From past experience I learned that the ecu cycles emission checks at a certain speed and under a constant load, the only way not to trip a light without the sim is to drive the car as if you were on a dyno so I drove 50ish miles roundtrip on and off the throttle and never cruising at a constant speed.once i had returned to constant 20s and 30s mph cel chimed went solid then flashed and turned off and has yet to return.
I will update if the cel comes back .
Nurburg at the Dorint hotel in a suite overlooking the start finish line of the F1 track.You can catch him at Joseph's bar and grill in the lower rightside level of the Hotel or clubs Pascha in klon ,paradise and oasis clubs in frankfort or club villa in Innsbruck.
Yep, i need this sim too. and i was waiting for others to be the guinea pig on this one. So James, are you saying the Riss o2 sim is working out of the box now?
I was thinking about driving up to Nurburg soon. Just before my time in Spain ends in June. Civilian FTW!
Its been ~2 weeks - How many miles w/o a cel? Do you think you'll have to re-tune the O2 Sim say if you have to replace the car's battery or disconnect the Sim?
picked up a misfire code(too large of meth jet) no you should be ok if the battery dies .
