Drivetrain Wastegate actuator
Old May 13, 2012 | 03:28 PM
Porthos's Avatar
Porthos
Wastegate actuator
I think mine is messed up. I am have looked at the other threads regarding the wastegatge and they really aren't helping that much. I have a stage 3 Alta AP tune and it is not hold boost. I was under the hood this morning emptying out my Catch can and decided to look around. I wanted to see if there was anything loose and I found the actuator was pretty loose. I looked through my Bentley manual and on realoem.com to see there was a replacement and it doesn't look that way. Does anyone know if it is replaceable or doe you have to replace the vacuum part with it or is this a full turbo replacement situation.
Old May 14, 2012 | 07:52 AM
Porthos's Avatar
Porthos
Somebody out there has to know about this....
Old May 14, 2012 | 08:25 AM
2009R56JCW's Avatar
2009R56JCW
Mine was loose from the factory and had zero issues.I would look at the hot and coldside pipes to see if there is a leak or loose connection and check the maf to make sure it is plugged in,if maf is not plugged in or is fubared you will not build boost.The only other time I had a issue was when my hpfp went out.If it is the hpfp install new plugs when you get the new fuelpump installed.
Old May 14, 2012 | 10:27 AM
Porthos's Avatar
Porthos
It has a new HFPF in it. It generates boost but, is not holding it. Like while at the Dragon I would start heading up hill it would generate boost then blow off generat boost and hold it about half of what it should be. I will check the hoses and the MAF to see how they are.
Old May 14, 2012 | 10:33 AM
2009R56JCW's Avatar
2009R56JCW
Sounds like the charge hoses.Check all the hoses,mine leaked at the turbo intake muffler delete pipe(would build but not hold boost) and on the coldside going to throttlebody(would not boost at all).
Old May 14, 2012 | 11:31 AM
Porthos's Avatar
Porthos
Hmm so the waste actuator is suppose to be loose. I thought it was suppose to have a little play but not be loose like a Thai hooker.
Old May 14, 2012 | 12:02 PM
2009R56JCW's Avatar
2009R56JCW
Lol.Had as much play as a russian trick on craigslist.
Old May 14, 2012 | 12:13 PM
Porthos's Avatar
Porthos
Hmmm though humor me here, if it is the acuator is that a replacement part or do I have to do more to fix it.
Old May 14, 2012 | 12:26 PM
2009R56JCW's Avatar
2009R56JCW
Check realoem to see if a replacment is offered,if not check with tom bush or orlando mini for adjustment spec.
Old May 14, 2012 | 12:33 PM
Porthos's Avatar
Porthos
No replacement part on realoem. It looks like it is attached to the vacuum actuator and it does look like it is a replaceable piece.
Old May 14, 2012 | 12:36 PM
2009R56JCW's Avatar
2009R56JCW
Needs a part# to be a replaceable part.keep digging on real oem.
Old May 14, 2012 | 06:13 PM
mamut's Avatar
mamut
mine is loose too...no boost issues really. holding around 15-16psi on stage 1 fmic. check the tubes, vacuum lines, and bov.
Old May 14, 2012 | 08:29 PM
ThumperMCS's Avatar
ThumperMCS
Have you not checked the DV?
Very likely culprit
Old May 14, 2012 | 09:08 PM
DICKS GARAGE R53's Avatar
DICKS GARAGE R53
You are running the AB stage 3, are you sure its not hitting boost cut? After 20psi on some cars it will kick in whenever it wants.
Old May 15, 2012 | 02:02 AM
robbo mcs's Avatar
robbo mcs
What part are you actually talking about? Pics or diagrams?
What codes have you got from the ecu? The car will leak boost for quite a while before it throws the 2885 boost pressure deviation code.
As others have said I would check the diverter valve first.
Old May 15, 2012 | 06:54 AM
Porthos's Avatar
Porthos
The thing is that it happens even before hitting that high now. It used to do it only going up hill or when it hit 20psi. Now it just won't hold it.
Diverter valve is brand newish. I got WMW's diverter valve about a year and a half ago.
http://realoem.com/bmw/showparts.do?...44&hg=11&fg=50
The bar right above #10.
Old Jul 18, 2012 | 11:12 AM
Theo_207RC's Avatar
Theo_207RC
hey guys, im new here. found this thread while doing a google search. Porthos, did you get your issue sorted out?
Old Jul 19, 2012 | 11:59 AM
SooperCuperErik's Avatar
SooperCuperErik
Year and a half ago... while thats fairly "new", having increased boost could have easily ripped the diaphragm within the DV at either 1 day old or 500days old... a ripped diaphragm will not allow you to build boost as it is constantly bleeding off.
Or... check your pressure converter...
#2... the valve inside can get dirty and clogged and cause it to stay open/closed, which actuates the wastegate as you build boost.
see here http://www.etuners.gr/en/index.php?s=12&t=247
Old Jul 19, 2012 | 12:05 PM
Theo_207RC's Avatar
Theo_207RC
Check out my thread about diagnosing turbo issues...simple diy stuff
Levers_and_Gears
Sep 28, 2015 04:42 PM
MiniUnz
Sep 14, 2015 11:11 AM
wildwestrider
Sep 4, 2015 06:25 AM
spackletooms
Sep 1, 2015 10:12 PM
WestfaliaR
Aug 19, 2015 08:01 AM
