View Full Version : Drivetrain (Cooper S)
Pages :
7]
12
15
16
- Drivetrain Turbo resonator delete
- Drivetrain 2011 MCS recall..
- Drivetrain Catless DP + Q300 question
- Drivetrain OBX-R Downpipe & Exhaust R56S Sound Clip Inside
- Drivetrain Spark Plug Gaskets
- Drivetrain Which way should I go?
- Drivetrain New Clubman owner, where should I start?
- Drivetrain Crank Pulley?
- Drivetrain Please help!! Spacers info
- Drivetrain Aquamist Meth Injection Question
- Drivetrain Downsides to accessport
- Drivetrain 2013 MCS Aftermarket
- Drivetrain air from the scoop
- Drivetrain Got my Mini tuned :-)
- Drivetrain Turbo muffler
- Drivetrain What do you think of my exhaust?
- Drivetrain CNT vs Q300
- Drivetrain Alta turbo owners, opinions?
- Drivetrain Okada Plasma Coils
- Drivetrain THP Engine with Big Turbo
- Drivetrain Experience: From Run-On-Flat to standard Contis
- Drivetrain Cutting intake box?
- Drivetrain Shifting cut
- Drivetrain Ebay Exhaust
- Drivetrain Will anyone code out a CEL from a DP?
- Drivetrain Borla Exhaust options
- Drivetrain Best Performance Exhaust
- Drivetrain Best Throaty Exhaust
- Drivetrain Helix Custom Tuning Days Oct. 4,5,6
- Drivetrain ram air intake?
- Drivetrain 2012 exhaust rumble
- Drivetrain Can someone explain this Mod
- Drivetrain Hi
- Drivetrain Injen Cold Air Intake on 2011 MCS
- Drivetrain Drone likelihood on Alta 3" Downpipes with JCW exhaust on an automatic
- Drivetrain How do I remove a wheel stud that was installed with loctite?
- Drivetrain Replacement Air Filter
- Drivetrain My MSC now with the JCW Turbo..
- Drivetrain Forge Intercooler on a 2011 MCS
- Drivetrain What to replace OEM rally lights
- Drivetrain BSH oil catch can question?
- Drivetrain Caliper Mounting Bolt Measurement
- Drivetrain Anyone have pics of how a silver/polished FMIC looks through the front grill?
- Drivetrain RennTech Tune
- Drivetrain Akrapovic v. Milltek DP
- Drivetrain Is Your R56 MINI Overboosting?
- Drivetrain bumper removal w/ rally lights
- Drivetrain Alta AccessPORT
- Drivetrain Who installed DDM Works RIS on 2011 R56/R55?
- Drivetrain Cars runs like crap after FMIC installation
- Drivetrain Do i need an oil pump?
- Drivetrain Wagner Mini Cooper S Intercooler ??
- Drivetrain High Air/Fuel Ratio (Running Lean)
- Drivetrain OEM Noisemaker Delete
- Drivetrain Must find more power - cylinder head work?
- Drivetrain Stromung Exhaust for R56!!! Feeler thread. Please comment!
- Drivetrain Acessport + super knock and other codes
- Drivetrain M7 VELOCITY Throttle Booster
- Drivetrain Warranty
- Drivetrain ED catted DP + Custom Exhaust issues
- Drivetrain Siezed engine?
- Drivetrain Just ordered my next mod...exhaust!
- Drivetrain My turbo is dying or what? HELP!
- Drivetrain On/Off Boost...Help!
- Drivetrain StopTech Rotors?
- Drivetrain Engine oil pressure error screen
- Drivetrain Transmission issues
- Drivetrain Intercooler partially covered by bumper???
- Drivetrain Akrapovic DP? Two words...
- Drivetrain CAI myth for turbocharged engines
- Drivetrain Chinese FMIC
- Drivetrain Broken BOV?
- Drivetrain JCW Turbo Swap
- Drivetrain Deletion of 2nd cat and Resonator 2012 Cooper S
- Drivetrain Finally a working dipstick!!
- Drivetrain New hood vents
- Drivetrain R56 Spark Plug Gap
- Drivetrain Gaskets, Bolts, V-Band Clamp?
- Drivetrain Helix FMIC Install Review
- Drivetrain BSH OCC Fitment with or without PCV delete
- Drivetrain MINI cooper S without MAF
- Drivetrain Engine temp
- Drivetrain Intercooler size question.
- Drivetrain Gintani tune experience anybody?
- Drivetrain Check Engine Light From Downpipe Install Fix
- Drivetrain Loss of SOME boost while shifting
- Drivetrain **The OFFICIAL THREAD** for Bytetronik FullAccess Tuning Kit - R50/R52/R53
- Drivetrain Any place online I can order mufflers only?
