Drivetrain Spark plug socket?
Old Oct 3, 2011 | 06:55 PM
richardsperry's Avatar
richardsperry
Spark plug socket?
How necessary is the $31 socket for the spark plugs? (MCS)
Old Oct 3, 2011 | 07:18 PM
JAB 67's Avatar
JAB 67
I don't know which particular socket you are considering, but as someone who has changed their own plugs (R53) I can tell you that the ideal tool is one-piece from handle to socket; if you use a conventional spark plug socket on an extension, you may find (as I did until I jury-rigged something) that after you torque the plug and then go to withdraw the socket & extension, the socket stays on the plug, and does not come out with the extension.
Old Oct 3, 2011 | 07:30 PM
blkkouki's Avatar
blkkouki
I believe a 12 point deep socket will work
Old Oct 4, 2011 | 06:42 AM
SooperCuperErik's Avatar
SooperCuperErik
14mm 12pt deep socket will take care of it. 14mm 6pt will NOT! ask me how i know.
Old Oct 4, 2011 | 06:56 AM
quality_sound's Avatar
quality_sound
I like true spark plug sockets because they hold the spark plug. A couple of tricks to getting the socket out after installing the new plugs. 1) Just barely insert the plug 2) When pulling the socket out, apply sideways pressure to the socket and pull SLOWLY, like getting your shoe out of the mud.
Old Oct 4, 2011 | 07:49 AM
ACEkraut11's Avatar
ACEkraut11
Originally Posted by JAB 67
....you may find (as I did until I jury-rigged something) that after you torque the plug and then go to withdraw the socket & extension, the socket stays on the plug, and does not come out with the extension.
Just use duct tape to hold it together then take it off when you are done.
Old Oct 4, 2011 | 08:14 AM
killerfox's Avatar
killerfox
yep, 14mm 12pt deep socket and put the rubber piece from a sparkplug socket inside and you will be fine, pick up one at lowe's for $10.
Old Oct 4, 2011 | 09:02 AM
bus1's Avatar
bus1
Yep, regular spark plug socket on a six inch extension with 1-wrapped layer of duct tape holding the two together did the trick - no problem!!
Old Oct 4, 2011 | 01:06 PM
quality_sound
That's so simple I feel like a bone head for not thinking of it before. lol
Old Oct 4, 2011 | 01:52 PM
norm03s's Avatar
norm03s
That's right! I have a dedicated socket and 6 inch extension duck taped to it just for MINI plugs.
Old Oct 4, 2011 | 02:15 PM
Maugre's Avatar
Maugre
Sears sells a 14mm 12 point deep socket for about 5 bucks.
Not specifically for plugs but it works. Good luck.
Old Oct 4, 2011 | 06:28 PM
richardsperry
But, but, but! It's a cool special Mini tool ...
Old Oct 4, 2011 | 06:34 PM
ACEkraut11's Avatar
ACEkraut11
Write MINI SPECIAL TOOL on the duct tape and you can pocket the extra money and still feel special and cool.
Old Oct 5, 2011 | 06:51 AM
Maugre's Avatar
Maugre
Now this is an idea with merit .
Old Oct 14, 2011 | 04:33 PM
e30r56's Avatar
e30r56
The tool also works on the new turbo bimmer engines too. (n54/n55)
eliseo1981
May 10, 2016 05:19 AM
JMF1975
Sep 11, 2015 03:29 PM
rob76turbo
GP Talk (2006)
Sep 7, 2015 12:28 PM
Sep 4, 2015 03:56 PM
Sep 2, 2015 09:05 AM
