View Full Version : R60/61 Cooper S Drivetrain
- Drivetrain R60 MOD ADVICE. New to MINI.
- Drivetrain R53 Torque Arm on R60?
- Drivetrain Clutch and flywheel replacement starting issue
- Drivetrain R60 all4 limitations
- How To Intake Valve Cleaning / Top Dead Center
- Drivetrain Resistor and car delete on R60
- Drivetrain Advice on Upgrades
- Drivetrain Os giken str clutch/flywheel
- Drivetrain R60 Mod Tier List
- Drivetrain Considering swapping R60 engine for hybrid engine
- How To Trying to find the best air intake and exhaust system
- Drivetrain Clutch longevity after tune
- Drivetrain Problem putting ecu back to stock
- Drivetrain R61 Mod Advice
- Drivetrain New turbo questions
- Drivetrain Wagner Intercooler Fit on 2015 R60 JCW
- Drivetrain Benefit to Upgrading piping
- Drivetrain Getting the power to the ground
- Drivetrain Turbo Issues
- Drivetrain 300hp Mini Countryman S R60 Manic Stage 3 Turbo Upgrade - Daily Driven
- Drivetrain Rod Bolt Install
- Drivetrain RPM Stage 3 Tune - R60 S All 4 Automatic
- Drivetrain Weird sound after Dp install
- Drivetrain Jcw intercooler
- Drivetrain 2C01 HPFP question
- Drivetrain Best Oil Catch Can?
- Drivetrain R60ALL4 Lower Torque/Engine Mount Re-Install Suggestions?
- Drivetrain VIP Custom Exhaust Question
- Drivetrain Rear Differential Mounting Bushing Replacement
- Drivetrain DP Good install Tips?
- Drivetrain Cheaper Safe Mods?
- Drivetrain New turbo issue
- Drivetrain Drive train specs
- Drivetrain The NM module
- Drivetrain Coolant Hoses - Are they shared with the rest of the family?
- Drivetrain Remus exhaust for sale $300
- Drivetrain Mk. 43-LT Custom Turbo: FAST SPOOL, HIGH TORQUE, SOLID TOP END
- Drivetrain small oil leak after factory recall fix
- Drivetrain Aftermarket clutch assembly for R60 ALL4
- Drivetrain R60 Problems
- Drivetrain N18A16C R60 JCW boost gauge question
- Drivetrain What Mods do my fellow R60 Countryman S have/suggest
- Drivetrain Manic stage 2 JCW intercooler option
- Drivetrain Recent Mods
- Drivetrain K&N Typhoon wont fit...
- Drivetrain Countryman Exhaust
- Drivetrain NM Power Module Issue
- Drivetrain V band clamp, go stock or after market?
- Drivetrain Anyone running the Turbosmart 50/50 on the N18??
- Drivetrain Chewbacca
- Drivetrain Selling FORGE Bypass Valve Kit (Used)
- Drivetrain Dinantronics Sport install for R60
- Drivetrain Downpipe removal
- Drivetrain Emissions and warranty friendly?
- Drivetrain Catless or HF Downpipe in PA
- Drivetrain Slightly more aggressive sound
- Drivetrain JB+ vs NM plug in tuners
- Drivetrain Alternatives to JB+?
- Drivetrain Age old question....
- Drivetrain Exhaust too close to heat shield, can I take it off?
- Drivetrain Tune + Power Module?
- Drivetrain ECU Tune and Intercooler
- Drivetrain Exhaust Question 2wd
- Drivetrain Coilovers, what brand?
- Drivetrain P0141 with catless downpipe + secondary O2 spacer...
- Drivetrain I've started modifications, what do I do next?
- Drivetrain AFE scorcher power module
- Drivetrain what spark plugs to use??
- Drivetrain Manic stage 1 vs stage 2/downpipe- any negatives?
- Drivetrain Tuning options and roof rack for the 2017 Countryman
- Drivetrain Just bought a 2012 Countryman S All4- is there a list of good mods/upgrades?
- Drivetrain Diverter Valve Spacer
- Drivetrain 2013 Countryman S with M7 Stage 2 CAI
- Drivetrain 50mm K04 turbo has arrived!
- Drivetrain Mario Kart Catless Downpipe with no tune
- Drivetrain Can someone summarize the tune options for me?
- Drivetrain Better of two downpipes?
- Drivetrain R60 Exhaust Performance Comparison
- Drivetrain Aftermarket Oil Cooler for R60S?
- Drivetrain Pops and burbles?
- Drivetrain Max Boost with JB??
