Drivetrain Mitsubishi TD05-big16G - 271 Hp
Old Mar 7, 2010 | 06:55 AM
Antalyalogy's Avatar
Antalyalogy
Guys dear Stelio's 207 Gt have a new setup and new turbo..
Results;
With a maximum boost of 1.3bar and constant of 1.2bar, the engine produced 271hp at 5995rpm.
Maximum torque was 346,5Nm.
http://etuners.gr/en/index.php?s=13&t=204
Mitsubishi TD05-big16G it's only 200 usd
http://cgi.ebay.com/ebaymotors/TD05-...Q5fAccessories
http://cgi.ebay.ca/TD05-BIG-16G-Turb...item5d27b171c1
Old Mar 7, 2010 | 07:26 AM
old81's Avatar
old81
M6
Did not see the price in this link, but it appears as a potential alternative if you have the shop to support it.
Good docs in the link.
Thanks for sharing.
Old Mar 7, 2010 | 07:38 AM
Antalyalogy
Thanks for sharing.
I added ebay link..Thank you..
Old Mar 7, 2010 | 07:41 AM
JamesHunt's Avatar
JamesHunt
does peugeot use the same ecu and software as mini ?
Old Mar 7, 2010 | 09:15 AM
Porthos's Avatar
Porthos
Maybe but it might not because of the fact that it is EU instead of US. Thats my guess
Old Mar 7, 2010 | 10:02 AM
JamesHunt's Avatar
JamesHunt
buy a euro ecu and delete the maf
Old Mar 7, 2010 | 10:18 AM
countryboyshane's Avatar
countryboyshane
Well after creating a new turbo inlet pipe and making a custom downpipe to hopefully fit your current exhaust (might need additional fabrication to fit) it seems like the total costs of this project are hidden.
The better solution still seems to be to wait for a big valve head w/upgraded cams, upgrade to JCW turbo components, and re-tune.
Old Mar 7, 2010 | 10:35 AM
JamesHunt's Avatar
JamesHunt
sounds expensive. bv head +cam kit will run 3200 to 3700
Old Mar 7, 2010 | 11:14 AM
ThumperMCS's Avatar
ThumperMCS
Interesting....
There will be a turbo kit for the R56 utilizing a Mitsubishi turbo on the market shortly
It would seem to me there needs to be a lot more tuning done on that 207...the numbers are less than stellar, considering those are BHP numbers from the crank.
Oh and not to mention a more effective IC...those intake temps are rather high.
Old Mar 7, 2010 | 02:33 PM
JIMINNI's Avatar
JIMINNI
Originally Posted by ThumperMCS
Interesting....
So will this kit be CARB legal? I say this because my friend is doing a STaSIS big turbo kit on his Audi as we speak and it's all CARB legal.
Old Mar 7, 2010 | 02:46 PM
Porthos's Avatar
Porthos
Probably not but, hey they are parts that are CARB so one can only hope
Old Mar 7, 2010 | 05:39 PM
ThumperMCS's Avatar
ThumperMCS
Unfortunately, no I don't believe so...
While it would be nice, I don't see it as a big must have. For the people who will be running an aftermarket turbo kit, I can't see them caring all that much...seeing as a good majority of them are probably running catless downpipes as it is!
With a mod like a turbo kit, 9 out of 10 people want a kit that is engineered properly, performs well, has maximum driveability and can be run safely without motor problems.
Old Mar 7, 2010 | 06:17 PM
GO K4RT's Avatar
GO K4RT
Stay away from those ebay 16gs. If you want a 16g, buy it from the best, Forced Performance.
If you find these numbers impressive, you should see what that turbo will do at 20-22psi. I have personally made over 400whp on that turbo on an Eagle Talon. IMO that turbo is too large for our cars unless you are comfortable upping the boost to 20-22psi and either way you will probably be waiting for boost on our tiny 1.6.
Old Mar 7, 2010 | 06:50 PM
ThumperMCS's Avatar
ThumperMCS
Agreed on all points
Old Mar 8, 2010 | 02:08 AM
Ottoman_FD3S's Avatar
Ottoman_FD3S
i still can't get in the mind set that a 16g is "too big" lol
coming from cars that run turbo's the size of ur head...
anyway.
ppl have to realize it's always a trade of.. a tiny asthmatic turbo like the stock one.. spools up fast because it's so small..
but it's little more than a hair drier up top...
if u look at the dyno graph.. you will see the power hits like a freight train at 4,000 rpm
for ppl lookin for straight line power.. that's still early enough..
by utilizing Dual Ball bearing turbos, playing with manifold design, and tuning..
u can get the spool down another 500rpm or so pretty easily..
Old Mar 8, 2010 | 07:37 AM
GO K4RT's Avatar
GO K4RT
anyway.
I know what you mean. A 16g is a tiny turbo in the DSM world. The turbo I have waiting to go on my Talon is a gt4294 journal bearing.
I wouldn't mind a 16g on the mini if we could bump up the rev limiter and we knew the limit of our internals. You could easily utilize it while road coursing but I just don't see why you would limit yourself on spool up time for a turbo that really isn't being pushed at the point where we start getting uncomfortable about the engine holding together.
Old Oct 6, 2012 | 08:34 AM
Hank Rearden's Avatar
Hank Rearden
TD04-13T from a Subaru WRX is a much better option for Prince THP engine.
Almost the same max BHP that a stock engine can handle safely as a TD05 big 16G
260bhp, 38Nm of torque, but no lag at all.
Faster spool up and max boost at 3800 rpm
Same or more power than an hibrid Alta Turbo at a MUCH lower price.
And if you want even more power with upgraded conecting rods, TD04-19T is THE choice, 340 hp capable with the same spool up as the 13T.
Old Oct 6, 2012 | 08:51 AM
Hank Rearden
TD04-13T or 15G are the right one for this engine.
Old Oct 6, 2012 | 09:13 AM
Mini///M's Avatar
Mini///M
Interesting....
So I should hold off on the G-Pop Turbo Upgrade? I need more ponies.
Old Oct 11, 2012 | 12:24 PM
ThumperMCS's Avatar
ThumperMCS
Lol that post is over two years old....
I don't have the R56 anymore, so needless to say no there will no kit that I was referring to lol...
With where tuning is on the 56...you're better off just doing a hybrid with G-pop or a JCW K03S ...keep the boost ~20psi and run meth injection.
Old Oct 11, 2012 | 01:57 PM
Mini///M's Avatar
Mini///M
Yeah I realized like a day after I posted lol. Yeah I think G-Pop may have to get it done. Thanks.
Mazarin
Sep 15, 2015 08:45 AM
Lyrebard
28
Nov 17, 2006 06:57 AM
UKDragon
62
Jul 14, 2006 10:19 AM
