Drivetrain Increased turbo lag
Old Jul 18, 2011 | 07:30 AM
Mini2na's Avatar
Mini2na
Increased turbo lag
The weather was warm, not hot while I made multiple auto cross runs in a row. I noticed increasing turbo lag as I when on. After lunch it was better.
Did I experience MINI's small intercooler? Or does my MINI need to go into the dealer for something before the warranty runs out?
If it is the IC, will spraying it down between runs help?
Old Jul 18, 2011 | 07:50 AM
ThumperMCS's Avatar
ThumperMCS
That's not turbo lag....thats just you feeling powerloss from the IC getting heatsoaked.
Spraying the IC will help for a few seconds, but you really need an FMIC
Old Jul 18, 2011 | 01:32 PM
HRM's Avatar
HRM
Alternately, or in addition, a methanol injection system will cool things down pretty fast too.
In the mean time, of if you don't want to go that far, you can as suggested above get a spray bottle and put in washer fluid (winter formula is 50/50 meth) and spray the outside of the intercooler before your run. The evaporation will do wonders for the heat as it evaporates. Just soak it before the run and it should help. I am not sure about how much is too much (as in it clogs the fins for a while) but I have to figure it should evaporate pretty fast and take lots of heat with it.
rob&JCW
Feb 21, 2018 02:41 PM
MAGICIAN
Oct 13, 2015 09:29 PM
twriter
Oct 2, 2015 03:14 PM
HaveATank
Sep 16, 2015 08:32 AM
Sep 2, 2015 11:15 AM
