Drivetrain Help needed! Cant find replacement stud
Old Jan 30, 2012 | 03:55 PM
mamut's Avatar
mamut
when taking off the oem downpipe to replace it with the riss racing unit, i broke two studs on the bracket where it attaches to the engine.
#4 is where the stud is that attaches to the engine. I cant find it anywhere and the local dealership has no clue. On one end it has a star to screw it in the engine.
for the time being, is it safe to drive the car?
Old Jan 30, 2012 | 04:02 PM
bluefox280's Avatar
bluefox280
Got a photo of the stud you snapped off?
- Erik
Old Jan 30, 2012 | 04:15 PM
mamut's Avatar
mamut
I'll get a picture as soon as I get home from work.
Old Jan 30, 2012 | 06:53 PM
richardsperry's Avatar
richardsperry
Try 11127534005
Old Jan 31, 2012 | 10:59 AM
p8ntbollr's Avatar
p8ntbollr
I saw something at autozone that looked extremely similar to the studs your talking about. Im pretty sure they were labeled as carburetor studs, might wanna check there if you dont find it anywhere else.
Old Jan 31, 2012 | 01:54 PM
mamut's Avatar
mamut
I think I found my stud :-). Part#11627583110. Looks to be the same stud that I need
Old Jan 31, 2012 | 04:20 PM
mamut's Avatar
mamut
This is the stud with nut. On the left side if the stud is the star fitting to screw into the engine.
Old Jan 31, 2012 | 08:15 PM
Mike@Tech Division's Avatar
Mike@Tech Division
If I'm not mistaken it should be #6 in this image.
Part number 11117630213
Old Feb 1, 2012 | 04:52 AM
mamut's Avatar
mamut
That's what I ordered from Mini of South Atlanta but it was a different stud.
Old Feb 1, 2012 | 06:25 AM
richardsperry
Man you buggered that stud up.. Ever hear of Aerokroil?
Old Feb 1, 2012 | 08:23 AM
Mike@Tech Division
Oops yeah, I mistook it for the other location. The 2 toward the front are smaller and shorter.
Did you try ordering the stud in the image you originally posted? The one marked 3 in the lower right of the image? The specs are the same from what I measured on a spare block I have.
Old Feb 1, 2012 | 08:22 PM
oxspeed's Avatar
oxspeed
personally I would just dye the stud... the threads dont look like their in that bad of shape. My only concern would be the situation of the threads inside the block. but your going to need to tap it any way if there messed up. local auto parts store should have the needed tools.
Old Feb 2, 2012 | 09:51 PM
mamut's Avatar
mamut
The stud came out of the block without a problem. It's the nut that held the downpipe bracket to the block that was the problem. Spraying the damn thing with pb blaster and clamping it down while trying to unscrew it, it didn't even budge. This one luckily gave way but the other one just snapped. Also two of the three bolts on the top heat shield broke off as well due to rusting. When I get these replacement parts everything will be brushed with anti-seize. might as well take that heat shield off and replace it with an aftermarket one, if anyone has one for sale :-)
Old Feb 3, 2012 | 05:14 AM
richardsperry
PB Blaster has got nothing on Kroil...
Old Feb 3, 2012 | 05:59 AM
mamut's Avatar
mamut
Haven't heard of this aerokroil but I'll be sure to check it out.
KrisMiss
Jan 3, 2016 02:02 PM
rckrzy1
Aug 26, 2015 09:12 AM
Aug 12, 2015 01:24 PM
nomar116
Aug 10, 2015 11:24 PM