- Drivetrain Unichip
- Drivetrain Motor Disassembly
- Drivetrain Riss Racing catless DP fitment
- Drivetrain Whats next...for aftermarket parts
- Drivetrain Riss Racing Catless DP, JCW Sound Clip
- Drivetrain Turbo heat control
- Drivetrain Catless Downpipe, Loss of torque down low?
- Drivetrain picture request inside a Forge IC
- Drivetrain K&N appolo intake filter
- Drivetrain Some Intakes Thoughts
- Drivetrain Motor Blew!!!!!!
- Drivetrain Another one of those Exhaust threads....And!
- Drivetrain $200!....?
- Drivetrain Best CAI
- Drivetrain is the JCW tuning kit worth it?
- Drivetrain Let's talk short shifter...
- Drivetrain Wideband O2 Sensor Placement
- Drivetrain Throttle position sensor (TPS) on scangauge II
- Drivetrain How much labour?
- Drivetrain Anyone else get this code on their 11'+ MCS?
- Drivetrain wish i could attck my mini with mods...
- Drivetrain Accessport ecu tuning issues?
- Drivetrain Alta Hard intake pipe unavailable?
- Drivetrain WANTED: Late 08 MCS and Countryman Portland, OR area!!!!
- Drivetrain Alta vs. K&N Typhoon Intakes
- Drivetrain Who can tune my car in Miami??
- Drivetrain Tuning?
- Drivetrain Evolve Automotive Tune for R56 MCS - Impressions
- Drivetrain DIY CAI Cooper S
- Drivetrain What type of transmission on a 2006 Mini Cooper S Convertible?
- Drivetrain Scorpion Cat-Back Exhaust
- Drivetrain BSH Oil Catch Can - No Baffle!
- Drivetrain raising the boost
- Drivetrain Intercooler Sprayer. How about Turbo Sprayer?
- Drivetrain Finally installed
- Drivetrain looking for a pass side boost pipe to send for an example to reproduce it
- Drivetrain Does anyone know what happened to WAY??
- Drivetrain Reading and understanding data logs
- Drivetrain have a little $$$$...next mods...???
- Drivetrain Photos of your boost tubes and hoses
- Drivetrain Is ALTA Performance not pursuing the AP for the 2011+ models?
- Drivetrain Forge Reasonator Delete Hose
- Drivetrain JCW engine VS S engine question...
- Drivetrain Nm engineering tune
- Drivetrain Anyone with the NM tune?
- Drivetrain GT25r or Alta Billet Turbo??
- Drivetrain JCW Intake - What's the difference?
- Drivetrain Borla exhaust R55?
- Drivetrain R56 exhaust questions/ideas
- Drivetrain Riss Racing Exhaust set up, good deal or not??
- Drivetrain Adding another MINI - 07 R56 S - What to get with $2k?
- Drivetrain Manutal Transmission Fluid
- Drivetrain DoS Intake vs. hood scoop style intake
- Drivetrain Wastegate actuator
- Drivetrain NM-Eng Upgrades installed
- Drivetrain Aftermarket Turbo Pulley - Advantages & Disadvantages
- Drivetrain 18" Sparco Assetto / Tire Size?
- Drivetrain ClutchMasters FX100 Review
- Drivetrain Opinions on whether I should go with..
- Drivetrain Possible scenarios of engine seizing?
- Drivetrain Cold Air Intakes Mythbusted
- Drivetrain Helix bov DIY videos or pics?
- Drivetrain Tunes on the track?
- Drivetrain Need help with information about resonator delete on 11' MCS
- Drivetrain Anyone had a similar problem ?
- Drivetrain Changing Clubbie from auto to stick?
- Drivetrain Track days are good for your engine oil
- Drivetrain Aftermarket intercooler - Lower grill keep it or ditch it?
- Drivetrain Intercooler or Exhaust advice?
- Drivetrain Some exhaust questions for you all...
- Drivetrain DIY heat sheild?
- Drivetrain WMW Turbo Back Exhaust
- Drivetrain The Always Up-to-Date Thread on Tuning 2011+ (N18) MINIs
- Drivetrain Any heavy duty axles driveshafts
- Drivetrain Corsa Exhaust,Reflective Sound Cancellation for your Mini!
- Drivetrain Why no iphone/android based programmers?
- Drivetrain whats that hidin behind that cat!
- Drivetrain Accessport stage 2 compatible exhaust that is quiet?
