PDA
View Full Version : R60/R61 Stock Problems/Issues
Pages : 1 [2] 3 4 5
  1. 2013 Countryman All4 Transfer Case
  2. Reduced engine output at random times
  3. Ticking after changing Timing Chain
  4. Solution: Smoking from Exhaust after Long Periods of Idling
  5. What are these parts?
  6. Check Engine Oil Pressure?
  7. P0128 after 3 new thermostats / CTS
  8. Bang! Rear suspension dropped
  9. Cranks and trys to start, but doesnt
  10. Temperature goes up and down while driving
  11. Coolant temperature comes up and down while driving, 204C to 217C.
  12. High Coolant temp? Fan constantly Running.. limp mode..
  13. What is that noise? crunch, rattle, lose power, oil light?
  14. airbox intake hose loose?
  15. my turn for a coolant leak!
  16. coolant leak, possibly water pump?
  17. OBDII report no faults, despite Engine Malfunction message
  18. Whining sound/ Valve cover replacement
  19. Front Outer Lower Ball Joint Removal and Replacement
  20. Lots of rattle on cold start.
  21. Tinted headlights and Tails HELP
  22. losing coolant mystery
  23. Waterpump Install 2011 MCS ALL4
  24. Door is Open won't go off with door closed
  25. Floored it and dumped coolant!?
  26. Not sure what part this is and if it’s ok to be loose.
  27. 2012 Countryman S - Had misfire and now has p2418 code
  28. 2012 R60 fuse box question
  29. Name this spark plug condition!
  30. 6th gear pops out
  31. Are these common issues with 2012 Countryman?
  32. R60 Cooper S All4 Limp mode 2c58
  33. Live Wire Melted (Battery>Starter/Alternator)
  34. R60 Cooper S All4 Limp mode 2c58
  35. R60 Cooper S All4 Limp mode 2c58 drives me crazy
  36. Clutch issue...Anyone ever see this?
  37. 2014 R61 JCW RPM at each shift(Auto)
  38. Has anyone seen a clutch do this?
  39. Help! Trip halted by P0367/8 codes!
  40. 2011 Countryman S limp mode
  41. Rear Marker Bulb Replacement - '12 Countryman
  42. Oil drip
  43. Running issues multiple codes
  44. R60 Driver Side Outer CV Boot - Automatic
  45. Need part identification help -- leaky washer fluid connection
  46. Generic P054B code; dealership just DOUBLED diagnostic fee when I need it.
  47. oil leak and coolant issue
  48. oil and coolant issue
  49. R60 Rear Output Axle Replacement
  50. Excessive coolant loss, no leaks
  51. Service Overdue Message
  52. 2012 All4 MT Shake in 1st and 2nd
  53. Fluid (coolant?) leak
  54. DMTL, Line break Faults
  55. trouble with Vanos actuator?
  56. R60 Countryman
  57. Leaking Washer Fluid
  58. 2012 Countryman All4 rear passenger CV joint leaking?
  59. R60 Suspension Knocking Woes
  60. Getting P0128 in Hot Weather
  61. Can't get fob to fully engage
  62. Clicking While Turning
  63. Timing chain: preventive replacement?
  64. Whistle sound when idle
  65. Drivers Seat Won’t Stay in Low Position
  66. Possible vacuum pump failure- low power/half power light
  67. Be Careful Ordering a Mini Clutch
  68. 2012 Countryman S Will Not Start
  69. Think my wheel bearings are shot
  70. Vibration/Rattle at 2700 RPM
  71. Need some ideas!
  72. Missing Sensor?
  73. Potential HPFP issues?
  74. 2012 countryman all4 s engine noise
  75. Cylinder 2 misfire
  76. No crank no start
  77. No compression #4 after head change
  78. Not battery or alternator but grounding strap
  79. R60 Hesitation under acceleration
  80. All4 manual trans oil change alternative fill, and shift linkage lube
  81. AC Relay confusion
  82. Door lock actuator failed???
  83. AC fan speed doesn't change after 4th setting
  84. Turbo failing on 2012 Countryman
  85. rear door release not working
  86. 2014 countryman base model doesn’t start
  87. Front strut mount
  88. Quick question on coolant system
  89. Wheel bearing vs run flat tire noise
  90. Roof Popping Noise
  91. After Battery Replacement Radio Loses Presets - Satellite and Terrestrial
  92. High coolant temps
  93. Loud Timing Component Knock
  94. Possible valve cover leak?
  95. R60 Countryman
  96. What parts are these?
  97. Fuel Tank Cover???
  98. Oil smell after shut down. Sometimes at start up
  99. Turbo-related Issue?
  100. They're not $hitting you about using MINI spec oil filters
  101. quiet whine when gently accelerating
  102. Wont Start Water Damage Electrical Puzzle
  103. Reduced power light and multiple codes
  104. MINI R60 JCW buying advice
  105. Chocolate milk
  106. Frustrating boost leak?
  107. Too much fuel pressure? P0172 system too rich
  108. P0128 thrown only at extreme cold temps
  109. 5E8A Code with yellow 4x4!
  110. Left Wheel Speed Sensor codes even after Sensor replaced?
  111. Weird engine malfunction message
  112. Weird noise coming from engine, when cold starting
  113. 2012 R60 Base CV Axle Confusion!
  114. Door warning light when door is closed
  115. Broken PCV Cap
  116. Bad fan switch?
  117. Cel p10ee
  118. Starts then turns off
  119. New Battery, New Alternator = Dead Battery
  120. Alternator Failure
  121. Self cancel turn signals
  122. 2012 CMS wouldnt start but the light on the start button did and the radio.
