Drivetrain Forge BOV
Old Jul 6, 2011 | 05:09 PM
  #26
Melangell's Avatar
Melangell
I am thinking that I had the softer spring. Way asked me to try the stiffer one but after talking to others just to go back to OEM. Again, I LOVED this thing on The Dragon, but just out and about I got no advantage and the nah nah nah noise. For the record, now I am running the OEM BoV with Alta spring, DoS intake, and Forge FMIC, NM downpipe, and am loving it.
Old Jul 6, 2011 | 09:46 PM
  #27
turtle343's Avatar
turtle343
Originally Posted by fishbert
What's wrong with the guy having a little personal preference?
I am asking a serious question. As I said before I want to get one so I want to know what was wrong with it. When I hear it makes a flutter sound I want to know if it sounds like something I have heard before, like a real BOV or something else, so I can get a good idea what to expect.
I hope that makes it a bit easier for you to understand.
Old Jul 6, 2011 | 10:04 PM
  #28
silhouette88's Avatar
silhouette88
https://www.northamericanmotoring.co...650-post5.html
Last edited by silhouette88; Jul 6, 2011 at 10:05 PM. Reason: quoting original post
Old Jul 7, 2011 | 05:21 AM
  #29
///Mflossin's Avatar
///Mflossin
Originally Posted by Melangell
...NM downpipe...
I didn't know NM made a downpipe. Any pictures?
Old Jul 9, 2011 | 08:48 AM
  #30
Melangell's Avatar
Melangell
Sorry, I meant discharge pipe... One too many sips of bourbon.
Old Jul 14, 2011 | 10:32 PM
  #31
MINI39's Avatar
MINI39
I just ordered the Forge BOV Kit from WMW (Way Motor Works) and I cannot wait to install it. I also ordered the heat shield, no melting hood scoop for me please....I also have to mention the great customer service from WMW they were great!!!!! Its nice to see; In todays world we can all get caught up in the negative BS that is out their.....
Old Jul 15, 2011 | 02:51 AM
  #32
Spollie's Avatar
Spollie
FYI:
Since MY 2010 the hoodscoops don't melt anymore. So you don't really need a heat shield. My tuned 2010 Cooper S has 30.000 miles on it and I haven't had any heat problems at all.
Old Oct 13, 2011 | 04:00 PM
  #33
Performance Angst's Avatar
Performance Angst
Originally Posted by WayMotorWorks
Here are the correct specs for the springs:
Green - 5-15 PSI
Yellow - 15-23 PSI
Blue - 23-30 PSI
Red - 30 + PSI
If you want the blue or red springs we will get them for you, but 99% of people aren't going to need them.
Also we do ship to AUS, just we have to get wire transfers for payment.
Will the Forge BOV work on a 2009 Factory JCW clubman?
Old Oct 14, 2011 | 02:50 AM
  #34
czar's Avatar
czar
Simple answer = Yes
Old Oct 14, 2011 | 03:04 AM
  #35
fishbert's Avatar
fishbert
Simple answer = Yes
More complicated answer = Indubitably
Old Oct 14, 2011 | 05:41 AM
  #36
Performance Angst
Thanks.
I think I'm going to try the upgraded spring option first before dropping another ~$200 on a BOV that might not solve my problem of high pressure bleed off over 20 psi. The spring upgrade claims to hold 40 psi w/o leaking so that looks like a better option right now for me as I've already got the a Helix BOV on it.
Old Oct 25, 2011 | 02:01 PM
  #37
ThePenl's Avatar
ThePenl
Correct spring installed
Although I have used the blue spring with my Forge valve without any problems for 7000 miles now, today I decided to install the yellow one to test it. It seemed that with the blue spring the valve was very quite and if I pushed really hard a stalling noise would be heard (like when the turbine axle is forced to decelerate unexpectedly).
From this change I firstly noticed that the blowing sound has come back. I will make further observations and report back.
Old Oct 25, 2011 | 02:09 PM
  #38
Bigprfed22's Avatar
Bigprfed22
The spring doesnt hold the valve closed, it is an electronic solenoid. The spring assists in the "closing/sealing" action of the valve
Thanks.
Old Oct 25, 2011 | 06:15 PM
  #39
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes the Forge kit will be perfect for that.
Old Jan 22, 2012 | 07:53 PM
  #40
turtle343's Avatar
turtle343
i just got mine today from out motoring. it only came with 1 spring and it looks like just steel colour but has patches of yellow on it. im assuming this is the yellow one then?
Old Jan 22, 2012 | 08:07 PM
  #41
turtle343's Avatar
turtle343
ok i found out how to pull it apart and it has a green one in it so i will chuck the yellow in.
GAT
Oct 4, 2015 07:27 PM
Tires, Wheels & Brakes
Oct 1, 2015 10:38 AM
Oct 1, 2015 10:17 AM
micromini234
Sep 30, 2015 07:36 PM
TifosinDel
Sep 28, 2015 10:45 AM
