Drivetrain does your inner cooler cause a lot of vibration?
so i search on here for a thread but did not find anything...
i just installed NM hot & cold side boost tubes today along with a helix inercooler and a cobalt skid plate.... happy with the products but when i fired up my mini, ran it at about 2500rpm for a few sec to let the system cycle and right away i noticed a lot of vibration.. more then normal, a lot more.. i can feel it in my foot, in the shifter, my cup holders shake wild even.. i think it may be the skid plate though... followed the instructions for the tubes, (not the IC, can you believe helix does not provide any
) and the skid plate was only 4 bolts but i cant understand the vibration...
also it feels like i lost some power with the install of the tubes and IC. even my velocity throttle booster seems less responsive. not sure if i did something wrong...after reading soo much about the ic, i was hoping to just be bidazzled by a huge gain but i'm not feeling that right now... anyone had any suggestions for this
) and the skid plate was only 4 bolts but i cant understand the vibration...also it feels like i lost some power with the install of the tubes and IC. even my velocity throttle booster seems less responsive. not sure if i did something wrong...after reading soo much about the ic, i was hoping to just be bidazzled by a huge gain but i'm not feeling that right now... anyone had any suggestions for this
I have no vibrations with my install. I did however feel like I lost some perkiness with the IC. However, I believe it is now a smoother response than it was, leading me to believe that my boost is no longer surging like it did with the stock IC. Dynolicious is showing more HP to the wheels as well. Seems like I lost a little top end though. :(
I think it is the skid plate vibrating. Even if it is tight, the vibrations from the engine are probably causing the body of the skid plate to resonate. When properly installed the Helix FMIC does not rattle.
You feel the difference with the FMIC on warm days especially pushing over 4000rpm and at particularly high speeds. You're actually just greatly reducing the amount of heat soak and of course the faster you're going down the road the better heat transfer will occur with the FMIC.
Don't get mad at the FMIC, it is one of the most important mods to have when you get a tune. The max boost pressure will surely be adjusted higher and the FMIC makes the most out of that boost gain.
No vibration here from the FMIC. I did start getting a vibration from the M7 turbo heat shield.
The M7 turbo heat shield mounts with only 2 long bolts rests on top of the exsisting heat shield (bad design). This contact point wore a hole through the thermal heat pad and there was metal to metal contact.
I removed the M7 turbo heat shield and no more vibration.
No vibration from my Helix FMIC. Might want to get back in there and make sure everything is tight
Ahhh the skid plate... my first thought was that it might be that... !thank you!... as far as the FMIC goes i do feel like i lost that perkiness, yes, but i have not been pushin it so hard because of the vibration.. so i'll recheck all my install, take the plate off and see if it still has the vibration.. hopefully i can get that pep back with the tune i'm getting from Jan next weekend..
Oh its quick without a tune and I can't wait to get a tune myself. Nut would almost be a waste of your JCW kit that you got. And if you have it on a lift when you do it take pics of your skid plate I want to see one on a MINI cause I might get one.
here it is online..., http://www.allminiparts.com/products...8/102-790.html mossmini has the same one, http://www.mossmini.com/Shop/ViewPro...86&SortOrder=1 but allminiparts.com is a little cheaper unless either is having a sale... just provides me more with piece of mind since i put my lower H&R springs on R56...i think it only weights about 9-12 lbs so it wasnt that bad... very easy install, 4 bolts.. now i just need to address the vibration.. a dampener between the frame and the plate perhaps
10 pounds?! Gees return that thing. My MINI is lowered too and I've been driving around lowered for over 20K miles without getting scrapes where that shield is protecting. I drive in Michigan too so we have some of the worst roads around. There are far better things to spend money on than that plate!
will do...
no not yet... going to tackle it this mon or tues probably...
i do notice this though, i miss the pep my mini had before i installed the new IC
! i read so many good post on here about how great they are but i'm just not impressed yet really... with my mods and turning on of my velocity booster it was more fun to drive
my instant gratification if you will.. now it feels like the car takes longer to get going, really lags in the lower rpms, i was expecting more... i hope a new tune will provide that again or i'm gonna be a bummed mini driver instead of a happy one...
you didnt lose power with the HELIX intercooler(barring the possiblity that you have a boost leak), the intercooler is proven to increase HP and most importantly maintain this power where the stocker heatsoaks! if the vibration is as bad as you say it is it is causing the kn ock sensors to activate and pull ignition timing which will lower power and cause the turbo to spool slower. I did testing on several automotive platforms testing motor mounts and vibrations definitely do activate knock sensors!
my instant gratification if you will.. now it feels like the car takes longer to get going, really lags in the lower rpms, i was expecting more... i hope a new tune will provide that again or i'm gonna be a bummed mini driver instead of a happy one...Last edited by Mark@Helix; Mar 7, 2010 at 10:33 AM.
Mark, I too feel as if it has lost a little "pep" The car is running great but I think with the stock IC it has more snap when you hit the gas.
I am pretty sure I lost a little on my top end as well. (yes, my Mini sees 140+ mph at least 2-3 times a week "legally".)
yes disconnect the negative terminal and hold the brake pedal down for about 15 seconds then reconnect, this will start the ecu from a blank slate. also retighten your hose clamp connections.
what is a MM muffle delete david
