Drivetrain Turbo Solenoid Bypass Adapter?
Old Jul 19, 2011 | 06:58 PM
Jaredclynn's Avatar
Jaredclynn
http://www.mossmini.com/Shop/ViewPro...eIndexID=86305
What exactly is this and what does it do? The description was a little vague. I know it's not a BOV but it talks about the sounds turbo cars make. I'm not very familiar with these kind of things.
Old Jul 19, 2011 | 07:14 PM
Mike@Tech Division's Avatar
Mike@Tech Division
Normally the stock diverter valve (bov) vents to the intake side of the turbo. The addapter you linked blocks the normal passage into the inlet side of the turbo and forces the DV to vent through holes in the side. It basically makes the stock DV a vent to atmosphere. It's for noise only.
Old Jul 20, 2011 | 10:46 AM
countryboyshane's Avatar
countryboyshane
You'll also enjoy the check engine light's you'll get for the $80 price
Old Jul 20, 2011 | 07:41 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Both statements above are true. Save your money and get a real valve.
Old Jul 21, 2011 | 04:57 PM
Jaredclynn's Avatar
Jaredclynn
Alright, thanks guys. I don't understand why companies try and sell stuff like that....
Anyway, I'm not sure i'd want a BOV because I heard they can cause a lot of problems. They sure sound cool though...
Old Jul 21, 2011 | 09:30 PM
Mike@Tech Division
The same effect can be made basically with an open air intake. You will hear the DV venting and hear the turbo spool a little.
Old Jul 22, 2011 | 11:25 AM
tintman718's Avatar
tintman718
Also, don't forget you will effectively run richer during each period the valve is open. This is because you are releasing metered air without the ECU being aware. I can only imagine this causing a CEL due to Lambda fluctuating excessively.
Old Jul 27, 2011 | 04:19 AM
Raymazing's Avatar
Raymazing
Oddly enough I've recently taken my Greddy BOV recirc tube off to see how the car acted. No code. Even after days of driving and I didnt see any super-rich conditions on my AFR. I put it back on but no tantrums from the car. I do run a resistor to trick comp into thinking stock DV is present.
Filmy
15
Jun 6, 2023 06:27 AM
jdinh504
Dec 18, 2016 11:08 AM
KinetechMW
Jan 22, 2016 09:04 AM
mikes603
Sep 11, 2015 11:00 AM
Ntety
Sep 2, 2015 08:39 PM
