Drivetrain Aftermarket clutch assembly for R60 ALL4
Hi, I hope that this is the correct place to ask this question.
Do any of you have an aftermarket clutch assembly in installed in your Mini Cooper S Countryman ALL4? Something that has eliminated the problem OEM assembly and still retained an acceptable everyday road experience?
Clutch Masters FX400
Disclaimer: I do NOT work for/with Clutch Masters, I have no personal vested interest in anyone purchasing their products.
Not sure of your mods if any, I'm running a Manic Stage 2 with the necessary upgrades. About 10k miles ago I had to put in a new clutch, went with a stock clutch and aftermarket lightweight single price aluminum flywheel from AASCO because I got a great deal. It would have worked well if not for the power upgrades. Last week I had to put in a new clutch because it was slipping pretty dang bad, the friction material was completely worn off. In a pinch I went with a Clutch Master's FX400 6-puck ceramic sprung clutch and their 24lb steel flywheel, works great. The stock clutch disk is rigid with a dual-mass flywheel to soak up the vibrations. After running a rigid disk clutch with a one piece flywheel the sprung FX400 feels pretty great. No issues holding power so far. The website alleges it can hold 415ft-lbs of torque 🤷♂️ we'll see.
ECSTuning (05-05-2020)
Bring back the dead thread, do you still post or own the countryman, I've been advised that I'll be wanting to replace my clutch kit soon since I have 80k on the clock, and also told that there were no good reliable clutches on the market other than the oem set up for driving daily and occasional spirited driving. (Driving daily as in, to and from work without traffic)
if you don’t have any serious mods maybe that would be the best route. The vendors here are very knowledgeable. Try contacting them directly.
Urbanr60 (05-05-2020)
Bring back the dead thread, do you still post or own the countryman, I've been advised that I'll be wanting to replace my clutch kit soon since I have 80k on the clock, and also told that there were no good reliable clutches on the market other than the OEM set up for driving daily and occasional spirited driving. (Driving daily as in, to and from work without traffic)
Urbanr60 (05-18-2020)
There are quite a few reliable clutch assemblies out there for the Countryman (base/S/JCW/Tuned). It all just depends on what you need. If you are wanting to stay stock with the dual mass flywheel then the OEM clutch assembly is really one of the best for that. If you are wanting a single mass flywheel for the quicker RPM response and are stock otherwise then either the basic JMTC or Valeo clutch single mass kit are good options. Then of course there are the higher stage options out there that will definitely be better than stock at dealing with the Countryman, and some are as easy to drive with as stock (JMTC clutch comes to mind).
Always a good idea.
Always a good idea.
portedbuckle
12-07-2011 05:53 PM
