Drivetrain best $150 or less engine mod?
Old Aug 3, 2011 | 01:34 PM
bksmith76's Avatar
bksmith76
looking for options - i was thinking of:
hot side boost tube (added benefit of more turbo sound )
oil catch can
motor mount / torque arm
others that i haven't thought of?
any input would be appreciated.
b.
Old Aug 3, 2011 | 01:54 PM
automan21's Avatar
automan21
OCC and torque arm bushing.
Old Aug 3, 2011 | 02:25 PM
bluefox280's Avatar
bluefox280
I second this; prolong engine life (OCC) and better shifting feel (arm insert).
- Erik
Old Aug 3, 2011 | 08:24 PM
ThumperMCS's Avatar
ThumperMCS
Save the $150 and put it towards something better
Old Aug 3, 2011 | 08:25 PM
etalj's Avatar
etalj
Originally Posted by bluefox280
i second this; prolong engine life (occ) and better shifting feel (arm insert).
- erik
+1
Old Aug 3, 2011 | 08:35 PM
2009R56JCW's Avatar
2009R56JCW
spend 400 and get
1. aem water/meth injection and enjoy zero carbon build up zero superknock with the benefit of cooler intake charge and advanced timining and always have overboost available regardless of temp .
2.hotside muffler delete.
3. if you have more than 15k miles new plugs
keep stock intake
keep stock airfilter
keep stock exhuast just remove 2nd cat
keep stock intercooler
keep stock hot and cold hoses
keep noisemaker
Old Aug 3, 2011 | 09:45 PM
Porthos's Avatar
Porthos
1st there are 2 cats. Just thought I would throw that out there. OCC is a could one. So is the insert. But is that all you have to spend or all that you want to spend?
Old Aug 4, 2011 | 05:13 AM
bksmith76's Avatar
bksmith76
it's all I'm looking to spend at the moment. maybe this fall I'll go nuts and do something more major like exhaust system...
Old Aug 4, 2011 | 11:14 AM
countryboyshane's Avatar
countryboyshane
Easy choice. Torque arm inserts from NM-Engineering. It does make a big difference in driveability, especially under high loads.
Old Aug 4, 2011 | 12:24 PM
zKryT's Avatar
zKryT
signed . Just did this last weekend. Did it myself, took an hour or so (hardest part was finding the best way to put the MCS on jack stands) and is by far one of the best mods I've done, especially for the price.
Old Aug 4, 2011 | 06:29 PM
Underoath's Avatar
Underoath
Delete 2nd cat and do 3inch straight pipe from there back for more Hp/ tq and make turbo spool little faster, slightly better mpg too.
Old Aug 4, 2011 | 07:10 PM
2009R56JCW's Avatar
2009R56JCW
Underoath why did you car only run a 14.9@93
High altitude?
at sealevel I have run 13:20s @ 103/105 using the stock runflats
Old Aug 4, 2011 | 07:27 PM
Underoath's Avatar
Underoath
High altitude?
You have a jcw, I have a mcs with barely any mods, what are your mods?
Old Aug 4, 2011 | 07:38 PM
2009R56JCW's Avatar
2009R56JCW
water/meth injection , removed intercooler and a canned tune.Car was runing 12;80s-12.90s on RFs with a catless downpipe a custom rmw tune and about 100 pounds of weight less.(before audio upgrade and with rearseat delete and lite weight braille battery)
Old Aug 4, 2011 | 07:44 PM
Underoath's Avatar
Underoath
Well that explains 10 mph trap with a heavier modded jcw vs a stockfish mcs lol. I hope to trap 100 with just an alta tune when ever I have the $$
Old Aug 4, 2011 | 07:45 PM
MiniBOL's Avatar
MiniBOL
Hows that water/meth injection on the R56? Was it expensive to do?
Old Aug 4, 2011 | 08:13 PM
2009R56JCW's Avatar
2009R56JCW
Install and setup is a breeze and picked up the kit for $300. uses about a gallon of meth for every tank of fuel.
Old Aug 4, 2011 | 08:21 PM
2009R56JCW's Avatar
2009R56JCW
You are only off 3 tenths of the stock automatic cooper s that was at the track.
there are a few things that are cheap and will help you meet your goal of 100 mph.
tires are huge ,car runs 13.ohs and pickes up a couple of mph on non runflat 215/45s.
intercooler is kinda restrictive I would replace with a finned copper or aluminum tube .
add meth with a 200 hp jet
ice the car down
Old Aug 4, 2011 | 08:56 PM
Underoath's Avatar
Underoath
ice the car down
Well my mods don't do much... And the manual actually runs a tenth slower time then the auto if I remember correctly, I have a manual, need to work on launch and im already looking into different tires when my run flats are gone. I wouldn't do meth on my daily driven work car plus my gf drives it so I don't want her monitoring anymore fluid lvls then she has to.
Old Aug 4, 2011 | 09:00 PM
2009R56JCW's Avatar
2009R56JCW
Just use the windsheild washer bottle and keep a extra gallon in the hatch.
meth helps keep everything carbon free! Plus added protection once you get a tune.
Old Aug 5, 2011 | 12:00 AM
Underoath's Avatar
Underoath
Well I might be interested in doing that if I was trying to go all ou with this car but I just want to do basic stuff, make it more efficient, reliable and fun to drive. I have an 02 mustang gt with a built short block, ported heads cams intake, full bolt ons and some n20, for more fun
madmax88
Aug 21, 2017 07:07 PM
bjcarter2
Aug 31, 2015 04:03 PM
makg
Aug 21, 2015 02:49 AM
minipopkart
Aug 13, 2015 05:22 AM
