Drivetrain boost tubes
Old Mar 3, 2010 | 08:52 PM
08cooperSblack's Avatar
08cooperSblack
boost tubes
anyone recommend any boost tubes and turbo inlet pipe. shopping around right now anything other than alta out there?
Old Mar 3, 2010 | 09:12 PM
JamesHunt's Avatar
JamesHunt
BOOST TUBES ARE JUNK
If you must waste money buy the nm engineering hardpipes
Old Mar 3, 2010 | 11:23 PM
Sabes's Avatar
Sabes
What are you talking about? I gained 50 hp when I installed boost tubes
Old Mar 4, 2010 | 03:32 AM
Ottoman_FD3S's Avatar
Ottoman_FD3S
is it because they don't add power? or make the car worse?
Old Mar 4, 2010 | 06:48 AM
JamesHunt's Avatar
JamesHunt
both
Old Mar 4, 2010 | 07:37 AM
OPC's Avatar
OPC
RATTUS Deserticus
Hard tubes are really the way to go if you're wanting to do this. NM Engineering is pretty well reviewed.
Alta tubes have a lot of fit issues reported (including my personal experience) on their silicon tubes. I haven't heard too much about their hard tubes.
Nice bling, but don't expect significant performance gains.
Old Mar 4, 2010 | 07:52 AM
Faulta's Avatar
Faulta
rather than throw money away for boost tubes, why not donate bucks to a local animal shelter and help some dogs?
Old Mar 4, 2010 | 07:56 AM
slinger688's Avatar
slinger688
+1.
Do not get the silicone ones. Real trouble...
Old Mar 4, 2010 | 08:18 AM
Kirkland's Avatar
Kirkland
+2
kudos for learning from others' experiences. my alta boost tubes wore out in less than 7500 miles and sounded like a ill cow moaning. $300 wasted.
Old Mar 4, 2010 | 09:28 AM
countryboyshane's Avatar
countryboyshane
You know I agree with you most of the time and we have the same thinking but give boost tubes a break! You have to admit that if one were to change one boost tube to change performance and limit restriction in the charge air circuit it would be the hot side boost tube with that ridiculous muffler.
Old Mar 4, 2010 | 09:35 AM
countryboyshane
I've had both silicone and hard boost tubes. I still have a silicone turbo inlet tube. Avoid Alta's silicone cold side boost tube like the plague. It is way too big and will get worn out from either the valve cover bolt that sits closest to it, or other things poking out near the throttle body.
There is definitely a little better throttle response and torque gain with the either hard or silicone. Don't expect a miracle though.
If you want to pay for real power, buy a catless downpipe, ECU tune, a FMIC.
Old Mar 4, 2010 | 12:50 PM
JamesHunt's Avatar
JamesHunt
I can tell you why these turds do not work.the muffler delete and the factory hardpipe that feeds the coldside tube are the most restrictive parts in the whole system of pipes.and guess what NOBODY MAKES A AFTERMARKET REPLACEMENT hardpipe .
Old Mar 4, 2010 | 02:24 PM
etalj's Avatar
etalj
I can tell you why these turds do not work.the muffler delete and the factory hardpipe that feeds the coldside tube are the second most restrictive parts in the whole system of pipes.and guess what NOBODY MAKES A AFTERMARKET REPLACEMENT hardpipe .
surely Macedo has the means to fab one up? I'd buy one.
Old Mar 4, 2010 | 03:34 PM
JamesHunt's Avatar
JamesHunt
stay tuned
Old Mar 4, 2010 | 03:51 PM
Rixter's Avatar
Rixter
Originally Posted by Kirkland
+2
M7 makes a hot side tube out of silicone that I was thinking of getting. How can a tube wear out?
Old Mar 4, 2010 | 03:52 PM
slinger688's Avatar
slinger688
Poorly designed tubes rub against metal parts because they have a bad fit. This will cause holes.
Old Mar 4, 2010 | 03:57 PM
Rixter's Avatar
Rixter
So can anybody comment on the M7 vs the NM Engineering tube? The NME tube has more parts and clamps, so logically that's not always a good thing. I've heard the M7 stuff is pretty decent.
Old Mar 4, 2010 | 04:41 PM
ENGINE 58's Avatar
ENGINE 58
I've had my m7 tube on for about 80000 miles between the two cars I've had it on with no problems . There is a little rubbed spot by the water tank but it's not deep.
Old Mar 4, 2010 | 07:47 PM
etalj's Avatar
etalj
stay tuned
Lol, I can be a beta tester if you like. And I'll pay for international shipping
Old Mar 4, 2010 | 09:11 PM
mattolson's Avatar
mattolson
So the ALTA tubing is a waste of money?
Old Mar 5, 2010 | 02:42 AM
countryboyshane
NM eng pipes have silocone couplers with hard pipes and M7 is purely silicone.
Look up silicone vs. hard boost tubes on google and you'll find out reasons why hard is better.
Old Mar 5, 2010 | 02:43 AM
countryboyshane
DING DING DING DING DING!
NM eng is much better. When Exhaust Depot is back up and running, their hard pipes are also very nice.
Old Mar 5, 2010 | 05:50 AM
iwashmycar's Avatar
iwashmycar
I was going to say if you didnt have an intake, the K&N pretty much comes with the turbo inlet hard tube. Nice and smooth.
Old Mar 5, 2010 | 06:55 AM
tgs91
Samco would be another option
Old Mar 5, 2010 | 10:50 AM
countryboyshane
Samco tubes actually fit unlike the Alta tubes ha ha ha ha!