- Drivetrain Oh LOOK! Another exhaust thread
- Drivetrain Mass Airflow
- Drivetrain New R60 owner! -Intercooler question-
- Drivetrain VIP full exhaust with CNT cat-less downpipe
- Drivetrain All4 R-Diff Bushing Insert Install
- Drivetrain Magnum FORCE Pro DRY S Stage-2 Intake System;CountrymanS(R60) thought&recommendations
- Drivetrain JB+ or Manic stage 2 tune??
- Drivetrain Exhaust wrapping downpipe
- Drivetrain Priming turbo after swap
- Drivetrain Borla Exhaust for Top Performance
- Drivetrain R53 won't idle no codes
- Drivetrain Way has New Powerflex Bushings for R60 R61
- Drivetrain Forge Diverter Tuning Springs?
- Drivetrain Scorpion Exhaust VS Remus Exhaust for Countryman?
- Drivetrain Countryman turbo swap yes or no?
- Drivetrain Looking for input on Exhaust Upgrade
- Drivetrain ko4 Swap?
- Drivetrain NM Power Module Review - The Good and The Bad
- Drivetrain 2013 Countryman S, First Modifications
- Drivetrain Trying to get a bit more top end for highway (K&N Filter and JB+?)
- Drivetrain looking for a jb+ to buy at Florida
- Drivetrain Downpipe and Intercooler
- Drivetrain Oil air filters OK?
- Drivetrain Forge DV Adapter Install Questions
- Drivetrain NM Engineering Exhaust
- Drivetrain Anyone with a home built IC pipe set?
- Drivetrain Stella gets H&R Sport Springs
- Drivetrain Down pipe ideas?
- Drivetrain Mishimoto OCC - Countryman S All4
- Drivetrain Countryman R60 - True CAI (custom)
- Drivetrain Methanol directly into tank?
- Drivetrain Alta turbo blanket install question
- Drivetrain waste gate adjustment difficulty?
- Drivetrain OEM Midpipe
- Drivetrain Just about ready to install mods!
- Drivetrain Alta vs Oxspeed BOV Spring
- Drivetrain which meth injection kit for an n18?
- Drivetrain octane boosters for JB+ set at 1-2 o'clock
- Drivetrain Celtic Tuning
- Drivetrain :: ECS Tuning :: ECS Carbon Fiber Intake
- Drivetrain Manic tune stage 2
- Drivetrain VIP + Scorpion Franken-Exhaust
- Drivetrain CARBON FIBER driveshaft for CM All4 - who's interested?
- Drivetrain Ru-1540?
- Drivetrain CUSTOM (2nd cat-back) 3" Exhaust into dual 2.5" exit pipes
- Drivetrain resonator delete
- Drivetrain Questions/confused about CAI's
- Drivetrain Are there any Intake/Exhaust Manifold Options?
- Drivetrain CM JCW stock exhaust on CM S All4?
- Drivetrain Thermal Blankets
- Drivetrain FMIC, what's the best
- Drivetrain $128 fmic?
- Drivetrain is an R56 turbo the same as our CM's?
- Drivetrain exhaust and etc info
- Drivetrain New N18 tuning option?!
- Drivetrain jb+ boost amount and other questions
- Drivetrain Might be letting go of my JB+
- Drivetrain VIP Customs AIRVIP 3 Intake - Instructions
- Drivetrain Tuning steering wheel power assist
- Drivetrain Going catless, but how?
- Drivetrain DDM Works Gen 2 Cooper Intake on a Countryman
- Drivetrain Aftermarket exhaust fitment with JCW Aero Kit
- Drivetrain O2 simulator for catless Downpipe?
- Drivetrain BOV upgrade question
- Drivetrain Downpipe that doesn't cause cel?
- Drivetrain JCW Exhaust Question
- Drivetrain BMS JB+ Tuning questions
- Drivetrain Exhaust Manifold install tips?
- Drivetrain torque arm insert - R60
- Drivetrain Aquamist HFS-4
- Drivetrain Using a DDM Intake on a Countryman S
- Drivetrain what ecu upgrade should i do?
- Drivetrain Replacing Rear Endlinks
- Drivetrain All4 50/50 Switch
- Drivetrain anyone install the forge inlet pipe?
- Drivetrain Anyone tried to install a DOS v1 in a Countryman?
- Drivetrain Flutter Noise under hard acceleration
- Drivetrain Meth?
- Drivetrain Looking for a FMIC Install thread
- Drivetrain Who has the BMS tune?
- Drivetrain FMIC and cool IAT impact to HP, question
- Drivetrain VIP CAI on CM ALL4
- Drivetrain NM High Intake By-Pass
- Drivetrain Pics/ and or results of K&N RU-1540 filter install?
- Drivetrain Next mod?