- Drivetrain please Help
- Drivetrain R56 Coil pack
- Drivetrain Forge Diverter Valve
- Drivetrain Tuning/upgrading the N14 engine
- Drivetrain Forge intercooler Vs Ebay
- Drivetrain Durability of OS Giken GT Clutch (Survey)
- Drivetrain AEM Cold Air Intake on a N18
- Drivetrain having issues with jan/revolution mini
- Drivetrain Possible new turbo from Blitz?
- Drivetrain NM Tune
- Drivetrain clutch bleeding?
- Drivetrain Best performance mods
- Drivetrain Clutch Replacement Tips?
- Drivetrain Boost leak, faulty tune, or what? HELP!!!
- Drivetrain OBX DP + OBX Cat back exhuast sound clip?
- Drivetrain My exhaust= obx catless DP + 2.5" pipe... THE END...lol
- Drivetrain Forge Motorsports
- Drivetrain Anyone installed NM Eng downpipe back exhaust?
- Drivetrain clutch bleed/DSC warning
- Drivetrain LSD Options - Mfactory?
- Drivetrain Want Better Tone
- Drivetrain What about the Das Intercooler?
- Drivetrain 2011 MCS Alta BOV Install Question
- Drivetrain blockheater
- Drivetrain securing the flywheel
- Drivetrain Trouble finding the right brakes for 08 S?
- Drivetrain Reset ECU & Best Tuning Options (Flash ECU, RMW, ALTA Port, Other Options)
- Drivetrain Remove original intake pipe from grill?
- Drivetrain Removal of Carbon from Valve Area with Steamcleaner?
- Drivetrain Riss Racing DP/Invidia CB combo. Exhaust leaks...
- Drivetrain Throttle Body and Inlet Manifold Cleaning
- Drivetrain Drone @ 3k from JCW tuning kit
- Drivetrain Please Help with alta intake
- Drivetrain What to do next?
- Drivetrain Evolve Sports Cat DP
- Drivetrain upgrades for auto?
- Drivetrain My new custom exhaust
- Drivetrain Another Comparison: DDM intake vs. Stock w/ K&N Filter
- Drivetrain Forge Valves
- Drivetrain DDM Street Intake too loud
- Drivetrain Did the noisemaker delete. Am I nuts or does throttle response improve?
- Drivetrain Who would've thought?....All it would take is a K&N drop in
- Drivetrain CAI question??
- Drivetrain Replace MINI engine with Cobalt SS engine???
- Drivetrain Aquamist HFS-4
- Drivetrain For those who never leave Gen2 forum... Northeast (CT) RMW Tune 2012 signup
- Drivetrain DDMWorks CAI
- Drivetrain BSH Oil Catch Can & PCV Delete
- Drivetrain DoS Water2Air Intercooler Opinions from Owners
- Drivetrain So Far not impressed by Forge :(
- Drivetrain Video sound of the DDM Street Intake on my 2011 MINI Cooper S
- Drivetrain BOV specific fantastic sound
- Drivetrain Will Oil Catch Can Void Warranty?
- Drivetrain Oil Changed turned bad
- Drivetrain new exhaust
- Drivetrain nm intake installed
- Drivetrain What's the differenece??
- Drivetrain Exhaust decisions
- Drivetrain Replacing valve cover - sealant needed?
- Drivetrain BOV question
- Drivetrain K N Apollo intake
- Drivetrain Anyone know what kind of exhaust this is??
- Drivetrain way around rev hang?
- Drivetrain LSD install
- Drivetrain NM Engineering ECU Flash
- Drivetrain Anyone keep stock exhaust and remove 2nd Cat?
- Drivetrain Most ridicule quote! JCW exhaust...
- Drivetrain New Catless DP comming soon
- Drivetrain water / meth anyone?
- Drivetrain Boost drop from stage II tuned 07 MCS??
- Drivetrain alta cobb
- Drivetrain Is this a stock, or an after market exhaust?
- Drivetrain Alternative for intercooler muffler?
- Drivetrain Introducing the Shift Rx from TyrolSport
- Drivetrain Looking for the front mount intercooler with the side tanks that block the radiator
- Drivetrain Best FMIC
- Drivetrain 2011 MCS Intake, I want Psh noise from turbo :)
- Drivetrain ANTI-mod question!! what do you recommend??
- Drivetrain GTB Performance Official First Look : AR Design Downpipe!
- Drivetrain Blow Off noise for '12 MCS
- Drivetrain Why does everyone seem to hate on the Alta CAI?
- Drivetrain Mods for '12 MCS 6spd
- Drivetrain Opinions needed: "inherited my wife's Cooper S"
- Drivetrain New member... sorta new problem
