivetrain GT28RS Tuned @ 338whp
- Drivetrain TPS reports through ScanGauge
- Drivetrain Loss of boost! 6 psi. HELP!
- Drivetrain 2009 JCW cold air intake?
- Drivetrain water/meth injection suggestions?
- Drivetrain Spark plug non-fouler mod on Alta TBE
- Drivetrain spark plugs eh?
- Drivetrain Exhaust Opinions Needed
- Drivetrain BSH catch can and dual boost port install
- Drivetrain manual boost controller
- Drivetrain Riss o2 sim FIXED
- Drivetrain is Alta Catback Exhuast Worth 500$?? need opinions
- Drivetrain wrong forum
- Drivetrain Hood scoop options...
- Drivetrain HOW TO HOOK UP MY MINI COOPER S
- Drivetrain help with alta bov
- Drivetrain Help Regarding M7's VELOCITY Throttle Booster
- Drivetrain how much is a fair price for labor at a dealer to install a JCW stage 1 tuning kit?
- Drivetrain SWEET RIDE!
- Drivetrain Best intercooler ever..??
- Drivetrain Check engine light help/suggestions
- Drivetrain LSD Options for R56
- Drivetrain boost interruption
- Drivetrain Akrapovic Exhaust
- Drivetrain Help installing Helix intercooler
- Drivetrain What does yours rev to.....
- Drivetrain Riss o2 sim impressions
- Drivetrain Velocity Adjustable Throttle Booster System- Wow
- Drivetrain Intake
- Drivetrain alta blow off valve
- Drivetrain 50+ FWHP with M7 AGS-R intake?!?!?!
- Drivetrain ***OFFICIAL SIGN-UP THREAD for FLASH TOOL***
- Drivetrain ALTA has a lieftime warranty now?
- Drivetrain ARC (ATOMO) Products
- Drivetrain Exhaust for 2010 S
- Drivetrain catless we go!
- Drivetrain Anyone running a Riss catch can with an Alta CAI and hard pipe?
- Drivetrain JCW: How much boost should I be producing?
- Drivetrain Running with no cats? Please tell your experience
- Drivetrain OBX catless downpipe?
- Drivetrain Question about DDM RIS system
- Drivetrain A word about RMW.... worthwhile.
- Drivetrain Dealer JCW Satge 1 or JCW Parts and RMW Tune?
- Drivetrain RMW tuning day at Helix in Philly Mar/Apr '10
- Drivetrain Remap Problem
- Drivetrain Power Ideas...
- Drivetrain Alta's Turbo Inlet Hard Pipe Fitting issue
- Drivetrain Headers on a turbo MCS?
- Drivetrain pulley on a 2007?
- Drivetrain Mini Cooper S Launch Control!!!!
- Drivetrain RMW Tuning Day in eastern Connecticut is on the Horizon around May 25-26, 2010
- Drivetrain **Riss Racing** R56 Mini Cooper/Clubman S Sequential BOV System! (Video)
- Drivetrain guestamate my HP
- Drivetrain Forge IC without ECU tune
- Drivetrain Riss Racing R56 o2 fix Launch!
- Drivetrain JCW Tuning Kit comes with this?
- Drivetrain How much boost are you getting?
- Drivetrain My only option...more or less
- Drivetrain R56 S PCV System ?
- Drivetrain JCW exhaust?
- Drivetrain Tuning
- Drivetrain JCW Stage I exhaust inlet pipe diameter?
- Drivetrain aftermarket clutch
- Drivetrain Need input from people that tore down timing......
- Drivetrain New Arqray Ti Exhaust :)
- Drivetrain Intake & Exhaust Noise - Yes I searched 1st :-)
- Drivetrain Air Intake
- Drivetrain Riss Racing Exhaust Installed
- Drivetrain Thinking about mods for 2010
- Drivetrain Catted VS Catless
- Drivetrain RR Downpipes, feedback?
- Drivetrain R56 Noisemaker Revealed!
- Drivetrain Exhaust Depot Downpipe... Ceramic Coated?
- Drivetrain resonator delete!
- Drivetrain NM Cold Air Intake or M7 Cold Air Intake?
- Drivetrain Best Exhaust for an 07 Mini Cooper S?
- Drivetrain JCW Kit Parts
- Drivetrain Shorten shift throw?
- Drivetrain RMW Orlando Tune: Post up your results!
- Drivetrain Big turbo upgrade with the Garrett GT28RS!
- Drivetrain Big turbo upgrade with the Garrett GT28RS...
- Drivetrain What do you get when you add DOS cai and a Quicksilver exhaust....
- Drivetrain A different oil catch can question
- Drivetrain Wanted: stock turbo for development work
- Drivetrain Post pictures of your mounte scangauge
- Drivetrain Oh no, not again, ANOTHER melted valve cover...
- Drivetrain primary cat gone vs all cats gone
- Drivetrain Trying to reach Riss Racing? Start here.
- Drivetrain Opinion
- Drivetrain Unichip Universal Tuner Kit
- Drivetrain Riss Racing's restructure
- Drivetrain Riss Racing Inc In trouble please read
- Drivetrain Giant Hole in Alta Downpipe
- Drivetrain Running lean why?
- Drivetrain yet another CAI question
- Drivetrain NM Engineering products in MINI JCW
- Drivetrain APEXi Units?
- Drivetrain Message from Adam@Riss Racing
- Drivetrain Better ways to spend Modding Money?
