Drivetrain Exhaust performance gains between OEM pipe, 2.5", 3"??
Old Apr 28, 2013 | 08:20 PM
MinneMINI's Avatar
MinneMINI
So my local exhaust shop says that he could install an axle back system with a muffler and tips at a fair price. Since it is axle back that means it would mate to the OEM pipe which is 2" or 2.18" if I remember right. My question is if I went CAT BACK and increased the pipe size to 2.5" would I see any appreciable gains from doing so? I could see going to 3" and gaining something worthy but I don't want/need 3". So is it worth going to 2.5" or just stick with axle back and save some money? FYI I would be installing the magnaflow muffler #12265. Cheers!
Old Apr 28, 2013 | 09:07 PM
Braminator's Avatar
Braminator
If you plan on future mods, then yes upping the tubing size will help. How much all depends on all the mods you do.
Old Apr 29, 2013 | 04:14 AM
MinneMINI's Avatar
MinneMINI
I don't plan on more than a CAI at this point. *Maybe* muffler delete. So changing the pipe size to 2.5 would not do much if that's all the mods I want to do? Thanks braminator.
Old Apr 29, 2013 | 05:05 AM
Braminator's Avatar
Braminator
Unless you plan on a tune and a bigger turbo there wont be enough of a difference for you to feel IMO.
Old May 7, 2013 | 07:24 PM
1bigpea's Avatar
1bigpea
Tune or no tune having a 3" pipe over a 2.5" will give you a significantly better flow and create less restrictions for your turbo. Anyone with the All4 might not be able to go with a bigger pipe because the drive train takes up the space the non-All4 uses, which allows for the 3" pipe all the way back.
I've noticed less lag on the turbo because of the exhaust specifically.
Old May 7, 2013 | 07:45 PM
Braminator's Avatar
Braminator
Even exhaust makers like Milltek and Magnaflow use a 2.5 inch exhaust. going to a 3 inch can cause a power loss down low and only gain on the high side and increase noise.
For your reading pleasure.
http://www.magnaflow.com/02product/s...ayproducts.asp
http://www.millteksport.com/exhaust....3#.UYm7rcph68A
http://www.exhaustvideos.com/faq/how...pipe-diameter/
http://www.tercelreference.com/terce...st_theory.html
Old May 7, 2013 | 07:47 PM
1bigpea's Avatar
1bigpea
Cool, I'll check these out.
Old May 9, 2013 | 05:42 PM
Melangell's Avatar
Melangell
A Cat-back exhaust gives you nothing...
Old May 9, 2013 | 06:03 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We did a bunch of testing when we built our custom exhaust and found no gain with the 3inch over a 2.5inch. We actually lost a little torque, mainly cause the exhaust gas velocity dies with the 3inch.
Old May 9, 2013 | 06:13 PM
Braminator's Avatar
Braminator
I second that.
Old May 9, 2013 | 06:22 PM
MinneMINI's Avatar
MinneMINI
I second that.
But are there real gains to be had from 2" ----> 2.5" i.e. stock pipe size? THanks
Old May 11, 2013 | 09:30 PM
Melangell's Avatar
Melangell
Cat back.... no.
Old May 4, 2014 | 10:35 AM
ridinDirty's Avatar
ridinDirty
Way-
Was all this testing done on a stock mini or did it have bolt-ons , tune, bigger turbo .. etc ?
Old May 5, 2014 | 07:21 AM
bmwr606's Avatar
bmwr606
i have a milltek 2.5 inch DP back on my 2012 all4
there is another 2012 all4 in town that is speced like mine
with both all4s fully stock, doing rollons from 1500 rpm , both stock, we were axle-2-axle all the way to redline
after i installed my milltek (only mod on the car), same road, same 1500 rpm rollon, i am ~5 car lengths ahead at redline
my buddy says all the gain is below ~4500 rpm, from ~4500 to redline i am not pulling away any more
i have not dynoed the car
scott
EDIT: ALL ROLLONS DONE IN 3rd GEAR
Old May 5, 2014 | 04:23 PM
ridinDirty's Avatar
ridinDirty
Good info , nothing like good old drag racing proof...lol
I'm sure you guess where not speeding right ??...lol
Old May 5, 2014 | 04:41 PM
bmwr606's Avatar
bmwr606
it was not a drag race ... a rollon takes driver skill put of the action ... besides, with all the clutch woes I read about I NEVER do a drag start
Old May 17, 2014 | 03:09 PM
bmwr606's Avatar
bmwr606
  • Originally Posted by Melangell
i disagree ....
a second cat back may not get any gain, but my milltek downpipe back gained me 5+ car lengths against another similarly equipped CM all4 in a 3rd gear roll on from 1500 to 4500 rpm
before the milltek, we were axel to axel, after the milltek, and only changing the exhaust, NO other mods, i was visibly faster
so that mysterious person "everyone" that "knows" there is no gain from an exhaust is wrong!
blackie
Oct 2, 2015 07:41 PM
FLYM1N1
Aug 16, 2015 01:15 PM
ASRman
Aug 13, 2015 09:33 AM
Aug 12, 2015 01:24 PM
