Drivetrain 2012 R60 Countryman S Turbo N18B16 dyno & tune
Old Sep 19, 2011 | 07:31 PM
m54b25's Avatar
m54b25
Just dynoed a stock 2012 R60 Countryman S Turbo N18B16 dyno with a PAW tune. Similar engine to the R56.2 Turbo S.
+28.00 rwhp / +50.92 Ftlb gain at the wheels on a Dynojet @ 90 degree weather!
https://www.northamericanmotoring.co...une-n18b16.pdf
Old Sep 19, 2011 | 07:42 PM
SooperCuperErik's Avatar
SooperCuperErik
N18 got hacked?? or is this in EU?
Old Sep 19, 2011 | 07:44 PM
roushraven's Avatar
roushraven
Very nice; I didn't realize tuning software was available yet for the new cars.
Old Sep 19, 2011 | 08:26 PM
m54b25's Avatar
m54b25
Yes, this is the Mini +2011 USA turbo Valvetronic N18 engine w/dual vanos =)
Old Sep 19, 2011 | 08:28 PM
roushraven's Avatar
roushraven
Impressive; I must give these guys a call.
Old Sep 19, 2011 | 08:29 PM
old81's Avatar
old81
M6
Interesting, a little more detail would be appreciated.
Tuning software, any subtle modifications to your R60 S? Tuner who applied the tune?
Very nice gains show on the dyno graph, what was the AF rations and any other interesting items, max rpm, did you raise the rev. limits, etc?
Drive-ability after the tune?
Are you a 6 speed or an automatic?
Thank you,
Don
Old Sep 19, 2011 | 08:37 PM
coopers111's Avatar
coopers111
Old Sep 19, 2011 | 08:39 PM
m54b25's Avatar
m54b25
Thank you,
Don
It's a stock R60 S 2wd MT & will also work on the steptronic auto. Just re-calibration done. AFR it's safe high 11's to 1 area, driveability it's noticiable gain, & no raise rev. limit since DME built in data recorder can be used to void warranty =)
Old Sep 19, 2011 | 08:49 PM
ThumperMCS's Avatar
ThumperMCS
Not many people know that the N18 motor has been able to be tuned for a while....but the ECU must be removed.
If this tune was done by OBD flash....then you have something new. Regardless...even with the addition of the dual vanos, gains don't seem much different than the N14. The torque would be fun with an AWD CM though....
Old Sep 19, 2011 | 09:56 PM
old81's Avatar
old81
M6
Thank you for the information. Yes, more torque with the ALL4 and auto would be very nice.
Still a respectable increase.
To the OP, can you ballpark the cost if your comfortable posting it or a PM would be fine to me.
Thanks again,
Don
Old Sep 20, 2011 | 05:28 AM
etalj's Avatar
etalj
12:1 AFR is quite conservative isn't it?
Old Sep 29, 2011 | 03:29 PM
Theta's Avatar
Theta
Have to ask...
1) Is tuning an option for ALL4s now?
2) Is something like this available as a canned tune, or simple ECU swap? Or does it need a dyno tune? Would be a lot harder here, as there aren't too many AWD dynos out here.
Old Oct 1, 2011 | 01:18 PM
m54b25's Avatar
m54b25
Originally Posted by theta
Have to ask...
Yes, it will work for ALL4s, FWD, manual or steptronic. You can decide to do dyno or not, but it's very noticiable the power gain specially in Sport mode. Also, ECU can be send by courier to re-calibrate I believe.
Old Oct 4, 2011 | 12:05 AM
Theta's Avatar
Theta
So, if I'm understanding a few of you correctly (and the post above)... tuning is possible, but I would need to physically remove my ECU and send it to a tuner. Then, I would need to wait for it to be sent back.
Is that where we're at right now? If so, which tuner will do this quickly, and how much does this cost?
Can any tuner do this at a dyno, or does it require special tuning software? Sorry, I'm more familiar with EFI Live, HP Tuners, LS1Edit, etc...
Old Oct 4, 2011 | 02:38 PM
Theta's Avatar
Theta
Well, good news for me (perhaps). I found a BMW tuner here with an AWD dyno setup.
I contacted them today, and they said they're more than willing/able to tune my Countryman, but they need to have some way to communicate with the DME/ECU.
What tuning software is required to edit these N18 engines?
Old Oct 4, 2011 | 02:58 PM
ThumperMCS's Avatar
ThumperMCS
I would not have someone that has not tuned one before do the tuning....
Dimsport software can be used to tune the N18, but like it's been stated...the ECU must be removed. Not sure what PAW is using, but I'd assume Dimsport.
Old Oct 4, 2011 | 09:47 PM
Theta's Avatar
Theta
Are there any resources I should be reading on this? Or is it sort of an industry insider subject? I hate to keep posting with dumb questions.
I don't want to appear ignorant, just scouting my options. I know a ton of you have tuned R56s, and I wanted in on the action with my R60.
I'll ask the tuner about Dimsport. They've tuned R56s, but never an R60 (not a surprise) - not sure if the software is the same since they're both N18s.
Last note - when you all say "remove the ECU", I'm assuming removing and programming the ECU. Am I misunderstanding?
Old Oct 11, 2011 | 02:09 PM
ENGINE 58's Avatar
ENGINE 58
luis at paw is a good guy . he has done some good work on my 09 jcw.
Old Oct 11, 2011 | 06:37 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We have Dimsport software and As of today the only way to tune any MINI with an N18 engine is remove the ECU and crack it open. Then use the Dimsport software to tune it.
If your looking to get a tune, I don't recommend being someone's test mule. Funny story is we had a local guy want a tune, but didn't like our price being a $100 more than his buddy at a BMW shop. So he went there, but icing on the cake was when he called me 4 months later with a blown engine. Good thing he saved that $100, he needs it now.
Old Oct 13, 2011 | 01:22 PM
smokeysevin's Avatar
smokeysevin
Is there any kind of piggyback available for the n18? I only have 6000 miles on my 2011 but I would be interested in a tune if it would leave no trace.
Sean
Old Oct 21, 2011 | 12:52 PM
tintman718's Avatar
tintman718
That's a nice "story". Please don't prey on less knowledgeable people. I'm sure you've had your own share of blown up engines. That BMW owner could have likely demanded the tuner increase certain parameters to unsafe levels. There's no need for you to promote yourself in a technical thread.
Old Oct 21, 2011 | 01:15 PM
Theta's Avatar
Theta
I get the feeling that he wasn't so much self-advertising as showing that you get what you pay for.
I'd love to get a tune around here, but most of the tuners say "well, I've never done one of those before!".
If Way has tuned these (2011s) successfully and has a working knowledge of them, more power to him. There are other tuners in other states that have done the same (PAW), and I would honestly only trust those that have done this regularly.
I certainly don't want to be a 'test mule'...
penguinhomey
38
Jul 7, 2019 09:24 PM
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
FrostyFox
Oct 28, 2015 02:06 PM
MES11
Aug 8, 2015 10:21 AM
