Drivetrain Cravenspeed SSK and NMEng Torque Are Insert are in:
Old Feb 28, 2010 | 04:49 AM
malteseracer's Avatar
malteseracer
I must say I'm very impressed with both products.
The SSK is short and presise, yet adjustable for easy driving going to school or work. Very cool mod. A ***** to figure out how to get in because the directions are horrible, but in the end well worth it.
The TAI from NMEng is really col. I can feel it staying more planted and having more power to the ground. Install for both took about 2 hours with a lift and air tools and no idea how to do it. Normal hand tools and jack stands: I'd say about 3-3.5hrs.
Old Feb 28, 2010 | 07:14 AM
onefish2's Avatar
onefish2
I have both. Both are great mods. A much, much better feel over stock.
Old Feb 28, 2010 | 07:31 AM
JamesHunt's Avatar
JamesHunt
2 hours for install?try 30 minutes if you know what you are doing
Old Feb 28, 2010 | 07:44 AM
clnconcpts's Avatar
clnconcpts
MAy I ask what we are talking about?
Old Feb 28, 2010 | 05:32 PM
malteseracer
Yea now that I know what to do it'd be 30 minutes, but the instructions are terrible. Last thing i want is someone taking my word for it and allotting themselves 45 minutes and not having the time.
Old Feb 28, 2010 | 10:08 PM
dooky's Avatar
dooky
great job on doing it yourself who cares how long it takes...
Old Mar 2, 2010 | 04:32 AM
J_'09s's Avatar
J_'09s
How did you handle the limited amount of space for the lower end of the shifter? Did you modify the case up underneath the heat shield?
Old Mar 2, 2010 | 09:54 AM
malteseracer
I just bent the heat shield up and left off the dust cover. I bent it too far though and the exhaust is hitting. Not bad enough to worry about so next time its up in the air I'll fix that
Old Mar 2, 2010 | 01:48 PM
J_'09s's Avatar
J_'09s
Thats how a lot of people are compensating for it. I just took a hack saw to the plastic cover (which was a Biatch to remove) and it worked good. I keep the ssk on the lowest setting.
Old Mar 2, 2010 | 02:07 PM
malteseracer
Yea, mine is all the way down too. any higher it feels like a truck now.
Old Mar 2, 2010 | 02:14 PM
J_'09s's Avatar
J_'09s
I KNOW!! I love this shift though. Its a good mod. Did you get the craven shift well cover too? and what **** are you going to run? I've still got the stock on installed.
Old Mar 2, 2010 | 10:02 PM
malteseracer
No I like the boot better, you can adjust the nut through the boot, but i cut two small holes for my fingers in case i can't
Old Mar 4, 2010 | 10:11 PM
jproz's Avatar
jproz
i will agree regarding the cravenspeed SSK.
I have it as well (with the plate cover and whalen shift ****).
I love the shifting. Every once in a while I'll put it back all the way to the top but generally put it back all the way to the lowest setting within a day or so... there is just something so appealing about the lowest setting.
note that I also ripped out the cover below the shifter (under the car) to achieve the lowest setting.
Cheers.
Debi's Coop S
Oct 3, 2015 08:19 AM
Oct 1, 2015 12:28 PM
Oct 1, 2015 12:13 PM
BendersMINI
Sep 27, 2015 07:02 PM
