Drivetrain Craven Speed short shifter and NM shift box
Old May 11, 2011 | 02:35 PM
Ladyvalea's Avatar
Ladyvalea
Just received this Craven Speed short shifter and NM Shifter Assembly box Cover! for my 09MCS Other then the Craven speed directions! does anyone know of a step-by-step instructions with pictures? and how hard is this going to be to install at home?? thanks Ladyvalea
Oh, where do the 4 black bolts and screws go??
Old May 11, 2011 | 03:01 PM
automan21's Avatar
automan21
Check the cravenspeed site, waymotorworks site or even alta to see if they have a how to pdf or something. I know ive seen it somewhere on one of those.
Old May 11, 2011 | 03:10 PM
Ladyvalea's Avatar
Ladyvalea
dang..how much is it going to cost ...if I pay a professional to do it??
Old May 11, 2011 | 03:17 PM
cop1406's Avatar
cop1406
I am having it done at AMVIV next week and Way motorworks is charging me around $200.00.
Larry
Old May 11, 2011 | 03:23 PM
cop1406's Avatar
cop1406
Check out this thread. This if for the first gen MINI but it is similiar to the 2nd gen. I decided that 200.00 isnt too bad for the install. Not for the faint of heart....
https://www.northamericanmotoring.co...xperience.html
Old May 11, 2011 | 03:50 PM
sooper_cooper's Avatar
sooper_cooper
Looks like a great setup. Report back on how it performs when you get it installed.
From what I've read it's an easy install, although you do have to drop the exhaust. If you can put your car up on jack stands it should be do-able as a garage project.
Old May 11, 2011 | 03:57 PM
drewstermalloy's Avatar
drewstermalloy
It's not that hard. It just takes some time, especially the first time you do it.
Old May 12, 2011 | 01:40 PM
minimike21's Avatar
minimike21
not to side track but is the nm shift box cover necessary? you cant fit the regular cover back on or is it just if its down all the way?
Old May 12, 2011 | 01:50 PM
cop1406's Avatar
cop1406
I believe you can put the stock one back on but you can't lower the short shift all the way which kinda defeats the purpose. You can leave it off as the exhaust shield blocks most everything but that was not acceptable to me so I purchased the cover from NM.
Old May 12, 2011 | 02:15 PM
Ladyvalea's Avatar
Ladyvalea
http://www.waymotorworks.com/nm-shif...box-cover.html
I just want my parts covered ...even if the exhaust shield blocks it ..it was still covered originally and now this allows for the extended ball to be covered.
Old May 12, 2011 | 02:17 PM
minimike21's Avatar
minimike21
Good info! Thanks guys
W0TM8
Dec 19, 2019 07:50 AM
blackie
Jan 18, 2017 09:56 PM
theblackfalcon
Oct 11, 2015 09:49 AM
David.R53
Sep 1, 2015 06:49 PM
