Drivetrain Forge BOV
Old May 21, 2011 | 04:02 PM
snyderminis's Avatar
snyderminis
Forge BOV
I need some help installing a forge bov kit their are to ports on the bov i understand where the top one on bov goes but no where in the instructions does it say where the bottom one goes i am assuming to the selinoid as well but not sure could use some help if anyone else installed the kit.
Old May 21, 2011 | 06:19 PM
Octane's Avatar
Octane
The bottom port on the DV connects to the metal nipple on the soleniod ( inline and on oppisite side of solenoid where the manifold intake line connects to the solenoid) and the top port on the DV connects to the vertical nipple on the soleniod. I bought mine from Way Motor Works and recieved 3 pages with text and pictures that was very clear and made installation quick and easy. If you want more help please send a PM with your email and I will scan the instructions and attach to a return email, good luck. BTW you will be very happy with the performance of the Forge DV it is a huge improvement over the OEM.
Old May 22, 2011 | 07:41 AM
snyderminis
Thanks Octane that answers my question perfectly cant wait to see how the mini acts going to install it in about 20 mins.
Old May 23, 2011 | 01:28 AM
turtle343's Avatar
turtle343
i really want to get the Forge part. which boost spring do you use? was it easy to figure out the spring you needed? i wanted the WMW one but they don't seem to ship to Australia.
Old May 23, 2011 | 01:49 AM
Octane's Avatar
Octane
Try Way Motor Works.
http://www.waymotorworks.com/
I bought mine there. After you install the Forge D/V you can change to either of the two springs supplied. You can change springs in just a few minutes because you do not have to remove the D/V to change springs.
Old May 23, 2011 | 02:04 AM
turtle343's Avatar
turtle343
i have seen the forge one at other websites, way don't ship to Australia. How did you know which spring you needed? i have a cooper S with JCW kit, DP , RMW tune and soon Alta FMIC. Does one spring say modified and one say stock? sorry for silly questions but i have no idea about putting things on my car.
Old May 23, 2011 | 02:14 AM
Octane's Avatar
Octane
You get two springs one is green and for lower boost (10 -15 psi) and a yellow spring for higher boost (15-23psi). I am just going by memory on the boost values but I think that's close you can call a supplier of your choise to get that info when you want to order part. With the RMW tune you should be using the yellow spring.
Old May 23, 2011 | 03:24 AM
ThePenl's Avatar
ThePenl
The spring, boost pressure ratings for the FM207V are as follows:
Green: 0-10 psi, this will be fitted as standard in your valve
Yellow: 10-16 psi, this should be supplied as an alternative in your box.
Blue: 16-22 psi
Red: 22 psi upwards
I got this info from Czar. I guess he doesn't mind to post it here.
Old May 23, 2011 | 08:29 AM
snyderminis
Car runs alot smoother now that i installed the bov i am using yellow spring i have stage 2 tune with my AP i wish i wouldve done the spacer as well maybe i will order that next anyone on here running the bov and spacer together
Old May 23, 2011 | 09:24 PM
turtle343's Avatar
turtle343
awesome, thanks guys.
Old Jul 3, 2011 | 10:01 PM
akng's Avatar
akng
Blue: 16-22 psi
Red: 22 psi upwards
I thought the Forge BOV Kit only comes with the Green and Yellow springs. How can we get the Blue and Red springs?
Old Jul 4, 2011 | 05:10 AM
robbo mcs's Avatar
robbo mcs
Communicate directly with the manufacturer at forge. They are a UK based company. Contact details are freely available on their UK website
Robbo
Old Jul 4, 2011 | 09:57 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Here are the correct specs for the springs:
Green - 5-15 PSI
Yellow - 15-23 PSI
Blue - 23-30 PSI
Red - 30 + PSI
If you want the blue or red springs we will get them for you, but 99% of people aren't going to need them.
Also we do ship to AUS, just we have to get wire transfers for payment.
Old Jul 4, 2011 | 02:44 PM
czar's Avatar
czar
Blue: 16-22 psi
Red: 22 psi upwards
Green - 5-15 PSI
Yellow - 15-23 PSI
Blue - 23-30 PSI
Red - 30 + PSI
Hmm seems there is a conflict of pressure ratings between information supplied direct from Forge here in the UK and the USA!
Old Jul 4, 2011 | 07:54 PM
Melangell's Avatar
Melangell
Went there, didn't like it, went back OEM... Good luck.
Old Jul 4, 2011 | 08:38 PM
turtle343's Avatar
turtle343
what was wrong with it?
Old Jul 5, 2011 | 05:35 AM
///Mflossin's Avatar
///Mflossin
details?....
Old Jul 5, 2011 | 09:28 AM
sooper_cooper's Avatar
sooper_cooper
Reports from those who have upgraded to the Forge are very good. Can you elaborate?
Old Jul 5, 2011 | 11:35 AM
akng's Avatar
akng
We are talking about the Forge BOV (http://www.waymotorworks.com/forge-blow-off-valve.html).
Or are you talking about the Forge BOV Adaptor (http://www.waymotorworks.com/forge-b...r-s-turbo.html)?
Please confirm. Thanks!
Old Jul 5, 2011 | 11:44 AM
sooper_cooper
Good point akng. I thought the thread was about the first link in your reply above, the entire BOV assembly upgrade as opposed to just the adapter.
Old Jul 5, 2011 | 07:24 PM
Melangell's Avatar
Melangell
The BoV. Way installed it. When under light turbo load and pushing the clutch in, it caused a flutter sound, kinda like Chevy Chase in Caddyshack practicing putting. I just hated the sound. At the Dragon, tearing through the turns, turbo screaming it was amazing but... Driving through town it gave no advantages and made the noise. Maybe I'm just shallow.
Old Jul 5, 2011 | 08:01 PM
akng's Avatar
akng
Which of the two springs were you using?
Old Jul 5, 2011 | 10:42 PM
turtle343's Avatar
turtle343
the kind of noise a real BOV would make?
Old Jul 5, 2011 | 11:25 PM
fishbert's Avatar
fishbert
What's wrong with the guy having a little personal preference?
Old Jul 6, 2011 | 06:02 AM
///Mflossin
No problem with his personal preference....just wish he would have elaborated at the get-go.
