Drivetrain Rear Differential Mounting Bushing Replacement
Old Apr 12, 2020 | 07:13 PM
ivegota's Avatar
ivegota
Post Rear Differential Mounting Bushing Replacement
I had ordered the poly bushings from waymotorworks, for my 2016 R60 S ALL4, (PFR5-1825 MINI Countryman R60 4WD Rear Diff Rear Mounting Bushing). These are the whole bushing replacements, not just the inserts.
I was hoping I could just cut the rubber bushing on the car so I wouldn’t have to take out the whole cross member holding the differential to press it out etc.
The way the rubber is sticking to the walls though, it looks like the original bushing had a metal sleeve on the outside of the rubber (in addition to the inner sleeve around the bolt). So, I just would like to confirm with someone if that’s the case before I move forward, either cutting it out or pressing it out.
For reference (Item 1): https://www.newtis.info/tisv2/a/en/r...ism/1VnXr91Bcr
Thanks!
Old Apr 13, 2020 | 01:55 PM
ivegota's Avatar
ivegota
Thumbs up
I was able to confirm it was a metal sleeve, so I was able to cut some of the rubber out of the way with a reciprocating saw and cut some vertical lines to relieve pressure. Popped right out as I was making the second line. I knicked the mount a little bit, but not to bad considering the first time I used a reciprocating saw... :-)
Old Feb 16, 2021 | 06:29 PM
Cracolici's Avatar
Cracolici
This may be an old post, but I am In search of the same bushing (I think Atleast) I need The bushing that the rear differential mounts into. Is this what you installed? And where did you get it at? I am In a lose of finding it.
thanks for the help.
Old Feb 17, 2021 | 08:10 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
These would be what he installed
https://www.waymotorworks.com/powerf...r60-all-4.html
They are for where the rear diff mounts to the body on the ALL4 Countryman
WayMotorWorks
R60/61 Cooper S Drivetrain
Apr 17, 2016 09:00 PM
dhabutcher
Suspension
Nov 3, 2009 04:42 PM
bobbyharr883
Classic Mini Talk
May 28, 2009 07:18 PM
meb
Suspension
Mar 9, 2006 09:44 AM
