Drivetrain clutch bleed/DSC warning
So this is a repeat of another thread I posted in the r56 section, just wanted to get a response as fast as possible....So I've just finished replacing my clutch and flywheel, and now my car is flashing a warning about the DSC needing to be adjusted by the dealer or something. It says in the Bentley this is normal, and the dealer needs to reset the steering calibration with the DSC or something. Is this costly, and I assume I should get an alignment before I do this? Also, do you need a power bleeder to do the clutch and brake bleed? I accidently depressed the slave cylinder rod so now my pedal is very spongy, and I definitely need to bleed the clutch and I might as well change all the fluid while I'm at it. Thanks everyone.
DSC needing adjustment? That doesn't make sense to me. When I dropped my front subframe and reinstalled everything, this happened to me, but I know that I pinched an ABS sensor wire when putting things back together. I bet it's something small like that. The dealer wanted $125 to even tell me what sensor was bad. Talk about customer service!
Sep 22, 2015 02:05 PM
Sep 16, 2015 06:22 AM
Sep 16, 2015 06:18 AM