- Drivetrain Forge BOV - Atmospheric versus Recirc
- Drivetrain Finally from aFe!
- Drivetrain HELIX Mounted on R60/R61
- Drivetrain DoS Intake Install
- Drivetrain FMIC! OEM VS. Aftermarket
- Drivetrain VIP Intake - Filter Angle?
- Drivetrain JCW Exhaust Tips vs. Aero Kit Tips Sound
- Drivetrain Timing chain ?
- Drivetrain Akrapovic DP
- Drivetrain Coopercrap R60 Exhaust worth it or not
- Drivetrain jcw map sensor vs r56 s sensor
- Drivetrain 2nd Cat Delete
- Drivetrain Custom Exhuaust Questions??
- Drivetrain Mods for the N00bs (and by "n00b", I mean, uh, me)
- Drivetrain P0141 CEL Code?
- Drivetrain RaceChip Ultimate
- Drivetrain So in All Seriousness, What's the Deal with the Lack of Performance Tunes?
- Drivetrain Borla exhaust?!? Any advice?
- Drivetrain Which exhaust shall I get?! Advice needed pls ...
- Drivetrain OEM Turbo Heat Shield Cover
- Drivetrain Exhausts: Milltek or NM?
- Drivetrain Upgraded Cat? No need for a CEL $6 fix!
- Drivetrain Magnaflow + 4" DiMisa tips install with sound clips
- Drivetrain R60 Throwout Bearings: 12 months or 12K miles
- Drivetrain Akrapovic Delete R
- Drivetrain WTH is that sound?
- Drivetrain brake fluid resevoir cap
- Drivetrain Looking for NON oiled CAI options for R60/N18
- Drivetrain Exhaust performance gains between OEM pipe, 2.5", 3"??
- Drivetrain Milltek Sport DP-back Exhaust sound
- Drivetrain Megan Racing exhaust for R60
- Drivetrain I don't see a resonator on ye old ALL4...
- Drivetrain Charge (cold side) Pipe-NM
- Drivetrain Exhaust advice
- Drivetrain Keep OEM muffler, but replace resonator/2nd cat with straight pipe?
- Drivetrain Any difference in drop in filters?
- Drivetrain Tyrolsport Shift Rx for R60: Who wants them?
- Drivetrain Cold cais bmc
- Drivetrain NM ECU tune + auto transmission -- experiences?
- Drivetrain All4 Gearbox and Transfer case: who makes it?
- Drivetrain Feedback on mods
- Drivetrain What is this? (Intake baffle?)
- Drivetrain Generic Intercooler?
- Drivetrain Intercooler Installation Pics
- Drivetrain Group Buy on TyrolSport FMIC
- Drivetrain Remus Powerizer
- Drivetrain Magnaflow Camaro muffler in Countryman?
- Drivetrain NM Catback exhaust
- Drivetrain Resonator and 2nd Cat Delete - CM4
- Drivetrain More questions about the JCW muffler (that I don't think have been asked yet)
- Drivetrain Intercooler Muffler Delete Pipe
- Drivetrain Helix Intercooler Group Buy
- Drivetrain Cold start problem
- Drivetrain Automatic transmission use
- Drivetrain No Boost and Half Power - while driving thick SoCal traffic
- Drivetrain Making a warm Air intake a cool air intake
- Drivetrain Forge DV (BOV) on R60S
- Drivetrain Has anyone just installed the John Cooper Works Intermediate Pipe?
- Drivetrain Oil Catch Can
- Drivetrain ETA on DOS CAI
- Drivetrain Another Exhaust Noise Topic
- Drivetrain Transmission Upgrade?
- Drivetrain Alta Performace Intake
- Drivetrain Painted JCW Exhaust?
- Drivetrain OS Giken Clutch
- Drivetrain R56 JCW CAI in R60
- Drivetrain Anyone looking to build a BEAST R60?
- Drivetrain Back, but with complaints. Intake sounds are...off?
- Drivetrain Non-kit intake mods?
- Drivetrain AFE Pro Dry S
- Drivetrain jcw countryman
- Drivetrain Injen Cold Air Intake on 2011 MCS
- Drivetrain NM 2WD Torque Arm bushing now avail
- Drivetrain Magnaflow Exhaust Install
- Drivetrain FMIC Solution - Forge R56 FMIC
- Drivetrain JCW Exhaust Install Video
- Drivetrain JCW Intake
- Drivetrain "All4" exhaust on FWD R60?
- Drivetrain Brake Duct Swap?
- Drivetrain Oil Catch Can (OCC)
- Drivetrain NM Short Shifter - GET ONE
- Drivetrain Ultra-Gauge Vers.1.2
