Drivetrain catless dp without tune!!
hey D Robinson messaged me this i was wondering if anyone has tried it or if yall think it will work.
http://bigdaddiesgarage.com/mini-cat-cel-fix.html
I'm "FlattOut" on motoring|underground, and yes this works. I do get a CEL every once in a while, but it will go away. I also have a code reset tool, which helps when I need the CEL to be fixed immediately I suggest running a spark plug non-fouler between the O2 sim and the dp.
Even if there was no code, any such device will not fix the real problem of power loss in the lower and mid range RPM. Having the light on is a minor side effect, but losing power from a part that is meant to add power is a real issue. It's the same when it's tuned. Turning the light off is an added benefit, but the real point to tuning is to make the DP functional with the car.
No point in going catless if you aren't getting tuned for it... but maybe I'm just cranky and "uptight" lol...
09-04-2015 02:12 PM
09-02-2015 12:57 PM
08-12-2015 01:24 PM
