Drivetrain size resonator
Old Sep 25, 2011 | 06:31 PM
drno's Avatar
drno
size resonator
what size resonator ( inlet / outlet ) it put in 56s to replace removed resonator. i planning a custom exhaust using modification of stock stage 1 system.
Old Sep 25, 2011 | 08:36 PM
SooperCuperErik's Avatar
SooperCuperErik
Please use the search function. This topic has been discussed so many times.[/COLOR]
Old Sep 25, 2011 | 08:48 PM
ThumperMCS's Avatar
ThumperMCS
this site has a search function?
I would have never known based on the questions asked daily here!!
I kid....I kid....
Old Sep 26, 2011 | 05:42 AM
drno's Avatar
drno
tried exhaust pipe size and stock exhaust pipe diameter - - came back no results. thanks for the help !
Old Sep 26, 2011 | 08:46 AM
SooperCuperErik
the forum searches aren't the best.
on google.com use
"site:www.northamericanmotoring.com exhaust diameter"
its something around 2.1-2.2
easiest way is to take a string, wrap it around the pipe diameter, then do circumference = 2*diameter
Regardless, its not a standard size of 2" or 2.25", so you'll need a sleeve if you're welding an aftermarket resonator to a stock exhaust
Old Apr 10, 2018 | 11:25 AM
austin5's Avatar
austin5
The other issue is when I search and find 3 threads with answers like this until I find the right answer
Old Apr 22, 2018 | 10:42 AM
4mikebruns's Avatar
4mikebruns
NAM Community Team
2.25 is the closest common size that will weld up without being a PITA. That's what I used for my mid section.
Old Apr 23, 2018 | 10:09 AM
KCLARK's Avatar
KCLARK
I did this with my custom exhaust and got a 3 inch, but got the longest resonator I could find to cut down on drone. I ended up using a magnaflow version because it was (14 inch) but noticed many on NAM use vibrant which was significantly shorter.
Old Apr 23, 2018 | 10:25 AM
cyow5's Avatar
cyow5
on google.com use
circumference is pi*diameter, so 3.14 instead of 2.
Old Apr 23, 2018 | 05:39 PM
bcriverjunky's Avatar
bcriverjunky
Stock pipe is 55mm. 55mm = 2.16535"
knbond1
Sep 4, 2016 02:30 PM
vulkandino
Oct 31, 2015 08:29 PM
Doc Pain
Oct 28, 2015 07:09 PM
OldElvis
Tires, Wheels, & Brakes
Oct 1, 2015 06:21 AM
WhinyR53
Sep 30, 2015 07:36 AM
