Drivetrain Riss Racing catless DP fitment
Old Jul 6, 2012 | 01:41 PM
automan21's Avatar
automan21
I have searched on realoem and found two diff part #s for the stock dp. I ordered and catless RR dp and it was just advertised as 07+. I have a 2011, Is it that much of a difference between the two? Thanks.
It seems to be the last of the RR dp's and I wanted to get the good deal on the price.
Old Jul 6, 2012 | 04:26 PM
countryboyshane's Avatar
countryboyshane
Most of the RR downpipes fit the OEM cat-back just fine. If you have an aftermarket cat-back it's kind of a toss up and you might have to make an appointment at the local exhaust shop.
Old Jul 6, 2012 | 04:43 PM
automan21's Avatar
automan21
Its all stock except for the resonator removal and the magnaflow muffler. Same coupler at the stock cat.
Old Jul 6, 2012 | 06:07 PM
automan21's Avatar
automan21
Just ordered new hardware for the dp install. Flange bolts, nuts, clamp and gasket.
Old Jul 7, 2012 | 05:10 AM
mcmmotorsports's Avatar
mcmmotorsports
Re-used my stock stuff. We shall see if I have any issues.
Old Jul 7, 2012 | 08:53 AM
automan21's Avatar
automan21
Can anyone chime in who has a '11 and this dp? As long as I bolts up to the turbo properly I won't worry bout the exhaust figment.
Old Jul 14, 2012 | 04:12 PM
automan21's Avatar
automan21
Anyone tried spacing out the o2 sensor with spacers of some sort to try and trick them into not throwing a code?? You know less of the sensor element in contact with the gases thus no cel.
Just a thought.
Old Jul 14, 2012 | 04:25 PM
mcmmotorsports
I have seen a adapter that has similar properties as a cat for sale on eBay, not sure if they work for the Mini. Your best bet, most sure fire way, is to just get a tune for it. I have no regrets.
Old Jul 14, 2012 | 04:44 PM
automan21's Avatar
automan21
Tunes for a 2011 are a bit scarce. Many CA tuners for 2011+ don't Wana bypass the cat cel from what I've read.
Was just trying to do a Joey mod maybe I can make a breakthrough in catless dp cels lol.
Old Jul 14, 2012 | 09:47 PM
countryboyshane
Been there done that. You can't fool the 2nd generation MINI ECU from Bosch.
Old Jul 16, 2012 | 09:01 AM
Porthos's Avatar
Porthos
The fitment issues I had with the RR pipe was that O2 sensor bung was lower then the stock one so i had to drill up my heat shield to get it to fit.
Old Jul 16, 2012 | 11:18 AM
automan21's Avatar
automan21
That doesn't sound bad, as long as it bolts up properly to the stock turbo and bottom vclamp.
Old Jul 16, 2012 | 01:01 PM
Miykl's Avatar
Miykl
Just a thought.
I screwed around with the "antifouler" spacers. Tried up to 3 of them. Worthless for our cars. I saw Way is selling/beta testing a "fix". But personally I'd just do what I did do, just go ahead and get a tune. btw- if you do try the spacers then get a tune, remove the spacers or you will get a seconday O2 sensor too lean code. Even with just one spacer in place. Guess how I know.
Old Jul 16, 2012 | 01:22 PM
Miykl's Avatar
Miykl
I had a simlar issue with the upper O2 bung. I just bent the heat shield a bit to fit it.
Old Jul 16, 2012 | 01:29 PM
automan21's Avatar
automan21
Sounds like a plan.
Last edited by automan21; Jul 16, 2012 at 01:29 PM. Reason: i spell like an 8th grader lol
Old Jul 16, 2012 | 01:31 PM
automan21's Avatar
automan21
Just waiting for the stuff to come in and I will be installing myself.
Old Jul 16, 2012 | 01:32 PM
automan21's Avatar
automan21
Just to be sure, the cel will just stay lit before the tune but it shouldnt effect performance right?
Old Jul 17, 2012 | 06:22 AM
Miykl's Avatar
Miykl
Correct. ...at least I had no issues other than the light... but I didn't even wait a week b4 getting the tune.
Old Jul 17, 2012 | 12:32 PM
automan21's Avatar
automan21
cool thanks
Old Jul 17, 2012 | 12:46 PM
Bor's Avatar
Bor
somebody got a good write-up on how to install a DP onto a stock set-up please ?
thanks!
Old Jul 23, 2012 | 04:38 PM
automan21's Avatar
automan21
thanks!
From what Ive found the Alta site has a decent write up.
Old Jul 23, 2012 | 07:10 PM
Porthos's Avatar
Porthos
If you want it I will sell it to you as I need to put the stock one back on for a little bit and I want to get the ABF DP.
Old Jul 24, 2012 | 03:32 PM
automan21's Avatar
automan21
Got one already.
Old Feb 23, 2014 | 09:12 PM
elsenordave's Avatar
elsenordave
So you're saying if I run a tune remove the spacer?
Chibi2
May 19, 2016 03:46 PM
pahg
Oct 5, 2015 11:50 AM
Ovrclck
Oct 5, 2015 09:45 AM
Island maser
General Discussion
Oct 1, 2015 01:09 PM
potterstein
Oct 1, 2015 07:10 AM
