Drivetrain So I blew a piston on my JCW and the fun begins
So I blew a piston on my 09 JCW a couple weeks ago. We spent the afternoon doing this...
http://gallery.me.com/mrrjm/100368
Alta "Stage 3" tune, capable of a 13.8 on the quarter mile.
References:
https://www.northamericanmotoring.co...827-post9.html
https://www.northamericanmotoring.co...9-post289.html
https://www.northamericanmotoring.co...5-post104.html
Cheers,
Charlie
Sport button doesn't have anything to do with boost, or increased performance. It does make the throttle opening more linear, and it does make the power steering heavier.
Man that sucks.
Interesting to see the fail point here is the same as most of the MCS pistons. The lower C/R alows higher boost, but at peak it fails in the same spot since they both share the same design flaw.
Apparently the answer is yes.
References:
Cheers,
Charlie
References:
Cheers,
Charlie
It always sucks to read all of this, especially since there have been several of these threads recently. Good luck putting it all back together.
I have a feeling I won't be keeping this car past warranty!
This is no surprise unless you count the surprise that it lasted as long as it did.
28lbs of boost?
The spike just before this happened was probably 28.4. Pretty much what happens is I see peak boost at 3000 rpm and it drops to 22-23 at redline. The tune I was running is awesome. Tons of low end torque. I was gonna lower the boost before this happened but too late now. I probably ran this way for 9k miles before this happened.
Does anyone even make upgraded pistons for the R56 yet?
http://eshop.kanteres.gr/en/virtuema...=28&TreeId=112
here we go... got another web site thats sells these stuff but that link is in my desktop...
Only reason I went with another stock motor is because the price was right.....aka free ;-)
Agreed, and exactly what I'm hoping to avoid. I've already spent a ton of cash on my car and I'm in the high risk group for a blown piston, basically I've modded myself into a corner.
I'm guessing it's a good investment at this point if upgraded pistons do indeed exist somewhere for the R56.
I better get used to eating ramen for a while...
It doesn't matter what aftermarket pistons you purchase and replace, for your OEM factory stock pistons, uncontrolled thermal stress detonation will kill your aftermarket pistons too!
The only way is to find out just what in each individual case, causes the detonation problem in the first place, I don't have a problem with my pistons and I'm using Mahle, albeit with more static compression ratio!
Is it different in each case or do you think it's mainly the result of the R56 carbon buildup problem combined with higher boost/temps from a tuned engine as well the quality/octane level of the gas?
I plan to add a water/meth injection system to reduce the chances of it happening.
i wanna hear this~
