Drivetrain Blow Off noise for '12 MCS
Old Feb 7, 2012 | 08:50 AM
pvillarraga's Avatar
pvillarraga
What would be the easiest/cheapest way to gain Blow off noise.
Will putting a K&N air filter work?
Old Feb 7, 2012 | 09:24 AM
automan21's Avatar
automan21
No, you are going to need a "cold" air intake like one from Alta, NM, M7 or one of the other brands. I wouldnt spend more than like $300 on one.
Old Feb 7, 2012 | 10:00 AM
Boosted_Mini's Avatar
Boosted_Mini
You can get a used intake for cheap.. I have the alta and i can hear my DV.. we DONT have BOVs.. we have diverter valves..
Old Feb 7, 2012 | 10:51 AM
gothmdoc's Avatar
gothmdoc
aka bypass valves
Old Feb 7, 2012 | 11:46 AM
mastawyrm's Avatar
mastawyrm
A cone on the MAF will give you the sound. Some will say it hurts performance but I haven't noticed anything from the butt dyno.
Old Feb 7, 2012 | 12:10 PM
teamrubixcube's Avatar
teamrubixcube
DoS intake is a bit trickier to install but the sounds are AWESOME. The intake sucks in air behind the bulkhead so the noise is very audible
Old Feb 7, 2012 | 03:09 PM
walk0080's Avatar
walk0080
Find a used JCW intake if you want to stay MINI "stock". Makes the noise plenty audible without being too annoying IMO.
Old Feb 7, 2012 | 03:16 PM
Boosted_Mini
Weird I drove a 2012 JCW Coupe and it was overall extremely quiet in every aspect.. from exhaust, engine, to the dv noise.. one of my turn offs to it.
Old Feb 7, 2012 | 03:18 PM
walk0080's Avatar
walk0080
Possibly a personal thing (what is loud enough)... but did you drive it long enough to warm up? I find it takes at least 10 minutes this time of year for the car to get 'loud' as it were.
Old Feb 7, 2012 | 03:26 PM
Boosted_Mini
20 min drive in 75* weather here.
But they told me they insulated the coupes more than other JCW models.. which i found depressing as well.. granted I currently run a catless TBE on my MCS I guess thats where my comparison comes in.
Old Feb 7, 2012 | 03:55 PM
pvillarraga
What do you mean by a cone. Im new to this. Will it void any warranties. Do you have pictures.
Old Feb 7, 2012 | 04:00 PM
Boosted_Mini
I dont think an intake can void a warranty.. if you are on a budget the alta is generally the cheapest one i find used. But it is still a good piece. People argue intake temps with every intake but yet not ONE person has ever backed up their claims with data logging or solid information.
Old Feb 9, 2012 | 08:17 AM
steptimeeditor's Avatar
steptimeeditor
I installed the DoS CAI on my MCS and now my BPV sounds amazing and beastly. It is a slightly tricky to install, but very well worth it. My installation took about 90 mins in total.
Old Feb 9, 2012 | 11:19 AM
mastawyrm's Avatar
mastawyrm
Just a simple cone filter from advanceauto.
Old Feb 9, 2012 | 12:03 PM
teamrubixcube
^ Why don't you take off the bottom half of the filter housing? It will be a much cleaner look. I believe you just have to pull up on it form there. That part is removed for installation of the DoS.
Old Feb 9, 2012 | 12:17 PM
Boosted_Mini
Couple of questions:
1. Do you take your mini mudding cause i have never seen so much water/dirt in the engine bay lol. Hopefully that filter isnt getting wet.
2. How are gaining anything this way? Are you running the stock snorkel to the headlight?
Your setup looks like you have a filter in a really hot area that is completely enclosed.
Old Feb 9, 2012 | 12:19 PM
mastawyrm's Avatar
mastawyrm
Well it's not heavy and I don't really care about the underhood appearance. I also have the top half and filter stored in the boot where the spare would go so I can easily swap back even if I'm away from home.
The stock snorkel has an elbow that normally feeds into the bottom half and I turned it so it points straight up into the bottom side of the cone. I don't expect any gains this way, I just did it for the sound and as long as I can't tell that it got slower, I'm fine. It's all about fun to drive to me rather than dyno numbers or track times. And yes, my Mini is not afraid of sliding around dirt roads :P
Old Feb 9, 2012 | 12:23 PM
Boosted_Mini
Just curious thats all.
Do you have your scoop opened? I would remove that stock lower portion so more cold air can get in that air and hopefully lower some EGTs.. if you have an AP you should log your Air temps with the stock vs the cone and see what the differences are.
Old Feb 9, 2012 | 12:25 PM
mastawyrm's Avatar
mastawyrm
I still have the stock grill in the scoop but it's open being a 2010
Old Feb 9, 2012 | 12:26 PM
Boosted_Mini
gotcha I pulled mine out entirely haha.
Well let me know if you do the AP tests. Would be nice to see some real logging on things.
Old Feb 10, 2012 | 11:24 AM
Melangell's Avatar
Melangell
DoS....
ericbryant24
Aug 29, 2015 01:55 PM
Fizzyx
Aug 14, 2015 08:24 PM
minipopkart
Aug 13, 2015 05:22 AM
Red Raven
Aug 11, 2015 04:48 AM
pocketmaster
Aug 6, 2015 01:41 PM
