Drivetrain AFE Pro Dry S
Old Sep 28, 2012 | 05:29 AM
dpike's Avatar
dpike
AFE Pro Dry S
anyone use one of these ? any pros or cons to this drop in filter ? opinions ?
Old Sep 28, 2012 | 05:56 AM
Hujan's Avatar
Hujan
http://afepower.com/shop/details_new...6L&&brandID=59
The filter you linked to is an oiled filter. Many on here are not fans of oiled filters because the oil can get on the MAF sensor and cause issues. AFE does make dry drop-in filters for our cars, as do other manufacturers. I am sure they flow better and therefore make increases in performance over stock (whether HP, torque, and/or MPG) but only slightly. It also has the added benefit of being reusable and should save some $ in the long run but at the expense of more labor for you. I say go for it.
Old Sep 28, 2012 | 09:19 PM
Bakerbrdz's Avatar
Bakerbrdz
Use maf sensor spray every oil change and you'll be straight
Old Sep 29, 2012 | 06:37 AM
mikeyb74's Avatar
mikeyb74
I've used both the dry and oil filters from aFe with no problems.
Old Sep 29, 2012 | 09:14 AM
sbdubya's Avatar
sbdubya
As soon as I got home with my '12 I put the dry filter in. No problems and I think it works great. Coouldn't tell you about any "gains" as I have nothing to compare it to.
Old Sep 30, 2012 | 05:40 AM
dpike's Avatar
dpike
thanks guys. the link is to both oiled and dry, you have to use the drop down for the dry.
sbdubya... how often have you cleaned it ?
Old Sep 30, 2012 | 10:59 AM
sbdubya's Avatar
sbdubya
Checked it at 5000 miles and it was still clean. When I hit 10,000 I'll check it again (in about a month).
Old Oct 2, 2012 | 04:30 AM
dpike's Avatar
dpike
i should point out that the vehicle selector search drop down on the afe site does not include the option for the Countryman S the proper link for the S is http://afepower.com/shop/details_new...174&brandID=59 according to the guys at afe. the original link was for the non S model.
*original reference links removed
USNAE2
16
Jun 17, 2022 07:17 AM
OutMotoring
Mar 3, 2017 06:29 AM
monkiboy
Oct 16, 2015 09:58 AM
Suspension Products
Oct 1, 2015 11:53 AM
AoxoMoxoA
Tires, Wheels, & Brakes
Sep 30, 2015 06:00 AM