- Drivetrain No Oil Change for a Year?!?
- Drivetrain R56 Factory Service Manual?
- Drivetrain NO OIL!!!!!!
- Drivetrain FMIC ?s
- Drivetrain Anyone have a used R56 flywheel for sale?
- Drivetrain ?s about clutch/flywheel
- Drivetrain RMW & Maitland Importers Tune day Dec 12
- Drivetrain fuel system cleaners...check this out
- Drivetrain Unichip Destoyed My ECU
- Drivetrain Oil Leak????
- Drivetrain Forge BOV questions
- Drivetrain Clutch replace @ 9.5K
- Drivetrain Water temps about 215F. Is this normal?
- Drivetrain JCW dyno pull
- Drivetrain Mini Boost gauge work with supercharger pullys???
- Drivetrain Evotech Software Tune
- Drivetrain eBay short shifter
- Drivetrain DoS CAI Owners: Defenders of Speed wants your feedback - CAI Baffle Development
- Drivetrain Data logging
- Drivetrain Which Front Mount Intercooler should i buy
- Drivetrain nm-eng what to expect?
- Drivetrain New(er) m7 Super AGS Install?
- Drivetrain Any feedback on the Forge CAI
- Drivetrain Quicksilver exhaust
- Drivetrain I am only boosting 10 or 11lbs , overboost to 12.6 help me figure out why?
- Drivetrain why are people selling their unichips?
- Drivetrain m7 Oil Catch Can Info?
- Drivetrain Need help identifying a OBDII code
- Drivetrain R56 MCS 174hp N14B16 Dyno tuned to 245bhp
- Drivetrain Lots of Alta... Bad dyno???
- Drivetrain CEL went bye bye
- Drivetrain Where to buy: Motor Mounts & Stud Conversion
- Drivetrain Alta exhaust resonator delete?
- Drivetrain Ported & Polished Head - A Missing Link in the R56 Quest for Power/Torque
- Drivetrain Alta CAI, Turbo Inlet and Noisemaker Delete Install.
- Drivetrain R56 boost reading: REV2 vs. boost gauge
- Drivetrain R56 Cutom Tune by Mynes
- Drivetrain way motor works tuner
- Drivetrain JCW sparks
- Drivetrain Arqray exhaust. What to choose???
- Drivetrain ED Downpipe Heat shield
- Drivetrain JCW Tuning Kit for '09 Clubman/Worth it?
- Drivetrain HELP loosing boost because of?
- Drivetrain denso for R56s in denso JP site only??
- Drivetrain Carbon Fiber Boot, Bonnet, Doors, and more
- Drivetrain Limiter in first and second gear
- Drivetrain GT28rs Turbo kit. Did you guys see this?
- Drivetrain modify wastegate acuator
- Drivetrain Scangauge xGauge - Now display BOOST without MAP
- Drivetrain RMW Tuning Feedback -How's your R56 MINI doing?
- Drivetrain Gearbox oil viscosity?
- Drivetrain '09 JCW DYNO results - Forge Intercooler
- Drivetrain P2187 CEL
- Drivetrain Defenders of Speed Vs DDMWorks
- Drivetrain GReddy RZ BOV on r56
- Drivetrain check out this exhaust for only $300
- Drivetrain rmw tune in stamford ct at ics
- Drivetrain JCW intake with aftermarket filter?
- Drivetrain RMW N/EAST TUNE--ROCHESTER NY
- Drivetrain My new exhaust!
- Drivetrain Need Help Find Samco Induction Hose
- Drivetrain GTSPEC STB
- Drivetrain Air / Fuel Ratio works with Scangauge xGauge
- Drivetrain Help
- Drivetrain O2 Sim / P0420 code delete
- Drivetrain P1497 CEL
- Drivetrain Eisenmann exhaust?
- Drivetrain M7 Oil Catchcan
- Drivetrain blow off valves
- Drivetrain Intercooler Performance Gains?
- Drivetrain Alta or M7?
- Drivetrain factory air box
- Drivetrain GT28 turbo kit from ati
- Drivetrain Problems with Alta boost tubes, check yours!!
- Drivetrain MiniMania exhaust OEM Tips
- Drivetrain My custom Stainless Cold Air Intake
- Drivetrain Alta Catback vs. Custom DIY
- Drivetrain Installing an LSD in the R56
- Drivetrain Forge R56 Intercooler Props
- Drivetrain noisemaker diameter? for bov
- Drivetrain RMW Custom Tune Party in Austin, TX, Oct 16/17
- Drivetrain My New Mini Cooper S 2009
- Drivetrain Mini tuning in Australia
- Drivetrain DDMWorks RIS and brake vacuum
- Drivetrain Ibiza Cupra R FMIC on the 09 207 RC !!
- Drivetrain Has anyone Tried Superchips on their R56?
- Drivetrain Milltek Turboback
- Drivetrain Alta vs Helix FMICs (For those who want to see the difference)
- Drivetrain aeroforce interceptor scan tool
- Drivetrain Riss racing?
- Drivetrain Helix short shift kit
- Drivetrain Balance shaft removal
- Drivetrain 207 RC boost cut problem..
- Drivetrain Tuning the R56
- Drivetrain Alta R56 Lightened Crank Pulley
- Drivetrain Boost
- Drivetrain first mods
- Drivetrain What about this intercooler