  123. Engine malfunction. Reduced power
  124. Brake Lights Stuck On
  125. 2108 Countryman Won't Read USB
  126. 2011 Countryman S (R60) No Lights, No Start, Electrical Issue
  127. Lagging/Jerking when stepping on it at speed
  128. Oil leak help
  129. Still same Check Engine Light Codes after replacing Thermostat and Ignition Coils
  130. New transmission at 69k. WTF
  131. CV Joint Issue
  132. Odd "rattle"
  133. Cracked Engine Piece
  134. Help was locked in car today
  135. 5E83 code, Anyone?
  136. R61 AC Recharge
  137. Alternator not charging - charging system malfunction warning
  138. Parking light always on
  139. AWD control coil open?
  140. No Start = key fob?
  141. Do I have a lemon?
  142. '12 R60 about to impact crude oil prices
  143. Speedo/radio controls and Boost CD cable issue
  144. Issue with Speedo/Radio controls and Boost CD plug
  145. Loose vents
  146. Mini Countryman All4 S CVT fluid change question
  147. Gear Shift knob Replacement R61
  148. Time for a timing chain kit
  149. Mini Countryman 4X4! Light on
  150. Hood Latch
  151. Help A Girl Out - New To Wrenching! 2013 Countryman Vanos Solenoid Replacement
  152. Sport Mode Issue
  153. Sport mode issue
  154. Fuel Gauge Troubleshooting
  155. tailgate latch on 2012 Countryman S will not latch
  156. 2014 CM ALL4 S Transfer Case Bearing Failure
  157. Right side headlight, fog lamp, marker light OUT
  158. What does it mean when white smoke comes out of the exhaust?
  159. No start or dash lights. Help?
  160. DTC and Satellite tuner enable codes for ISTA P?
  161. New Battery installed today.
  162. New used mini, need help
  163. 28BD Throttle valve, closing spring check: Malfunction
  164. Problem with a/c
  165. '13 R60 Engine Knocking & Vibrating After Sparkplug Change
  166. Passenger restraint/Airbag warning light.....fuse?
  167. Bosch 9747 Spark Plug ok for R60 Cooper S?
  168. Throttle Hesitation when Accelerating
  169. new guy! with problem
  170. 2C57 low charging pressure and/or not plausible
  171. P0015 Code Question
  172. 2013 mini paceman pcv valve
  173. Carbon build up on exhaust tips
  174. A MASSIVE amount of water
  175. Turbo wastegate
  176. Diagnostic help codes 5E83 and 5E88
  177. Adjusting headlight level?
  178. Random error 931d.
  179. 4X4! And DSC lights on
  180. Looking at 2015 CMS’s All4...questions
  181. 2013 JCW R60 Reduced Engine Power
  182. Exhaust Flex Pipe snapped
  183. Passenger Side Daytime Running Light wont turn off
  184. Changed plugs, air filter -- Check Engine
  185. Computer Failure after Water Pump Installation??
  186. 2012 Countryman Stumble at Mid-Throttle
  187. 2011 Mini Countryman All4 S High pitch whistle
  188. Replacing rear rotors on Countryman what tools?
  189. 2013 Mini Countryman coil replacement
  190. 2014 countryman wont start
  191. Tracking down engine noise.
  192. A/C Condenser Replacement
  193. Countryman Common Problems
  194. check engine light and rough starts
  195. Chk Engine P098
  196. PO98 Coolant or Thermostat Sensor?
  197. R60 Countryman Wheel Bearings
  198. 2013 MINI Cooper Countryman S Cylinder 1 Misfire After Spark Plug & Coil Replaced
  199. Replace BOV
  200. Countryman Engine Rattle
  201. Audio Input Cable for newer Ipods
  202. A/C cycles off when stopping
  203. Cylinder misfire!
  204. Antifreeze leak at Transmission oil cooler.
  205. Oil spot on bottom of MT. Couple Qs
  206. Boot lid strap? (What's this do?)
  207. JB+ and spark plug issues.
  208. Bonnet Stuck Shut on 2013 R60S
  209. VANOS replacement issue
  210. Really StrangeRadio problem on my Countryman 2012
  211. Help! Is this a clutch issue?
  212. P053A code Pcv issues.
  213. automatic gearbox icon, car won't start
  214. misfire P0301, P0302, DME(ecu) related
  215. 2015 R60 Scavenge Air Line
  216. 2011 Mini Cooper Countryman sunroof issues
  217. P054B/P0015 Code
  218. Countryman R60 Power Window Moves Incrementally
  219. Dashboard Warning Light Interpretation 2011 Countryman S (R60)
  220. Passenger Side CV Shaft ALL4
  221. Countryman radio removal
  222. Rough idle and diesel sounding on cold starts
  223. Valve Cover Gasket
  224. mini cooper
  225. Accessing License Plate Light Lamp Assembly
  226. Engine light
  227. 2011 MCS All4 2C57, 2C90, 2C91
  228. Rough idle until Engine warms
  229. 2012 Countryman electrical problems: battery & OEM headlight
  230. Fault Codes After Getting Towed
  231. 2012 R60 Hazard Button
  232. Headlight Washers Not Working
  233. is there a radiator service position on the R60?
  234. how to meter alternator output
  235. Interior Door Handle Removal
  236. 2014 CountryMan S: Engine Operating at reduced output....
  237. Help with obd2 code P05CE
  238. Ticking noise near windshield?
  239. Cold Countryman Turbo?
  240. 2 Front Main Seals within 25k
  241. Hill Start / Clutch Burning
  242. Dang Battery
  243. Two nagging issues, one new one.
  244. can low oil pressure cause full power not available engine fault light to come on?
  245. Faulty Thermostat Control Circuit
  246. Green Coolant??!
  247. code - P0462
  248. Vacuum pump valve
  249. stalling sputtering
  250. R60 cooling system drain procedure
